Pete otto Posted March 23, 2023 Share #1  Posted March 23, 2023 Advertisement (gone after registration) I tried to rewind a film that wasnt fully used. When rewinding, a weird screechy feeling occurred. After that, i just shot the whole roll and took it out. Is this causing any problem? And is that part in the pic normal?Also, when finally rewinding, i could reload 3-4 frames extra before it stops. Never happened before. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/374231-mp-rewind-issue/?do=findComment&comment=4734287'>More sharing options...
Advertisement Posted March 23, 2023 Posted March 23, 2023 Hi Pete otto, Take a look here Mp rewind issue. I'm sure you'll find what you were looking for!
Mute-on Posted March 23, 2023 Share #2  Posted March 23, 2023 The metal tab is the frame counter reset. It extends as soon as you remove the baseplate and resets the frame counter to zero. You can watch it happen.  It’s possible the rewind lever on the front of the camera moved down a little to partially engage the clutch, which could cause the screeching and added tension on film rewind. I always hold the lever in the rewind position initially to ensure it is fully disengaged. Link to post Share on other sites More sharing options...
jakontil Posted March 23, 2023 Share #3  Posted March 23, 2023 2 hours ago, Pete otto said: I tried to rewind a film that wasnt fully used. When rewinding, a weird screechy feeling occurred. After that, i just shot the whole roll and took it out. Is this causing any problem? And is that part in the pic normal?Also, when finally rewinding, i could reload 3-4 frames extra before it stops. Never happened before. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! That tab is the film counter reset, the explanation why u get extra exposures is because, you didnt waste the film leader like when you are loading the first time usually i get 38exposures on a single roll, and another extra, depending on how i load the films Link to post Share on other sites More sharing options...
250swb Posted March 23, 2023 Share #4 Â Posted March 23, 2023 As for the 'weird screechy feeling' are you sure you had the rewind lever pointing at 'R'? As the other guys have said the tab just resets the frame counter. 1 Link to post Share on other sites More sharing options...
