modernvintagephotos Posted May 7, 2023 Share #1 Posted May 7, 2023 Advertisement (gone after registration) First big photo shoot with the M11M today. It froze a dozen times. I wanted to throw it against a wall it was so frustrating. Grrrrrrrrrr. Suggestions? Link to post Share on other sites More sharing options...
Advertisement Posted May 7, 2023 Posted May 7, 2023 Hi modernvintagephotos, Take a look here M11 Monochrom Freezing. I'm sure you'll find what you were looking for!
michali Posted May 7, 2023 Share #2 Posted May 7, 2023 Try a different SD card Link to post Share on other sites More sharing options...
modernvintagephotos Posted May 7, 2023 Author Share #3 Posted May 7, 2023 Also, Firmware says: Installed Version 122.40.37 Installed Release 1.0.0.0 Link to post Share on other sites More sharing options...
frame-it Posted May 7, 2023 Share #4 Posted May 7, 2023 so the same issues as the M11? Link to post Share on other sites More sharing options...
modernvintagephotos Posted May 7, 2023 Author Share #5 Posted May 7, 2023 Sorry. I don't have that experience to compare it with. Link to post Share on other sites More sharing options...
frame-it Posted May 7, 2023 Share #6 Posted May 7, 2023 Just now, modernvintagephotos said: Sorry. I don't have that experience to compare it with. Link to post Share on other sites More sharing options...
lct Posted May 7, 2023 Share #7 Posted May 7, 2023 Advertisement (gone after registration) Have you been using uncoded lenses? Just curious. Link to post Share on other sites More sharing options...
Chaemono Posted May 7, 2023 Share #8 Posted May 7, 2023 FIRMWARE 1.6.1 ERROR CORRECTION • A camera error, which caused the device to freeze, was remedied Link to post Share on other sites More sharing options...
digitalfx Posted May 7, 2023 Share #9 Posted May 7, 2023 odd...but had zero issues with 1.0fw and camera freezing...but since updating to 1.6.1 my M11M has had to hard reset twice. Link to post Share on other sites More sharing options...
dkmoore Posted May 7, 2023 Share #10 Posted May 7, 2023 (edited) As a few have mentioned, Always update firmware to latest version. I just got mine, updated firmware and haven’t had freeze issues. Same with my M11, haven’t had freeze issues in months. What’s great is that you can connect to Fotos very quickly and install the latest firmware without any cables in about 5 minutes. Props to Leica. Edited May 7, 2023 by dkmoore Link to post Share on other sites More sharing options...
modernvintagephotos Posted May 7, 2023 Author Share #11 Posted May 7, 2023 7 hours ago, lct said: Have you been using uncoded lenses? Just curious. I have used uncoded lenses. But the freezing was happening with coded lenses, 3 hours ago, digitalfx said: odd...but had zero issues with 1.0fw and camera freezing...but since updating to 1.6.1 my M11M has had to hard reset twice. I can't believe they ship the camera with Firmware 1.0, but in any case I updated to 1.6.1 and so far, I can't reproduce the freezes. Fingers crossed. 2 Link to post Share on other sites More sharing options...
lct Posted May 7, 2023 Share #12 Posted May 7, 2023 1 minute ago, modernvintagephotos said: have used uncoded lenses. But the freezing was happening with coded lenses, OK but when using your uncoded lenses, did you select lens detection auto? Link to post Share on other sites More sharing options...
modernvintagephotos Posted May 8, 2023 Author Share #13 Posted May 8, 2023 8 hours ago, lct said: OK but when using your uncoded lenses, did you select lens detection auto? Yes. I did. Link to post Share on other sites More sharing options...
