ChampagneCharlie Posted February 21, 2024 Share #1 Posted February 21, 2024 Advertisement (gone after registration) Hi all, looking for some advice, please. How do you all deal with recording lens details in exif using an M11? I have 20 or so 50mm lenses which I'd, ideally, like to be able to record individually via the in-camera lens detection menu (rather than lumping them all under one or two entries). My current method relies on adding metadata post-import, which is tedious and unreliable. Any advice much appreciated. #firstworldproblems Link to post Share on other sites More sharing options...
Advertisement Posted February 21, 2024 Posted February 21, 2024 Hi ChampagneCharlie, Take a look here Lens Detail Recording in EXIF. I'm sure you'll find what you were looking for!
lct Posted February 21, 2024 Share #2 Posted February 21, 2024 Most of my 50mm lenses are either coded or hand-coded. If yours are not coded already, you may wish to hand-code them, which is easy to do with late VM and ZM lenses, thanks to a recessed part in their flange. This way the exif data will show the ID of the Leica lens corresponding to the code you chose. They won't show the real ID of the lens though. The only way to do this is to use software like File Multi Tool for Mac. Link to post Share on other sites More sharing options...
marchyman Posted February 21, 2024 Share #3 Posted February 21, 2024 4 hours ago, lct said: or hand-coded You can't code a ZM (or any non-Leica) lens to get correct metadata. You can get a focal length and maybe the aperture, but that's about it. I believe post processing is the only way to get accurate info into the metadata. With 20 or so 50 mm lenses I can see post processing becoming a burden, too. I don't have any good answers for ChampagneCharlie. Link to post Share on other sites More sharing options...
lct Posted February 21, 2024 Share #4 Posted February 21, 2024 Just a snap to show what is possible to do with the M11 and a hand-coded lens. Here a Nokton 50/1.5 SC v2 coded as Summilux 50/1.4 pre-asph. The 6-bit code painted on the flange of the lens is 000101. The exif data of the DNG file say: • Camera Model Name: Leica M11 • Lens ID: Summilux-M 1:1.4/50 • Exposure Program: Aperture-priority AE • Aperture Value: 8.0 • Shutter Speed Value: 1/180 • ISO Speed: 64 To correct the lens ID, if needed, suffice it to use software like File Multi Tool for Mac. This way, the lens ID will become, in my example, Voigtländer Nokton 50/1.5 SC v2. FWIW. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/389594-lens-detail-recording-in-exif/?do=findComment&comment=5050540'>More sharing options...
marchyman Posted February 22, 2024 Share #5 Posted February 22, 2024 22 hours ago, lct said: This way, the lens ID will become, in my example, Voigtländer Nokton 50/1.5 SC v2. FWIW. Yes. That works when you have a 1:1 relationship between your coding and the actual lens used. The process breaks when you have "20 or so 50mm lenses" because there are not 20 or so codings for 50mm lenses available. It looks to me like you'd have to note which lens was used for which images at time of use and then do the manual update to set lens ID, etc., in the metadata. As ChampagneCharlie said, that can be tedious and unreliable. Link to post Share on other sites More sharing options...
Henners Posted February 22, 2024 Share #6 Posted February 22, 2024 (edited) I guess if shooting RAW (so the lens corrections aren't baked in to the JPEG) you could code each lens to any lens and then once in lightroom select all of X lens and update the meta data to be correct. This way it would be much quicker to batch process each lens as long as you kept a lookup table so you know that the lens coded as a 90mm 2.8 lens is actually the Voigtlander 50mm f2 lens or whatever. Edited February 22, 2024 by Henners 1 Link to post Share on other sites More sharing options...
Henners Posted February 22, 2024 Share #7 Posted February 22, 2024 Advertisement (gone after registration) I can see the only way is to create a Lightroom plugin or use some kind of exif processing software that will do the fake lens conversions I mentioned previously, automatically on importing the photos. Like Al Brown says there doesn't seem to be any way to do it on the fly, only to try and make things easier when transferring to a computer. It can definitely be done with a marginally technical solution as long as it fits nicely in to the workflow. Link to post Share on other sites More sharing options...
lct Posted February 22, 2024 Share #8 Posted February 22, 2024 54 minutes ago, marchyman said: Yes. That works when you have a 1:1 relationship between your coding and the actual lens used. The process breaks when you have "20 or so 50mm lenses" because there are not 20 or so codings for 50mm lenses available. It looks to me like you'd have to note which lens was used for which images at time of use and then do the manual update to set lens ID, etc., in the metadata [...] I must have something like a dozen 50mm M lenses. Most of them are coded, a couple of them uncoded and the remaining ones hand-coded. Not that much of a problem really. Just to take an example, my VM 50/2.5 is coded as a Summarit 50/2.4, VM 50/1.5 SC v2 as a Summilux 50/1.4 pre-asph and ZM 50/2 as a Summicron 50/2. I can even recognize the latter which has not the same code number as my Summicron v4, v5 or apo. Link to post Share on other sites More sharing options...
evikne Posted February 22, 2024 Share #9 Posted February 22, 2024 I have used the LensTagger LR plugin to manually change to correct names on many lenses. It was quite easy to distinguish them from each other based on time and place and memory. I've never had as many as 20 lenses with the same focal length though! But once you get done with the job of renaming the lenses in previous images, get used to doing this procedure after each import, while you still remember well which lens you used. Link to post Share on other sites More sharing options...
