lct Posted May 8, 2023 Share #21 Posted May 8, 2023 Advertisement (gone after registration) I would make sure that lens detection auto has been selected in your user profiles given that all your lenses are coded. Link to post Share on other sites More sharing options...
Advertisement Posted May 8, 2023 Posted May 8, 2023 Hi lct, Take a look here M11M and User Profiles not persisting . I'm sure you'll find what you were looking for!
digitalfx Posted May 8, 2023 Author Share #22 Posted May 8, 2023 IMG_5552.mov Link to post Share on other sites More sharing options...
digitalfx Posted May 8, 2023 Author Share #23 Posted May 8, 2023 17 minutes ago, lct said: I would make sure that lens detection auto has been selected in your user profiles given that all your lenses are coded. it is set to auto Link to post Share on other sites More sharing options...
digitalfx Posted May 8, 2023 Author Share #24 Posted May 8, 2023 22 minutes ago, Chaemono said: Yes, I agree. Reset the camera perhaps and see if the issue persists? Take out the battery, too? Edit: Also, check to see if there are any changes to your settings that may have occurred/the camera may have made after being restarted. Yes Ive tried all this. In my tests Im setting profile and immediately powering down and back up...if any changes are made by the camera then this is a problem. The camera doesn't randomly change settings. See my video above. Link to post Share on other sites More sharing options...
Chaemono Posted May 8, 2023 Share #25 Posted May 8, 2023 vor 4 Minuten schrieb digitalfx: Yes Ive tried all this. In my tests Im setting profile and immediately powering down and back up...if any changes are made by the camera then this is a problem. The camera doesn't randomly change settings. See my video above. Yes, that’s definitely a problem. It would still be interesting to see, if any changes to settings occurred when turning the camera off and on. Maybe you have a firmware with AI. 😉 Link to post Share on other sites More sharing options...
Paco TG Posted August 11, 2023 Share #26 Posted August 11, 2023 On 5/8/2023 at 5:50 PM, digitalfx said: Yes Ive tried all this. In my tests Im setting profile and immediately powering down and back up...if any changes are made by the camera then this is a problem. The camera doesn't randomly change settings. See my video above. I revive this Post New to Leica since last July, with an M11 and a 35mm and 50mm reissues. I was intrigued because the same thing was happening to me, but despite the figure of the standard profile appearing, the settings are those of the profile that you had in use. I have read and mixed the suggestions and comments of this post with another with the same incident, and I have drawn a possible conclusion. And what I did is a profile for each lens, which are coded lenses, then export the profiles to SD and then import them, this seems to fix them. 🙄 Link to post Share on other sites More sharing options...
