noirblancgris Posted December 16, 2022 Share #1 Posted December 16, 2022 Advertisement (gone after registration) Hi I tried to use 2 different Visoflex 2 on my Leica M11 and both did not work correctly. They are not turned on, both. They damaged the hot shoe of the M11 and required enormous pressure each time to be able to put them in place. It is true that once put in place with force, they lit up. I've seen videos where it seems quite easy to place them on the M11. Has anyone had this kind of problem? Since then, I give up using this accessory. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/355706-visoflex-2-and-hot-shoe-leica-m11/?do=findComment&comment=4602068'>More sharing options...
Advertisement Posted December 16, 2022 Posted December 16, 2022 Hi noirblancgris, Take a look here Visoflex 2 and hot shoe Leica M11 . I'm sure you'll find what you were looking for!
Photoworks Posted December 16, 2022 Share #2 Posted December 16, 2022 I had some issues that it didn't work, and I have tested other in the store and that worked and the version I owned on a new M11 was giving problems. I looks like the contact need cleaning often and then it works fine. I WAS NEVER HARD TO PUT ON. I would check with a flash or a trigger and see if you have the same problem, may be camera hotshoe side spring are the issue. Link to post Share on other sites More sharing options...
noirblancgris Posted December 16, 2022 Author Share #3 Posted December 16, 2022 My Leica M11 is brand new. Link to post Share on other sites More sharing options...
jakontil Posted December 16, 2022 Share #4 Posted December 16, 2022 slotting in was not too hard, slide in well but yeah my viso dont work no more, but i think the hotshoe was the problem since it worked fine on my m10r Link to post Share on other sites More sharing options...
Keith (M) Posted December 16, 2022 Share #5 Posted December 16, 2022 56 minutes ago, noirblancgris said: Hi I tried to use 2 different Visoflex 2 on my Leica M11 and both did not work correctly. They are not turned on, both. They damaged the hot shoe of the M11 and required enormous pressure each time to be able to put them in place. It is true that once put in place with force, they lit up. I've seen videos where it seems quite easy to place them on the M11. Has anyone had this kind of problem? Since then, I give up using this accessory. The two copper-coloured pins on my Visoflex 2 depress very easily. The relevant pin on yours presumably did not. Do you still have the one that caused the damage? Link to post Share on other sites More sharing options...
noirblancgris Posted December 16, 2022 Author Share #6 Posted December 16, 2022 7 minutes ago, Keith (M) said: The two copper-coloured pins on my Visoflex 2 depress very easily. The relevant pin on yours presumably did not. Do you still have the one that caused the damage? No, I don't have them, my Leica dealer was absolutely great and took back the 2 Visoflex and also gave me a new M11 because the hot shoe has been damaged. I won't by a Visoflex 2 anymore... but I just wanted to understand what happened. Link to post Share on other sites More sharing options...
Gelatino Posted December 16, 2022 Share #7 Posted December 16, 2022 Advertisement (gone after registration) I would not stay on that bad experience with the visoflex2. You surely have been unlucky with the one(s) you got, but your Leica dealer did well changing both viso and body. IMO, EVF is a great help in some circumstances to overcome limits of the RF system. Link to post Share on other sites More sharing options...
DenverSteve Posted December 17, 2022 Share #8 Posted December 17, 2022 (edited) First, I'm glad whatever caused your damage was handled by your Dealer. I had not previously examined the contact pins on my Visoflex 2, but after reading your post, I did. The two outside pins that mate with the rear two contacts on the M11 are the easiest contact pins to push that I've ever experienced. Mine require no pressure and offer no resistance. They could, in no way, cause the damage you show, or any damage for that matter. Additionally, I see no possible way the pins could damage anything. I'm more surprised that you found two different Visoflex 2s, in one store, that were both completely defective. I can't even imagine, with the limited production of this accessory, that a single store had two, completely defective, Visoflex units that somehow failed final inspection and ended up at the same Leica store. Boggles the mind. 🤷♂️ Edited December 17, 2022 by DenverSteve Link to post Share on other sites More sharing options...
noirblancgris Posted December 17, 2022 Author Share #9 Posted December 17, 2022 8 hours ago, DenverSteve said: First, I'm glad whatever caused your damage was handled by your Dealer. I had not previously examined the contact pins on my Visoflex 2, but after reading your post, I did. The two outside pins that mate with the rear two contacts on the M11 are the easiest contact pins to push that I've ever experienced. Mine require no pressure and offer no resistance. They could, in no way, cause the damage you show, or any damage for that matter. Additionally, I see no possible way the pins could damage anything. I'm more surprised that you found two different Visoflex 2s, in one store, that were both completely defective. I can't even imagine, with the limited production of this accessory, that a single store had two, completely defective, Visoflex units that somehow failed final inspection and ended up at the same Leica store. Boggles the mind. 🤷♂️ Hello, Thank you for your answer. I called my Leica dealer, and he thinks that the hot shoe of this M11 is perhaps in question, it must have a defect. I don't see what, but he may be right... Two Visoflex not working in the same store is quite strange indeed... you're right. Link to post Share on other sites More sharing options...
lct Posted December 17, 2022 Share #10 Posted December 17, 2022 (edited) On 12/16/2022 at 1:54 PM, noirblancgris said: They damaged the hot shoe of the M11 and required enormous pressure each time to be able to put them in place. [...] I've seen videos where it seems quite easy to place them on the M11. Has anyone had this kind of problem? My Viso 2 fits perfectly but my M11 is not damaged contrary to yours. Incredible that you got that damaged a hotshoe on delivery but i would quit using any accessory on it as long as it is not repaired. And please, never force you can only aggravate things. Edited December 17, 2022 by lct Link to post Share on other sites More sharing options...
Jeff S Posted December 18, 2022 Share #11 Posted December 18, 2022 4 hours ago, lct said: …but i would quit using any accessory on it as long as it is not repaired. Dealer gave him a new M11. Jeff 1 Link to post Share on other sites More sharing options...
