icloudfiles Posted August 31, 2024 Share #1 Posted August 31, 2024 Advertisement (gone after registration) Would you happen to know what needs to be adjusted if the RF patch is tilted slightly (clockwise direction) for eg. if you put a pencil on the table and try to focus, it never actually aligns but rather makes a cross (x) if that makes sense. At no point is the pencil in the patch parallel to the actual pencil nor does it overlap perfectly when in focus. I get that some skew is normal but this seems way off. I noticed this after a long ride on my old Vespa (lots of vibration) Is there a 3rd screw somewhere besides the horizontal and vertical adjustment screws? Many thanks. Link to post Share on other sites More sharing options...
Advertisement Posted August 31, 2024 Posted August 31, 2024 Hi icloudfiles, Take a look here RF patch tilted clockwise. I'm sure you'll find what you were looking for!
jaeger Posted August 31, 2024 Share #2 Posted August 31, 2024 None of the adjustments are meant for patch leveling, It probably needs to send back to Leica for service. Link to post Share on other sites More sharing options...
Mute-on Posted August 31, 2024 Share #3 Posted August 31, 2024 Sounds like vertical RF alignment might be off (two images are misaligned vertically). Adjustment is via screw on the front of the top plate, under the Leica dot. Link to post Share on other sites More sharing options...
Topsy Posted August 31, 2024 Share #4 Posted August 31, 2024 If you have a straight line (your pencil) but you do not frame it at 90 degrees (straight on to the vertical pencil) then the rangefinder can't give a precise image because some of the pencil is farther away and some of the pencil is closer than the point of focus. Check your rangefinder against a vertical straight line with your camera at 90 degrees to it. Link to post Share on other sites More sharing options...
jaapv Posted August 31, 2024 Share #5 Posted August 31, 2024 I would advise you to have the rangefinder completely adjusted by a reputed third-party service. 1 Link to post Share on other sites More sharing options...
LocalHero1953 Posted August 31, 2024 Share #6 Posted August 31, 2024 (edited) I agree with @Topsy - this may be normal behaviour. If you mean that the pencil is flat on the table aligned away from you, then it will form a cross; the point of focus is where the pencil images intersect. This happens all the time if (e.g.) there is a fence line running away from you. If your pencil is vertical, parallel to the camera focal plane (it's easier to check with a window frame), and it forms a cross, then yes, something is off that cannot be fixed by the screw under the top plate. Edited August 31, 2024 by LocalHero1953 1 Link to post Share on other sites More sharing options...
pgk Posted August 31, 2024 Share #7 Posted August 31, 2024 Advertisement (gone after registration) This sounds like the prism inside the rangefinder has become loose and is now misaligned (Vespa vibration?) and it will need a repair (precise realignment) by someone familiar with working on Leica rangefinders. Its not something that you are likely to be able to do yourself and I wouldn't leave it in case it loosens further or becomes detatched. You don't specify where you are - in some countries there are great independent repairers, in others it may need to visit the Leica importer. Link to post Share on other sites More sharing options...
adan Posted August 31, 2024 Share #8 Posted August 31, 2024 NORMAL! (probably) - as described by Topsy and LocalHero1953. Remember that the whole idea of a rangefinder is two windows viewing the world from different directions (usually on either side of the lens) So if the pencil is directly in front of the lens, the two RF views will show it slanted in opposite directions \ | / | | ( ) (camera and lens) Superimpose those two views (red) in the viewfinder, focused on the center of the pencil, and you get an X. And the center of the X, where the views coverage, is the point in focus. Move in and out to focus on the near end of the pencil, or the far end, and you should see \/ or /\ 1 Link to post Share on other sites More sharing options...
Topsy Posted August 31, 2024 Share #9 Posted August 31, 2024 (edited) 36 minutes ago, pgk said: This sounds like the prism inside the rangefinder has become loose and is now misaligned (Vespa vibration?) and it will need a repair (precise realignment) by someone familiar with working on Leica rangefinders. Its not something that you are likely to be able to do yourself and I wouldn't leave it in case it loosens further or becomes detatched. You don't specify where you are - in some countries there are great independent repairers, in others it may need to visit the Leica importer. If that was the case I would have to send all 6 of my Leicas for this precise realignment but when I focus on vertical upright straight lines (parallel to the film/sensor plane) I have no issues, @adan described it better than me. BTW the closer the subject is the more pronounced the discrepency is. To the OP just try an upright vertical before thinking the worst. Edited August 31, 2024 by Topsy Link to post Share on other sites More sharing options...
