First time for me : my 128 Gb SD card (Sandisk Extreme Pro SDXC V30 200MB/s) was defective. It was no  more recognised by the M11 (and PC and Ipad).
Hopefully I managed to recover the images with the Photorec app.
I have then reformatted the card with SD card Formatter. But now I wonder if it's safe to use this card again : is there a higher risk of failure with a "once" faulty card ?
Thank you
I had a card my M11-P stopped recognizing but it was still working on my Mac.  I did a low level format using the disk utility in MacOS and no issues since but your problem seems different and I agree that i wouldn't trust that card (or at minimum save to both internal memory and card if you want to give it another go).
Thank you
A couple of questions if I may?
Did you delete files from the card using a computer?
Did you format the card in the Mac?
are the contacts on the card clean?
I used a laptop (windows) with the program from SD Memory Card Formatter for Windows/Mac | SD Association (sdcard.org)
The contacts are clean.
I am not keen to use this card again...
Thank you
Memory is stored by switching on and off cells, an old memory does not keep enough charge to work properly.
If the SD card is old, I would get a new one.
There is software that can help maintain and recover sectors. Spinrite from GRC is used by many recovery companies as a first step.
the card is one year old, and used with care... bad luck...
Just throw it away.  I have had few card issues over the years, but any indication that a card doesn't want to perform sends it to the trash.  Come on, they are like $60.
I never mess around with SD formater, deleting files, etc on the iMac.  Always have the camera format the card when I put it back in.  Never an issue.
Thank you
What was your normal workflow with this card? And is your M11 on FW 2.0.2??
Yes, latest firmware
The problem came after this
sd card from M11 to card reader to iPad
Import some photos to Lightroom on the ipad
card back to M11
normal workflow :
- the same but I import all the photos on Lightroom (iPad) and then I reformat the card in the M11
Edited by chris7273
Leica Suggest using UHS-II cards
card back to M11
normal workflow :
It is not impossible that the issue was caused by a FW 2.0.2 issue (FW 2.0.2. has known corruption issues).
Personally I would keep the card, use it only for backup of M11 profiles and firmware updates, and buy a good UHS-II card for shooting...
Maybe for 2.0.2… but is rhe new 2.1.1 safer ? Surprise, surprise 🙂
i will buy a new sd card and dedicate the old one as a «transfer / temp » media
