osroubek Posted December 15, 2023 Share #1 Posted December 15, 2023 (edited) Advertisement (gone after registration) I’m sure people are aware of this method but I finally tried it for the first time. I attached my M11-P to a monopod, pre focused, and then inverted it upside down holding the camera close to the ground and using the Fotos app to adjust the orientation and also see the image in the correct orientation and then take the exposure. To get just a few inches off the ground with a flippy screen you would still have to crouch very low or sit on the ground. This seems like a good alternative with no strain on the back, but an extra piece of gear is needed. Carrying the camera over the shoulder though is not too bad for a short excursion. Taken with 35/1.4 Summilux Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited December 15, 2023 by osroubek 6 2 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/385895-shooting-low-to-the-ground/?do=findComment&comment=4942959'>More sharing options...
Advertisement Posted December 15, 2023 Posted December 15, 2023 Hi osroubek, Take a look here Shooting low to the ground. I'm sure you'll find what you were looking for!
jaapv Posted December 15, 2023 Share #2 Posted December 15, 2023 Just a tip. It can be easier in some cases not to use a monopod which is a bit unwieldy but to reverse the center column of a tripod. 1 Link to post Share on other sites More sharing options...
Cronilux Posted December 15, 2023 Share #3 Posted December 15, 2023 Usually, using live view in such a case is sufficient enough. Link to post Share on other sites More sharing options...
lct Posted December 15, 2023 Share #4 Posted December 15, 2023 1 hour ago, Cronilux said: Usually, using live view in such a case is sufficient enough. +1 but i had to get down on one knee here. Ouch my arthrosis (M11 + Skopar 21/4). Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 4 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/385895-shooting-low-to-the-ground/?do=findComment&comment=4943167'>More sharing options...
Olaf_ZG Posted December 16, 2023 Share #5 Posted December 16, 2023 The monopod is also great to create drone like views. Especially with a fe 21mm lens, you can get nice images. Used to this with the selftimer… Link to post Share on other sites More sharing options...
ianforber Posted December 16, 2023 Share #6 Posted December 16, 2023 I have a small, light Gitzo monopod that has a strap with a clip on it so easy to attach to a belt when not using. I’ve never tried this method but will give it a go. I also have the Leitz mini tripod so I suppose that or any other small tripod would do the trick but it would probably need me to bend over for longer to adjust angle of view and then lift it up while finished. Link to post Share on other sites More sharing options...
BillCB Posted December 30, 2023 Share #7 Posted December 30, 2023 Advertisement (gone after registration) My knees really like the tilting Visoflex 2! 1 Link to post Share on other sites More sharing options...
