rosshj Posted February 27, 2024 Share #1 Posted February 27, 2024 Advertisement (gone after registration) Hello. I have a light leak around the back door of my M4. It took me a while to realize it was coming from the back door, but I narrowed it down when I taped off the back door and had zero light leaks. I’m wondering if it’s my light seal at the top under the back door. If so, is this a big job to fix it? Any DIY solutions (not involving tape), or should send it out? Cheers! Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/389898-m4-light-leak-around-the-back-door/?do=findComment&comment=5059558'>More sharing options...
Advertisement Posted February 27, 2024 Posted February 27, 2024 Hi rosshj, Take a look here M4 light leak around the back door. I'm sure you'll find what you were looking for!
rosshj Posted February 27, 2024 Author Share #2 Posted February 27, 2024 This is actually a better representation of the light leak. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/389898-m4-light-leak-around-the-back-door/?do=findComment&comment=5059643'>More sharing options...
dpitt Posted February 27, 2024 Share #3 Posted February 27, 2024 It looks to be one of the sides of the back door, both top and bottom. Maybe start by inspecting the backdoor sides and see if one side does not fit as it is supposed to. Link to post Share on other sites More sharing options...
250swb Posted February 27, 2024 Share #4 Posted February 27, 2024 It looks like the light is coming from the rebate for the sliding catch of the rear door, is there any damage around there? It's hard to imagine damage or is there something stopping the catch from closing properly? The top seal is really as much a dust seal, the whole door relying on the baffles to stop any light leakage. Link to post Share on other sites More sharing options...
rosshj Posted February 27, 2024 Author Share #5 Posted February 27, 2024 Thank you all for the replies. The back door seems to be totally fine. No damage from what I can see. I'm going to run another roll through there (I've burned about 5 so far) to see what else I can figure out. Link to post Share on other sites More sharing options...
Michael Geschlecht Posted February 28, 2024 Share #6 Posted February 28, 2024 (edited) Hello Ross, Welcome to the Forum. It would appear that the felt lite seal on the side of the film chamber under the range/viewfinder window is missing. That felt lite seal should look like the 1 on the other side of the film chamber. It should go top to bottom & be thin. Best Regards, Michael Edited February 28, 2024 by Michael Geschlecht Link to post Share on other sites More sharing options...
TomB_tx Posted February 28, 2024 Share #7 Posted February 28, 2024 Advertisement (gone after registration) 10 hours ago, Michael Geschlecht said: Hello Ross, Welcome to the Forum. It would appear that the felt lite seal on the side of the film chamber under the range/viewfinder window is missing. That felt lite seal should look like the 1 on the other side of the film chamber. It should go top to bottom & be thin. Best Regards, Michael M models did not originally have felt seals at the sides of the back door, but relied on the labyrinth path around the body/door joint. My M3s & 2s do not have the seals, It was common for Techs to add the seals when cameras were serviced. Possibly repeated flexing / wear of the door made them a good idea. Sherry added them to my M4 when she serviced it. 1 Link to post Share on other sites More sharing options...
Michael Geschlecht Posted February 29, 2024 Share #8 Posted February 29, 2024 (edited) Hello Tom, I think that some M3's came originally with felt strips on both sides of the film gate. It was the felt strip NOT being on the left side that I noticed. Best Regards, Michael Edited February 29, 2024 by Michael Geschlecht Link to post Share on other sites More sharing options...
