patrickcolpron Posted March 19, 2024 Share #181 Posted March 19, 2024 Advertisement (gone after registration) 59 minutes ago, geoffnik said: 73255745476__8D29AB5C-FFA2-485E-98F8-3EA7D4091521.MOV 527.82 kB · 1 download That's fine, bought mine a few days after it was announced. That "wobble" is not a wobble or a wobbly aperture ring, it doesn't "jiggle" on its own. In my experience with modern Leica lenses, they all have play in their aperture ring, it just seems more pronounced on the Steel Rim reissue than it is on other similar lenses, such as the 35 FLE V1. It does feels more extreme on the reissue because we have tabs we can "jiggle" it with. That "wobble" hasn't changed since I bought it, and the lens has worked flawlessly ever since. It sure is disappointing since original Steel Rim aperture rings have no play to this day, and ... you don't expect that from a Leica lens, or any lens for that matter at this price point but, I assure you, that aperture ring play is really not unlike other modern Leica M lenses. I wouldn't lose sleep over it. 3 2 Link to post Share on other sites More sharing options...
Advertisement Posted March 19, 2024 Posted March 19, 2024 Hi patrickcolpron, Take a look here Summilux-M 35mm f/1.4 11301 "STEEL RIM" reissue QC problems. I'm sure you'll find what you were looking for!
algrove Posted March 22, 2024 Share #182 Posted March 22, 2024 On 6/18/2023 at 3:21 AM, Gobert said: Bad news. Most of the issues you expect with cheap Chinese lenses, not with German quality. The vignetting design flaw might be the work of an engineer just from school. Maybe they farmed the assembly of this lens out to China as an experiment. Link to post Share on other sites More sharing options...
algrove Posted March 22, 2024 Share #183 Posted March 22, 2024 On 11/13/2023 at 8:26 PM, Qlan said: Just got my 35mm Steel Rim back from Germany for a back focus issue. Tried it in the Leica store where they shipped it to, and I as pessimistically expected, it still back focuses, in the exact same way as before. The Leica store owner tried it, and thankfully agreed that it indeed back focuses. The lens they have on display is good though. They'll try to find a solution, hopefully not another trip to Germany without any confidence it will be fixed correctly. What a joke this is. Hiring and training practices and/or too much good bier at lunchtime. Link to post Share on other sites More sharing options...
69xchange Posted March 22, 2024 Share #184 Posted March 22, 2024 Waiting for someone to complain about the limited 200pc black reissue SR quality control here. 1 4 Link to post Share on other sites More sharing options...
Al Brown Posted March 22, 2024 Author Share #185 Posted March 22, 2024 (edited) 3 hours ago, 69xchange said: Waiting for someone to complain about the limited 200pc black reissue SR quality control here. Gosh, I *DO* hope Leica took a hint and fixed everything. Let's go over all the initial problems again just to be sure: - Loose, not snug lens cap that does not stay on - Stiff focusing ring near infinity - Wobbly aperture ring that rattles - Some samples are not calibrated/aligned with rangefinder (back or front focus) - The use of filter with screw-in threaded lens hood leads to undesirable vignetting – design flaw, a problem recognized by Leica with a solution - The clip-on hood does not stay on the lens/falls of at the slightest touch Edited March 22, 2024 by Al Brown 2 Link to post Share on other sites More sharing options...
algrove Posted March 23, 2024 Share #186 Posted March 23, 2024 18 hours ago, 69xchange said: Waiting for someone to complain about the limited 200pc black reissue SR quality control here. I am afraid too many will never be used and as such those will never know to complain about problems. Their only problem will be too carefully cut the white tape sealing the outer box.😀 1 1 Link to post Share on other sites More sharing options...
algrove Posted March 23, 2024 Share #187 Posted March 23, 2024 Advertisement (gone after registration) BTW, my SR had been prefect except for the lens hood with vignettes while using event thin filter. Just got the replacement and STRANGELY Leica made it narrower, but used the same part #12486 as the first hood.🤨 Link to post Share on other sites More sharing options...
