That depends on the crop factor of the TL, which is googleable very quick. The question is more whether the TL lens’s image circle is broad enough for full format.
Edited by otto.f
Shooting on my SL1, the SL switches to APS-C automatically when a TL lens is mounted. My Summilux 35 TL gives excellent results and is my only AF 50mm eq lens for the SL. With the 24 MP , APSC is 24 / 1,5/1,15 = 14 MP only,  with the SL3 you should have to 35 MP.
9 minutes ago, 01af said:
55-135 mm.
You can not use the TL lens in FF mode on the SL3, shooting mode is locked to APS-C only, so it will be 80 - 210 eq. , at least it is on my SL(601). Can you confirm that the SL3 allows  FF mode with a TL lens?
Edited by dpitt
vor 26 Minuten schrieb dpitt:
You have to apply the 1.5 crop factor to both dimensions of the FF sensor. TL lenses result in 10.7 MP images on the SL and in 26.8 MP images on the SL3.
Focal length, and aperture, are properties of the lens, not the camera.  The OP might have been better served by asking about equivalent field of view, not focal length. But this word choice (and belief) has become the norm in many if not most discussions.
Jeff
Thanks. You are right ofcourse...
Edited by dpitt
12 hours ago, jaapv said:
And is on the CL/TL
Good to know.   Therefore it is the same effective focal length as CL/TL/SL3.
How about the DOF?  Will the same TL lens image have shallower depth of field when used on a SL3, than used on a CL body?
Edited by yst
Simple answer - No.
  • 3 months later...
Jeff
To be pedantic: angle of view. Field of view is defined at a given subject distance. But you are right, the focal length of a lens can be read off the barrel.
