Welcome to the forum!
And congratulations for your M5. It is a very unique Leica M model, with many features that no other M before or after the M5.
You did mount a lens did you?
And you need to cock the shutter/advance the film before it becomes active.
Of course the light meter also needs a proper battery to work.
Edited by dpitt
Very good! Note that Wein cells have limited life once exposed to air. They have fair power for many measurements, but if you store the camera for a while don't count on the battery. Of course, it's best to store any film camera with the battery removed. One leaked in one of my Leicas and ruined the meter circuit board.
Your best bet is to either send the body to DAG Camera to have the meter converted to 1.5v batteries, or you can by a Kanto converter 1.55v to 1.35v  that allows you to use modern 1.55 volt SR 43 batteries as a long-term solution.  Welcome to the wonderful world of the M5.   Remember not to leave the shutter tensioned when you set the camera on the shelf, and remember to NOT touch the shutter release button until you're ready to make the exposure or the meter cell won't stay in the center of the frame.  Past those caveats, once you learn how to meter with the body, you'll love it!
Hello Pierre Luc,
Welcome to the Forum.
Sometimes if the ASA/DIN dial on the TOP of the camera is set at too high or too low a position then the moving needle stays all of the way to 1 side or the other.
The ASA/DIN dial on the BACK of the camera is only a reminder of what has been set on the TOP dial. The TOP dial actually controls the ASA/DIN setting.
ALSO: If you pull the frame selector under the VIEWFINDER window all of the way AWAY from the lens mount: The needle should move to the battery check position.
Best Regards,
Michael
Try setting the ASA/DIN dial on the TOP of the camera to 100/21 and then see what happens