RexGig0 Posted March 23, 2024 Share #188 Posted March 23, 2024 I consider the threaded hood, that I received with my Re-Edition Steel Rim, to simply be a collectible accessory, one of the things to keep inside the original box, in pristine condition, to be passed along to the next owner. The hood that I received has the physical appearance of the early version, that is known to vignette, when used with a threaded hood. At the time I ordered the lens, I placed an order with Rainbow Imaging’s eBay store, for a very inexpensive threaded hood that reportedly does not produce vignetting, but, I have not yet used it, either. The plastic hood, that is packaged with the Re-Edition Steel Rim, has sufficed. (Mine does stay nicely in place.) 1 Link to post Share on other sites More sharing options...
geoffnik Posted March 29, 2024 Share #189 Posted March 29, 2024 (edited) On 3/19/2024 at 5:21 PM, patrickcolpron said: That's fine, bought mine a few days after it was announced. That "wobble" is not a wobble or a wobbly aperture ring, it doesn't "jiggle" on its own. In my experience with modern Leica lenses, they all have play in their aperture ring, it just seems more pronounced on the Steel Rim reissue than it is on other similar lenses, such as the 35 FLE V1. It does feels more extreme on the reissue because we have tabs we can "jiggle" it with. That "wobble" hasn't changed since I bought it, and the lens has worked flawlessly ever since. It sure is disappointing since original Steel Rim aperture rings have no play to this day, and ... you don't expect that from a Leica lens, or any lens for that matter at this price point but, I assure you, that aperture ring play is really not unlike other modern Leica M lenses. I wouldn't lose sleep over it. I did post the video of the ‘play in the aperture ring’ to Leica and had this response. I have reviewed the video together with our technicians and they confirmed that this behaviour is normal for this lens. The Leica Summilux-M 35 f/1.4 follows a classic product concept in order to preserve the special character and individuality of the lens. The top priority for our engineers was to come as close as possible to the original from 1961, with a barely changed vintage look and an identical optical design. Accordingly, mechanical tolerances can deviate from our modern and otherwise usual standards, but this does not mean any loss of quality or functional restrictions. Edited March 29, 2024 by geoffnik 1 Link to post Share on other sites More sharing options...
FrozenInTime Posted March 29, 2024 Share #190 Posted March 29, 2024 12 minutes ago, geoffnik said: Accordingly, mechanical tolerances can deviate from our modern and otherwise usual standards, but this does not mean any loss of quality or functional restrictions. I call that bullshit; anything manufactured today will have been redrawn in 3D CAD tools and measurements passed to CNC machines. 1 1 Link to post Share on other sites More sharing options...
rouge_homme Posted September 1, 2024 Share #191 Posted September 1, 2024 I just picked up a brand new 35mm SR ( manufactured 05/24). I shot it on my M11P for a few hours today and love the size, rendering and character, however, I can’t help but feel that the overall build quality feels somewhat disappointing when compared to my other lenses (35 FLE V2 / 50mm APO). Notably, there is some play in the aperture ring (similar to what was shown in the video provided by someone above) and the focus throw has a slight resistance approaching infinity. Reading this thread and others, these seem to be common concerns, but are they just characteristic of this lens? Or should I be sending it back for a replacement? Link to post Share on other sites More sharing options...
patrickcolpron Posted September 1, 2024 Share #192 Posted September 1, 2024 3 hours ago, rouge_homme said: ..., there is some play in the aperture ring (similar to what was shown in the video provided by someone above) and the focus throw has a slight resistance approaching infinity. Reading this thread and others, these seem to be common concerns, but are they just characteristic of this lens? Or should I be sending it back for a replacement? I have picked mine up the day it was available for purchase when it was announced. There is a slight play in the aperture ring but the 35 FLE has the same play and most Leica M lenses for that matter, never made me lose sleep over it. Just that we have big grips for our fingers on the SR so it seems worse, it isn't. The slight resistance near infinity has never troubled me in use. I don't want to send a lens back I paid good money for which I won't be able to use for 4 to 5 months while it is serviced. At the price they sell those things it should be perfect, could he worse, at least there is no electronics in it, there will be no freeze up issue with it 😉 Just enjoy the lens and don't worry about it. Link to post Share on other sites More sharing options...
rouge_homme Posted September 2, 2024 Share #193 Posted September 2, 2024 9 hours ago, patrickcolpron said: At the price they sell those things it should be perfect, could he worse, at least there is no electronics in it, there will be no freeze up issue with it 😉 Just enjoy the lens and don't worry about it. Thanks for the feedback and yes, compared to my occasionally freezing M11, it's not so bad. 😅 But as you say, it's still disappointing for a lens at this price point. 1 Link to post Share on other sites More sharing options...
mada9909 Posted September 2, 2024 Share #194 Posted September 2, 2024 On 3/23/2024 at 1:39 AM, algrove said: Maybe they farmed the assembly of this lens out to China as an experiment. It seems China is often blamed, even when discussing the poor quality of a German product. I purchased Steel Rim in Apr this year, noticed that the manufacturing date of this lens was in Jan 2024. so far, I have had no issues with this lens. I recently purchased a lens from LLL, China. I do think it truly demonstrated top-notch craftsmanship... Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/378430-summilux-m-35mm-f14-11301-steel-rim-reissue-qc-problems/?do=findComment&comment=5528402'>More sharing options...
