brickftl Posted February 14, 2024 Author Share #21 Posted February 14, 2024 Advertisement (gone after registration) 3 minutes ago, RobW0 said: I have not had the lens very long. I have been happy with what little I have used it. It is a good zone focus lens not being rf coupled. I like the indents for the different focus points. I used the 35/135 adapter because that is the same frame lines that are activated by a 24mm lens. The Rayqual is available here: https://shop.cameraquest.com/leica-screw-mount-adapters/rayqual-24/35/135-6-bit-coded-leica-screw-mount-type-iii-leica-screw-mount-lens-to-leica-m-body-adapt okay, but just to be clear - you say that the 35/135 adapter shows frame lines that are activated by a 24mm lens. However the skopar is a 25mm lens. Link to post Share on other sites More sharing options...
Advertisement Posted February 14, 2024 Posted February 14, 2024 Hi brickftl, Take a look here what adapter to use screw in lens? . I'm sure you'll find what you were looking for!
RobW0 Posted February 14, 2024 Share #22 Posted February 14, 2024 1 minute ago, brickftl said: okay, but just to be clear - you say that the 35/135 adapter shows frame lines that are activated by a 24mm lens. However the skopar is a 25mm lens. There are no frame lines for the 24mm in the M10. I believe the M8 had 24mm frame lines. The 24mm is about the same as a 25mm. The recommended lens code for this lens is the Elmar M 24mm f/3.8 ASPH #11648. If you mount this lens the 35/135 frame lines are what is displayed. The full RF window is a very ruff approximation for the 25mm. 1 Link to post Share on other sites More sharing options...
Alberti Posted February 14, 2024 Share #23 Posted February 14, 2024 I have had the Skopar since ages - I started with it on the M6. On the M8 it was good. On the M240 it just performed good and very sharp. I have pictures that are just jaw dropping for this lens. In fact, its sharpness is great but I am sorry to say I sold it due to the fact that it didn't have a follow-focus on the RF. Then F/8 & 3 m for instance is great for the snapshot style. It gives great performance for the money. You can code it as a 25mm. no problems there. Link to post Share on other sites More sharing options...
UliWer Posted February 14, 2024 Share #24 Posted February 14, 2024 When the adapters were introduced for the Leica, the rule of thumb for a lens wider than the frames in the viewfinder was to use the largest frame. That means an 28/90 adapter would be the one for a 25mm lens - though all others would work in principle as well. As those with 28/90 (from Leitz) regularly don't have the cutouts (very rare exceptions), you shouldn't have any problems with them. Link to post Share on other sites More sharing options...
RobW0 Posted February 14, 2024 Share #25 Posted February 14, 2024 1 hour ago, UliWer said: When the adapters were introduced for the Leica, the rule of thumb for a lens wider than the frames in the viewfinder was to use the largest frame. That means an 28/90 adapter would be the one for a 25mm lens - though all others would work in principle as well. As those with 28/90 (from Leitz) regularly don't have the cutouts (very rare exceptions), you shouldn't have any problems with them. I guess it is a matter of preference. I consider it a 24mm so the 35/135 like a 24mm lens would have. If it was the 21mm Skopar then I would use the 28/90 like a 21mm lens would have. Link to post Share on other sites More sharing options...