250swb Posted February 22, 2024 Share #10 Posted February 22, 2024 On 2/21/2024 at 12:45 PM, ChampagneCharlie said: Hi all, looking for some advice, please. How do you all deal with recording lens details in exif using an M11? #firstworldproblems Remembering and looking at the photograph, just as people did before Exif files. Perhaps people had better recall back then???? Link to post Share on other sites More sharing options...
lct Posted February 22, 2024 Share #11 Posted February 22, 2024 23 minutes ago, 250swb said: Remembering and looking at the photograph, just as people did before Exif files. Perhaps people had better recall back then???? Or we had less years and lenses 😄 2 Link to post Share on other sites More sharing options...
adan Posted February 22, 2024 Share #12 Posted February 22, 2024 In my relatively brief period of using film Ms (2001-2006), if I needed to "record" the lens used (say, for comparisons/tests), I would simply snap a picture of the lens I was going to use for the next group of shots. Then, when I was going to change to the "comparison" lens, I would photograph IT, and then put it on the camera and take the pictures with it. Analog EXIF as a sequence of film exposures. 🤪 [picture of lens X]...mount lens X.... [picture with lens X #1] [picture with lens X #2] [picture with lens X #3] [picture with lens X #4] [picture of lens Y]...mount lens Y.... [picture with lens Y #1] [picture with lens Y #2] [picture with lens Y #3] [picture with lens Y #4].....etc. I've done the same thing occasionally (as in - once every 2-3 years!) with digital Ms - but that is obviously just an "aide-memoire," not actual EXIF data. Still requires EXIF editing afterwards. Alternatives - just fire a blank frame between lens changes, and keep a pen-and-paper notebook record of which lens was used oin what order. 😉 Just like Ansel Adams did: https://fineartamerica.com/featured/ansel-adams-photography-exposure-record-log-wingsdomain-art-and-photography.html .................... The only way the camera could record "bespoke EXIF" would be if Leica, out of the goodness of their hearts, added a "User Lens Entry" menu line to the manual lens selection list. It would still be cumbersome - requiring a menu-dive with every lens change, and likely significant typing (on the tiny LCD). But, in theory, something like: - Open lens selection menu - scroll to a hypothetical new top line in the list (between the 135s and the 16-18-21) reading "MANUAL LENS SPECIFICATION." - select that line - a virtual alphanumeric "keyboard" pops up on the LCD, same as for adding © info or changing default file/folder names). - type in, for example, "LEITZ 50MM ELMAR F/3.5 V2 SN 1234567" or "VOIGTLANDER 50 NOKTON V1 2002." Press "Done" or "Save" button. It is possible Leica could allow for "permanently" saving multiple such "personal" manual lens lines - but 20 would probably be pushing the limits of the amount of memory Leica would care to devote to that process. And a defect would be that there would be no recognizable automatic correction patterns (vignetting, color vignetting) available for such entries - which is the real technical purpose of Leica including lens EXIF at all. Enter "LEITZ 21MM SUPER-ANGULON F/3.4" or "VOIGTLANDER 15MM F/4.5 V1"- and one would still get purple and cyan stains on the pictures. To the camera and firmware, such a manual entry would simply be a random ASCII text string (no different, or more recognizable, than entering "AZR3-SK-//917&AXQ7"), and not data it could interpret and use. Link to post Share on other sites More sharing options...
pippy Posted February 22, 2024 Share #13 Posted February 22, 2024 (edited) On 2/21/2024 at 12:45 PM, ChampagneCharlie said: I have 20 or so 50mm lenses which I'd, ideally, like to be able to record individually...Any advice much appreciated... Pencil and Paper? Seriously; just take notes. Philip. Edited February 22, 2024 by pippy Link to post Share on other sites More sharing options...
ChampagneCharlie Posted February 23, 2024 Author Share #14 Posted February 23, 2024 16 hours ago, pippy said: Pencil and Paper? Seriously; just take notes. Philip. If that was intended to help, it didn't. Although it doesn't seem like that was your intent. Link to post Share on other sites More sharing options...
