9 hours ago, julianf73 said:
Since the 35mm Summilux ASPH FLE (11675) is larger than the Summicron (11674), does it make sense that it's also lighter?
Summilux-M 35mm f/1.4 ASPH:
Dimensions 2.2" x 1.8" / 56 x 46 mm
Weight 11.3 oz / 320 g
Summicron-M 35mm f/2 ASPH:
Dimensions 2.1" x 1.4" / 53 x 35.7 mm
Weight 12 oz / 340 g
The 35 APO is 320 grams. The 35 cron black is @ 252 grams.
I compiled the following while preparing to purchase M 35mm. I ended up with the Summarit and APO lenses.
Weights for black anodized taken from Leica Technical Specifications. The FLE's are noted as approximate.
LENS L D W Filter Size Part #
Leica 35 2.5 34 mm 51 mm 220 g 39 mm 11680
Leica 35 2.0 35.7 mm 53 mm 252 g 39 mm 11673
Leica 35 APO 40.9 mm 43 mm 320 g 39 mm 11699
Leica 35 1.4 FLE  46 mm 56 mm 320 g 46 mm 11663
Leica 35 1.4 FLE II 46 mm 58 mm 338 g 46 mm 11726
In its heyday the silver summicron 35 ASPH version 1 (all time version V) with product number 11882 was 340g because it was made of brass. Because of that it was heavier than the 35 lux FLE and it made perfect sense. The current one 11674 is not brass and is thus lighter than FLE.
B&H still erratically lists the old V1 weight under the V2 model.
