Qfan Posted February 6, 2024 Author Share #21 Posted February 6, 2024 Advertisement (gone after registration) 4 hours ago, ayamuz said: The best way to achieve this, probably, is to use exposure compensation assigning it to the thumbwheel. Setting the dial to -1 or -2 is usually enough to prevent the camera from overriding the SS. Thanks for your feedback. I will test by creating a User Profile for -1 is a good way to check if the camera will respect the Minimum SS all the time when shooting this way. A downside is constantly underexposing may not be good idea where ETTR is required. Link to post Share on other sites More sharing options...
Advertisement Posted February 6, 2024 Posted February 6, 2024 Hi Qfan, Take a look here How to overcome Q3 going below set Minimum Shutter Speed?. I'm sure you'll find what you were looking for!
Qfan Posted February 6, 2024 Author Share #22 Posted February 6, 2024 (edited) Just a quick summary of all the ideas so far: 1. Different User Profiles 2. EC -1 or -2 3. Completely manual Anything else? Edited February 6, 2024 by Qfan Link to post Share on other sites More sharing options...
Le Chef Posted February 6, 2024 Share #23 Posted February 6, 2024 17 minutes ago, Qfan said: Anything else? Shutter Priority. 1 Link to post Share on other sites More sharing options...
SrMi Posted February 7, 2024 Share #24 Posted February 7, 2024 2 hours ago, Qfan said: Just a quick summary of all the ideas so far: 1. Different User Profiles 2. EC -1 or -2 3. Completely manual Anything else? As I understand you want to achieve the following: - set min shutter speed and max ISO - once max ISO is reached, do not lower shutter speed in order to underexpose to preserve highlights. - there is no need to underexpose to preserve highlights if the max ISO setting has not be reached. 1 Link to post Share on other sites More sharing options...
Qfan Posted February 7, 2024 Author Share #25 Posted February 7, 2024 5 minutes ago, SrMi said: As I understand you want to achieve the following: - set min shutter speed and max ISO - once max ISO is reached, do not lower shutter speed in order to underexpose to preserve highlights. - there is no need to underexpose to preserve highlights if the max ISO setting has not be reached. That’s true, but I also want to keep noise reasonable by not going beyond 3200-6400, since I have a slow computer. Q3 took out a big chunk of savings so upgrading computer is not an option right now so I can’t let ISO float to stratosphere 🤣 Link to post Share on other sites More sharing options...
SrMi Posted February 7, 2024 Share #26 Posted February 7, 2024 7 minutes ago, Qfan said: That’s true, but I also want to keep noise reasonable by not going beyond 3200-6400, since I have a slow computer. Q3 took out a big chunk of savings so upgrading computer is not an option right now so I can’t let ISO float to stratosphere 🤣 But your solution will not keep the noise reasonable! The only way to keep the noise from going too high is to allow shutter speed to change below the min value. Link to post Share on other sites More sharing options...
Qfan Posted February 7, 2024 Author Share #27 Posted February 7, 2024 Advertisement (gone after registration) 31 minutes ago, SrMi said: But your solution will not keep the noise reasonable! The only way to keep the noise from going too high is to allow shutter speed to change below the min value. My understanding is as long as I compose my image in a way that I don’t need to lift the shadows in post, then I don’t need keep lowering SS once max Auto ISO is reached, right? I just thought of another approach, use highlight metering but EC up instead of EC down. Link to post Share on other sites More sharing options...
SrMi Posted February 7, 2024 Share #28 Posted February 7, 2024 1 minute ago, Qfan said: My understanding is as long as I compose my image in a way that I don’t need to lift the shadows in post, then I don’t need keep lowering SS once max Auto ISO is reached, right? If you can set exposure at a fixed minimum shutter limit speed that does not require lifting in the post, then you can set the same when the minimum shutter speed is not fixed once the ISO limit is reached (by applying negative EC). Link to post Share on other sites More sharing options...
Qfan Posted February 7, 2024 Author Share #29 Posted February 7, 2024 (edited) 32 minutes ago, SrMi said: If you can set exposure at a fixed minimum shutter limit speed that does not require lifting in the post, then you can set the same when the minimum shutter speed is not fixed once the ISO limit is reached (by applying negative EC). Yes that’s true. I think this conclusion has been reached after exploring eveythign in this thread. As other posters have said, both are not elegant because they require manual intervention at some point. Having an algorithm or toggle that stops the camera from going lower than “minimum SS” is the ultimate but sadly it doesn’t seem it’s the norm for camera manufacturers. Edit: but apparently Canon is smart enough to offer this option according to another post I read in a related thread! Now there is hope other camera manufacturers will “catch up” with Canon in future 😅 Edited February 7, 2024 by Qfan Link to post Share on other sites More sharing options...
