Matlock Posted July 20, 2023 Share #21 Posted July 20, 2023 Advertisement (gone after registration) 11 hours ago, dpitt said: Back to OP... I noticed that any soft release or cable release that works on my vintage M's will not work on the digital M's starting from M8, and the other way around. I did not know that modern M film bodies follow the old vintage bodies, but it seems the M-A is the same as my M3 in that aspect. Interesting, but not my experience (I don't use a soft release but I tried one with absolutely no problems on modern Leica's, I also tried a variety of cable releases, again no problems) Link to post Share on other sites More sharing options...
Advertisement Posted July 20, 2023 Posted July 20, 2023 Hi Matlock, Take a look here Soft release issue. I'm sure you'll find what you were looking for!
250swb Posted July 20, 2023 Share #22 Posted July 20, 2023 The only cable release I have that fits absolutely everything I have, all my Leica's from M2 to MP and MP, medium format, vintage cameras and shutters etc. is an old Gitzo cable release with a very short fine thread. Any other cable release that works has to be stored with the camera so as not to separate them. So it's not just a problem with soft releases. Link to post Share on other sites More sharing options...
Knipsknecht Posted July 20, 2023 Share #23 Posted July 20, 2023 I tried several soft release buttons, but I came to the conclusion that they are cumbersome and just add unnecessary point of failure to the camera. Sure, they look cool, but they create more problems than they solve. Link to post Share on other sites More sharing options...
wattsy Posted July 20, 2023 Share #24 Posted July 20, 2023 (edited) Some cable releases have a tapered thread so they work with a range of thread sizes (obviously within a reasonable limit). I have a Leica branded cable release that I've had for 20 years and it has worked fine with everything from M6TTL to M-A via the various digital Ms I've owned too. Edited July 20, 2023 by wattsy 1 Link to post Share on other sites More sharing options...
LocalHero1953 Posted July 20, 2023 Share #25 Posted July 20, 2023 Mmmmm, soft releases....... I must talk to my welfare director 1 1 Link to post Share on other sites More sharing options...
Marc B-C Posted July 20, 2023 Share #26 Posted July 20, 2023 I used to have a soft release on my Fuji X100f, however, it became slightly pressed when in the camera bag. This was causing battery drain (even thought the camera was switched off. Once I removed it, there was no issue. Never had one ever since and do not miss them. 3 Link to post Share on other sites More sharing options...
awirstam Posted April 27, 2024 Share #27 Posted April 27, 2024 Advertisement (gone after registration) Is it Not possible do half press with a soft release button. The one I have can’t half press on my m7. so I can’t use the exposure lock with the soft release 1 Link to post Share on other sites More sharing options...
stevesurf Posted September 23, 2024 Share #28 Posted September 23, 2024 On 4/27/2024 at 2:49 PM, awirstam said: Is it Not possible do half press with a soft release button. The one I have can’t half press on my m7. so I can’t use the exposure lock with the soft release Definitely do not use a soft shutter release or release adapter that uses a “plunger” on an M7. Mine had to make a trip to Wetzler because of it. The top plate somehow becomes loose and is a difficult repair. Link to post Share on other sites More sharing options...
Greenhilltony Posted September 23, 2024 Share #29 Posted September 23, 2024 I tried a soft release on my M4 and a few days later I took it off and never returned. Because on those meter-less Ms, the shutter release does not have the half-stop mechanism, which makes it quite easy to trigger accidentally. I had times triggering the shutter when I carried my M4 across my body and squatted down, or when I lifted the straps from my shoulder and transferred it to the front, it hit my bag and fired. Using the finger knuckle to squeeze into the shutter release collar is a great way to fire the shutter with minimum vibrations. Link to post Share on other sites More sharing options...
250swb Posted September 23, 2024 Share #30 Posted September 23, 2024 (edited) 3 hours ago, stevesurf said: Definitely do not use a soft shutter release or release adapter that uses a “plunger” on an M7. Mine had to make a trip to Wetzler because of it. The top plate somehow becomes loose and is a difficult repair. If the shutter release button has a screw thread in the middle (as does the M7) it is there to take either a cable release which is basically a 'plunger' or a soft release which is basically a spacer. Indeed the M7 manual states this, my underlining "Shutter release Three-step: Power – Metering memory-lock (for aperture priority mode) – Release. Integrated standard thread for cable release." If something has happened to your M7 it will be a fault in using the accessory or a faulty camera. Edited September 23, 2024 by 250swb Link to post Share on other sites More sharing options...
kivis Posted April 9 Author Share #31 Posted April 9 On 7/19/2023 at 10:05 AM, kivis said: I have noticed that many of my soft releases (I have a whole bunch) will not fit on my M-A but will fit on my M240. On the M-A they just will not screw in. But this works on all my cameras. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Does not work on my M3. Link to post Share on other sites More sharing options...