LeicaR10 Posted May 8, 2023 Share #14 Posted May 8, 2023 Modernvintagephotos, First, welcome to the forum. You will find there are highly experienced photographers that will offer their sage advice to include myself. Second, the M11-M camera was shipped with the initial firmware because the firmware update wasn't available when the camera was produced. My M11-M came the same way when I picked it up at the Leica Store, 2 weeks ago. I knew to immediately check for firmware updates based on years of digital M camera experience. Third, Michali's advice in his post #2 is sage advice. I use Delkin Black 128 GB SD cards and use the SD Card Formatter software (free) to initially format all my SD cards. Then I upload the Leica firmware to the camera. I have never had a freeze since doing this way back with the M240 and all Monochrom cameras. I also download my shoot every day, then delete the files and reformat the SD card in camera. Every 10 shoots, I reformat the SD card with SD Card Formatter. I also always use the same SD card in my camera. Again, never a freeze or issue with any M or SL camera. Many others do the same thing, no issues. The M10-M was excellent, but you will find the M11-M stellar once you get use to it. Hope this helps. r/ Mark PS. Red Dot Forum with David Farkas and Josh Lehrer had some good tips on their past weekend video for the M11-M. You might want to watch it, it might help you. 4 Link to post Share on other sites More sharing options...
lct Posted May 8, 2023 Share #15 Posted May 8, 2023 19 minutes ago, modernvintagephotos said: Yes. I did. Better select lens detection manual for uncoded lenses. Lens detection auto can work but freezes may happen then. According to Leica's instructions, "the lens type must be entered manually when using a Leica M lens without 6-bit encoding" Link to post Share on other sites More sharing options...
hdmesa Posted May 8, 2023 Share #16 Posted May 8, 2023 ^ Nothing will help for freezes on startup, at least it did not for me on the M11. If you’re experience startup freezes, either learn to live with it until a fix is issued or return it. Link to post Share on other sites More sharing options...
normie610 Posted May 8, 2023 Share #17 Posted May 8, 2023 just got mine, and updated straightaway to 1.6.1 and no freezing issues. Overall feel of the menu/UI is quite a bit faster than my M11. And no SD for me, since internal SSD is plenty already 😁 1 Link to post Share on other sites More sharing options...
modernvintagephotos Posted May 11, 2023 Author Share #18 Posted May 11, 2023 On 5/8/2023 at 3:11 PM, LeicaR10 said: Modernvintagephotos, First, welcome to the forum. You will find there are highly experienced photographers that will offer their sage advice to include myself. Second, the M11-M camera was shipped with the initial firmware because the firmware update wasn't available when the camera was produced. My M11-M came the same way when I picked it up at the Leica Store, 2 weeks ago. I knew to immediately check for firmware updates based on years of digital M camera experience. Third, Michali's advice in his post #2 is sage advice. I use Delkin Black 128 GB SD cards and use the SD Card Formatter software (free) to initially format all my SD cards. Then I upload the Leica firmware to the camera. I have never had a freeze since doing this way back with the M240 and all Monochrom cameras. I also download my shoot every day, then delete the files and reformat the SD card in camera. Every 10 shoots, I reformat the SD card with SD Card Formatter. I also always use the same SD card in my camera. Again, never a freeze or issue with any M or SL camera. Many others do the same thing, no issues. The M10-M was excellent, but you will find the M11-M stellar once you get use to it. Hope this helps. r/ Mark PS. Red Dot Forum with David Farkas and Josh Lehrer had some good tips on their past weekend video for the M11-M. You might want to watch it, it might help you. Cheers Mark. Thanks for the advice and welcome. I have been making photographs for 30 years from 35mm to ULF. I love my M6 but have always used Nikon for Digital Equipment. Since the FW Update, I have had zero issues. FWIW, my lens setup is 21 SEM, 35 ZM, 50 APO and 90 2.8 Voigt They all look STELLAR on the Monochrom. 2 Link to post Share on other sites More sharing options...
duesentrieb Posted May 20, 2023 Share #19 Posted May 20, 2023 Exchanged the first M11 after the issue could not be dealt with. Even parts of the hardware were changed. The current M11 also freezes permanently, also on the way to customer care. Now had the hope with the M11 Monochrome that the issue would be resolved. Unfortunately none. Imported latest firmware. Internal memory formatted, also formatted the SD card again. More attempts are in progress. 1 Link to post Share on other sites More sharing options...
digitalfx Posted May 20, 2023 Share #20 Posted May 20, 2023 10 hours ago, duesentrieb said: Exchanged the first M11 after the issue could not be dealt with. Even parts of the hardware were changed. The current M11 also freezes permanently, also on the way to customer care. Now had the hope with the M11 Monochrome that the issue would be resolved. Unfortunately none. Imported latest firmware. Internal memory formatted, also formatted the SD card again. More attempts are in progress. have you tried a different card? Link to post Share on other sites More sharing options...