Casey Jefferson Posted February 7, 2024 Share #30 Posted February 7, 2024 I own the Q2 instead and...If it's night time and I absolutely don't want the shutter speed to go any slower and I know the camera won't be hitting ISO100 (which is 99.99% of the case even if it's wide open), I just set the desire shutter speed manually. Not the most elegant solution but there are plenty of photographer appreciate the camera slowing the shutter speed upon reaching the ISO ceiling. 1 Link to post Share on other sites More sharing options...
thegobi Posted February 8, 2024 Share #31 Posted February 8, 2024 On 2/7/2024 at 12:25 PM, Qfan said: Yes that’s true. I think this conclusion has been reached after exploring eveythign in this thread. As other posters have said, both are not elegant because they require manual intervention at some point. Having an algorithm or toggle that stops the camera from going lower than “minimum SS” is the ultimate but sadly it doesn’t seem it’s the norm for camera manufacturers. Edit: but apparently Canon is smart enough to offer this option according to another post I read in a related thread! Now there is hope other camera manufacturers will “catch up” with Canon in future 😅 Olympus/OM does as well, but you have to dig for it! (In the flash menu if memory serves) 1 Link to post Share on other sites More sharing options...
David Wien Posted February 8, 2024 Share #32 Posted February 8, 2024 23 hours ago, Casey Jefferson said: I own the Q2 instead and...If it's night time and I absolutely don't want the shutter speed to go any slower and I know the camera won't be hitting ISO100 (which is 99.99% of the case even if it's wide open), I just set the desire shutter speed manually. Not the most elegant solution but there are plenty of photographer appreciate the camera slowing the shutter speed upon reaching the ISO ceiling. I think we are still not used to realising that sensors built in the past 5-10 years work quite well at amazingly high ISO settings, and that almost any noise can be neutralized by using raw files and cliking a button in pp software. David 1 Link to post Share on other sites More sharing options...
SrMi Posted February 8, 2024 Share #33 Posted February 8, 2024 Before this thread, I had no idea why anyone would set an Auto-ISO limit lower than the max ISO. Now, I understand that it can be used to specify maximum allowable noise. To work as intended, the shutter speed must decrease once the max ISO value is reached; otherwise, the noise will increase. Link to post Share on other sites More sharing options...
ColdShower Posted February 8, 2024 Share #34 Posted February 8, 2024 (edited) This is an issue with the M digitals as well. When shooting in aperture priority the camera choses high iso and high shutter speeds some times, when in reality a better image quality would be to lower both. The solution is to go manual. Edited February 8, 2024 by ColdShower 2 Link to post Share on other sites More sharing options...
Pindy Posted March 31, 2024 Share #35 Posted March 31, 2024 Qfan, I just wanted to chime in to say I feel your pain and recognize a kindred spirit. I can see a case for sacrificing the auto ISO threshold so that your automatic shutter speed limits are never transgressed; it is a matter of your priorities. Just saying to switch SS to manual ignores that a second later, lighting conditions could be good enough to increase your shutter speed to an even safer speed, if stopping motion is your goal. This is why I don’t accept that advice uncritically. In Aperture Priority there are two legs of the exposure triangle with which to compromise so why not make it the photographer’s choice? 1 Link to post Share on other sites More sharing options...
David Wien Posted April 1, 2024 Share #36 Posted April 1, 2024 On 2/8/2024 at 4:40 PM, ColdShower said: This is an issue with the M digitals as well. When shooting in aperture priority the camera choses high iso and high shutter speeds some times, when in reality a better image quality would be to lower both. The solution is to go manual. I often find that the Q3 makes strange exposure decisions. On the other hand, my car, a Mazda MX5, often recommends changing to a higher gear than I would normally select. When I take the advice, it never results in the engine stalling! Seriously, though, there are times when I seriously contemplate going fully manual with the Q3 — except for focussing: the arrival of auto focussing improved my success rate immensely! David 3 Link to post Share on other sites More sharing options...
Qfan Posted April 1, 2024 Author Share #37 Posted April 1, 2024 On 3/31/2024 at 2:11 PM, Pindy said: Qfan, I just wanted to chime in to say I feel your pain and recognize a kindred spirit. In Aperture Priority there are two legs of the exposure triangle with which to compromise so why not make it the photographer’s choice? Thanks for voicing your support. With so many responses echoing the same pain, it's quite clear to me that Leica should further improve Q3's behavior on this issue. 1 Link to post Share on other sites More sharing options...
Qfan Posted April 1, 2024 Author Share #38 Posted April 1, 2024 13 hours ago, David Wien said: Seriously, though, there are times when I seriously contemplate going fully manual with the Q3 — except for focussing: the arrival of auto focussing improved my success rate immensely! David I have gone full manual already just to stop the Q3 from going below my desired minimum shutter speed. Unfortunately, this introduces other issues that I and others have mentioned earlier in this thread. 1 Link to post Share on other sites More sharing options...
SrMi Posted April 2, 2024 Share #39 Posted April 2, 2024 On 2/6/2024 at 11:17 PM, Qfan said: Thanks for your feedback. I will test by creating a User Profile for -1 is a good way to check if the camera will respect the Minimum SS all the time when shooting this way. A downside is constantly underexposing may not be good idea where ETTR is required. ETTR makes sense only at base ISO. Link to post Share on other sites More sharing options...
SrMi Posted April 2, 2024 Share #40 Posted April 2, 2024 8 hours ago, Qfan said: I have gone full manual already just to stop the Q3 from going below my desired minimum shutter speed. Unfortunately, this introduces other issues that I and others have mentioned earlier in this thread. Why not raise the Auto-ISO value to the maximum? 1 Link to post Share on other sites More sharing options...