pgk Posted August 31, 2024 Share #10 Posted August 31, 2024 (edited) 1 hour ago, Topsy said: BTW the closer the subject is the more pronounced the discrepency is. I've tried this at the closest focus distance and whilst there is a marginal degree of parallax failure at the top and bottom of the rf patch it is anything but 'way off' as described in the OP. At worst it is very minor and needs to be looked for. I always focus using the central area in the rf patch anyway and I actually had to look for the top and bottom shift in the rf patch after having used Leicas for over 40 years. Hardly an issue and certainly couldn't be described as obvious in any way whatsoever. I imagine that there is some degree of tolerance in the angular deviation of the prism in the rangefinder and at some point it might drift outside this and becomes obvious. Edited August 31, 2024 by pgk 1 Link to post Share on other sites More sharing options...
jaapv Posted August 31, 2024 Share #11 Posted August 31, 2024 And the camera only exhibited this behaviour after being subjected to strong vibrations. Link to post Share on other sites More sharing options...
pgk Posted August 31, 2024 Share #12 Posted August 31, 2024 4 minutes ago, jaapv said: And the camera only exhibited this behaviour after being subjected to strong vibrations. Yes but I'm never too worried about this as my cameras have been subject to a lot of such treatment (diveboats can be bad for heay vibrations and constant motion, some impacty, and this has never caused me any problems), but it could be the cause if the prism isn't sufficiently tightened up I suppose. Link to post Share on other sites More sharing options...
jaapv Posted August 31, 2024 Share #13 Posted August 31, 2024 It happened to me in an old Cessna 1 Link to post Share on other sites More sharing options...
LocalHero1953 Posted August 31, 2024 Share #14 Posted August 31, 2024 The rf on my M2 survived trips in an open door army helicopter in Southern Oman in 1981. That's my all time reference for maximum vibration. Sadly, the negatives didn't handle the climate very well. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 3 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/404725-rf-patch-tilted-clockwise/?do=findComment&comment=5521591'>More sharing options...
icloudfiles Posted August 31, 2024 Author Share #15 Posted August 31, 2024 5 hours ago, Topsy said: If that was the case I would have to send all 6 of my Leicas for this precise realignment but when I focus on vertical upright straight lines (parallel to the film/sensor plane) I have no issues, @adan described it better than me. BTW the closer the subject is the more pronounced the discrepency is. To the OP just try an upright vertical before thinking the worst. 90 degrees parallel to the sensor plane is fine. Looking down at something on the table or the edge of the sidewalk forms a long X. 1 1 Link to post Share on other sites More sharing options...
icloudfiles Posted August 31, 2024 Author Share #16 Posted August 31, 2024 3 hours ago, jaapv said: And the camera only exhibited this behaviour after being subjected to strong vibrations. did you send it in then? What’s it like for you now… does looking down at a pencil at an angle overlap perfectly. Link to post Share on other sites More sharing options...
icloudfiles Posted August 31, 2024 Author Share #17 Posted August 31, 2024 4 hours ago, pgk said: I've tried this at the closest focus distance and whilst there is a marginal degree of parallax failure at the top and bottom of the rf patch it is anything but 'way off' as described in the OP. At worst it is very minor and needs to be looked for. I always focus using the central area in the rf patch anyway and I actually had to look for the top and bottom shift in the rf patch after having used Leicas for over 40 years. Hardly an issue and certainly couldn't be described as obvious in any way whatsoever. I imagine that there is some degree of tolerance in the angular deviation of the prism in the rangefinder and at some point it might drift outside this and becomes obvious. Bad enough that I get eye strain after taking few photos. Didn’t happen before the Vespa ride. Maybe my retina needs realignment will stop by the Leica store. Link to post Share on other sites More sharing options...
Topsy Posted August 31, 2024 Share #18 Posted August 31, 2024 1 hour ago, icloudfiles said: 90 degrees parallel to the sensor plane is fine. Looking down at something on the table or the edge of the sidewalk forms a long X. All 6 of my Leica Rangefinders are like that, always have been (plus 2 that I no longer have) I think it's just that angular parralax thing, be aware of it but I don't think any repair man can change it. Link to post Share on other sites More sharing options...
jaapv Posted August 31, 2024 Share #19 Posted August 31, 2024 2 hours ago, icloudfiles said: did you send it in then? What’s it like for you now… does looking down at a pencil at an angle overlap perfectly. Well actually I drove over to Will van Manen and two glasses of wine later it was fine. Link to post Share on other sites More sharing options...
a.noctilux Posted August 31, 2024 Share #20 Posted August 31, 2024 3 hours ago, icloudfiles said: Maybe my retina needs realignment will stop by the Leica store Please report back when your retina realigned by the store. ... I'm very glad having done last week catarac operation on right eye. Never see around as well. Nextweek will be the left eye turn. Link to post Share on other sites More sharing options...
