LCL999 Posted January 13, 2024 Share #41 Posted January 13, 2024 Advertisement (gone after registration) I tried an infra-red filter on my Q2M but the results were not very good. The built-in IR filter (to cut IR) is very effective. So I'll stick with my old M8 ( an early one without the IR cut) which I bought just for IR, Works well. Link to post Share on other sites More sharing options...
Advertisement Posted January 13, 2024 Posted January 13, 2024 Hi LCL999, Take a look here Filters for Q3 . I'm sure you'll find what you were looking for!
jaapv Posted January 13, 2024 Share #42 Posted January 13, 2024 Actually the M8 does have an IR cut sensor filter about 70%. Link to post Share on other sites More sharing options...
DrPixel Posted February 17, 2024 Share #43 Posted February 17, 2024 On 8/20/2023 at 12:47 PM, IanrM said: Just to clarify matters: The Urth kit I bought comprises a filter ring that screws on to the lens and four magnetic filters (which are only magnetic and don't have screw threads) It also appears to me that it would be quite difficult for the UV magnetic filter to fall off as its being stopped by the lens hood. Hi Ian. I'm thinking of getting the same Urth kit for my Q3. Did you get the 49mm filter size or to reduce the risk of vignetting, did you jump up to the 52mm filter size? If you stuck to 49mm, presume no issues? Cheers. Link to post Share on other sites More sharing options...