ChampagneCharlie Posted February 23, 2024 Author Share #15 Posted February 23, 2024 Thanks everyone for the suggestions. On the plus side, it looks like I'm not missing a simple solution to my simple issue. As Adan suggests, some form of user entry in one of the menus would be what i'm looking/wishing for to add in whether a particular shot is taken with a Xenon, Summar or some variation of the menu-listed lenses. LCT, i appreciate your thoughts- merci. Marchyman, I see you understand my pain :). Adan, the picture of the lens idea is a good one, given the lack of a proper solution- thank you. Al Brown, Evikine & Henners, good imput, much appreciated. Thanks again. 1 Link to post Share on other sites More sharing options...
ChampagneCharlie Posted February 23, 2024 Author Share #16 Posted February 23, 2024 18 hours ago, 250swb said: Remembering and looking at the photograph, just as people did before Exif files. Perhaps people had better recall back then???? Waste of time reponse. Link to post Share on other sites More sharing options...
pippy Posted February 23, 2024 Share #17 Posted February 23, 2024 14 minutes ago, ChampagneCharlie said: If that was intended to help, it didn't. Although it doesn't seem like that was your intent. I was being serious and, incidentally, it is always my intention to help. I have no idea of any camera where it would be possible to differentiate between 20 different 50mm lenses the majority of which will have no means of identifying itself to the camera body without inputting data that, in turn, could affect in-camera capture. Perhaps you know differently? I have a few 50mm lenses myself and, if using more than one on any given day, have worked out a system which works for me. P. Link to post Share on other sites More sharing options...
ChampagneCharlie Posted February 23, 2024 Author Share #18 Posted February 23, 2024 2 minutes ago, pippy said: I was being serious and, incidentally, it is always my intention to help. I have no idea of any camera where it would be possible to differentiate between 20 different 50mm lenses the majority of which will have no means of identifying itself to the camera body without inputting data that, in turn, could affect in-camera capture. Perhaps you know differently? I have a few 50mm lenses myself and, if using more than one on any given day, have worked out a system which works for me. P. Then I'm I'm happy to be corrected, and thank you for your input. However, I'd prefer a better solution than maintaining multiple decades worth of 'pencil and paper' records. I don't think it's totally unreasonable of me to wish my 10k camera body to be able to accurately record the lens that I'm taking a particular image with, especially if said lens is made by said body manufacturer. Maybe in M12... 1 Link to post Share on other sites More sharing options...
pippy Posted February 23, 2024 Share #19 Posted February 23, 2024 18 minutes ago, ChampagneCharlie said: ...I don't think it's totally unreasonable of me to wish my 10k camera body to be able to accurately record the lens that I'm taking a particular image with, especially if said lens is made by said body manufacturer......Maybe in M12... I can't see how anything which Leica might do with a future body would change the situation. As marchyman said back in post #6; 21 hours ago, marchyman said: ...The process breaks when you have "20 or so 50mm lenses" because there are not 20 or so codings for 50mm lenses available... Modern Leica lenses, of course, pose no problem. It is also possible to have some of the older non-6-bit-coded lenses modified by Leica by changing the rear mounting flange. There is, however, no possibility of accurately post-coding many of Leicas own 50s from the past such as an LTM 50mm f3.5 Elmar; there have simply been too many different models produced over the last 100 years for it to be worth Leica's time and effort. Nor, stating the obvious, can any non-Leica 50 be coded accurately in terms of profile. It is possible to manually select a profile for any one particular lens and, if this profile is always used for the same lens, this makes identifying that lens straightforward. For example I don't have a 50mm f1.4 pre-ASPH Summilux but do have a 1953 50mm f1.5 Summarit so when using the latter I manually select the profile for the former. Similarly I can select from a choice of three non-coded profiles for each of my 35mm lenses so can also tell what was used and when. Once the DNG files have been downloaded into a folder I will name it (as an example) "MM 35mm LLL-8 Element+Yellow" or "MD 35mm Summilux+Pola" (etc...etc...) for long-term recording of this info. But there are not 20-odd 50mm lens profiles in the menu from which you might choose and if you can't physically tell the camera which lens is fitted how can the camera know? One solution might be to utilise those profiles which might not be used in day-to-day shooting; stuff like the various 75s, 90s and 135s. If snapping with a 50mm f1.8 Canon Serenar you might set it manually from the menu as an 11817 (assuming you don't also have an 11817). A 50 f2.8 Elmar might be set as an original 11820 Noctilux (assuming you don't have...) and so on and so on until you have input all 20+ lenses under different profiles. Having noted which was which you would be able to dial-in each lens with every change according to these notes. Electing to use profiles for these longer lenses would also tend to not interfere too much with the lens' native rendering. Apart from that? I can't see any other way of selecting 20+ profiles for uncoded lenses. Good luck in finding your own system. P. 1 Link to post Share on other sites More sharing options...
lct Posted February 23, 2024 Share #20 Posted February 23, 2024 43 minutes ago, pippy said: A 50 f2.8 Elmar might be set as an original 11820 Noctilux ... or a 50/2.8 Elmar-M 😉 1 Link to post Share on other sites More sharing options...