250swb Posted February 29, 2024 Share #9 Posted February 29, 2024 (edited) Foam light sealing is often added in the search for a light leak but it doesn't mean it should be there by design. I see my MP came with a very thin sealing strip either side of the film gate (and the top of course) but I don't think any camera up to that point ever had them from the factory. In the case of my MP it may simply be there to stop a clatter or damage to the paint if the door slams shut? My M4-P for example doesn't need extra sealing and has never had it, and I think the difference is in the depth of the light baffle and the paint coating which on the older cameras was a thick heavy textured crackle finish. The OP could add some foam seal around the edge (you can buy it in sheets to cut to size, 1mm or 1.5mm thick) and see if it stops the leak and life could go on, except it's probably a sign of trouble elsewhere. I'm also sure camera techies add foam because it saves searching for a leak around the door and many of their customers believe it's missing if there isn't any. Edited February 29, 2024 by 250swb Link to post Share on other sites More sharing options...
williamj Posted February 29, 2024 Share #10 Posted February 29, 2024 You have a functional reason to add tape to the outside of your camera, not just an aesthetic reason. I’d grab the opportunity with both hands. Link to post Share on other sites More sharing options...
Michael Geschlecht Posted March 1, 2024 Share #11 Posted March 1, 2024 On 2/28/2024 at 9:06 PM, Michael Geschlecht said: Hello Tom, I think that some M3's came originally with felt strips on both sides of the film gate. It was the felt strip NOT being on the left side that I noticed. Best Regards, Michael 19 hours ago, 250swb said: Foam light sealing is often added in the search for a light leak but it doesn't mean it should be there by design. I see my MP came with a very thin sealing strip either side of the film gate (and the top of course) but I don't think any camera up to that point ever had them from the factory. In the case of my MP it may simply be there to stop a clatter or damage to the paint if the door slams shut? My M4-P for example doesn't need extra sealing and has never had it, and I think the difference is in the depth of the light baffle and the paint coating which on the older cameras was a thick heavy textured crackle finish. The OP could add some foam seal around the edge (you can buy it in sheets to cut to size, 1mm or 1.5mm thick) and see if it stops the leak and life could go on, except it's probably a sign of trouble elsewhere. I'm also sure camera techies add foam because it saves searching for a leak around the door and many of their customers believe it's missing if there isn't any. Hello Everybody, just to clarify things: When I bough my M3 at the Leica dealer, years before the M4 was introduced, it had a felt light seal on both sides of the film gate. Best Regards, Michael Link to post Share on other sites More sharing options...
rosshj Posted March 1, 2024 Author Share #12 Posted March 1, 2024 I’ve had a few M bodies and never seen light seals on the sides, but I’m sure it wouldn’t hurt. Maybe I’ll try that if I can’t figure out another solution. For now I’m running another roll through it and taping just half the back to see if I can narrow things down. 1 Link to post Share on other sites More sharing options...
Michael Geschlecht Posted March 1, 2024 Share #13 Posted March 1, 2024 (edited) Hello Ross, Welcome to the Forum. You have an "M" body with a light seal right now. Please look to the right of the winding spool in your Post #1 above. It is that approximately 4 cm/1.6 inch long. Thin, vertical thing. Sticking up a little bit. A little to the right of the winding spool. Best Regards, Michael Edited March 1, 2024 by Michael Geschlecht Link to post Share on other sites More sharing options...
George Collier Posted March 1, 2024 Share #14 Posted March 1, 2024 I had leaks on an M4-2 and an M4, but higher up the film, to the left of the aperture right along the frame edge and into the frame - with your pic as a reference. I was in Massachusetts and took it to Youxin Ye (he had worked on both cameras before). He looked at it and said that the back door was defective. He offered to replace it for I think $150 (I could return the door if it didn't work), and he put in a small amount of think black padding material in the light traps above and below the aperture. I didn't take him up on the back door, but tried the seal. Still leaked. Closer examination when I got home revealed that the back door hinge pin, far left at the top of the door was loose. This pin sits tightly in a hole, withdrawn by a spring loaded pull to remove the door (as you seem to have done for your picture above). If the pin becomes loose, it allows the door to not seat properly and leak. Youxin didn't say, but I think that was his conclusion. I don't see any material sealing mine and I eventually removed what Youxin put in, but my final solution is to cover the three edges of the door edge with a black graphic arts paper (but opaque) tape, low tack and replaced every 2 or 3 months. 1 Link to post Share on other sites More sharing options...
