jaapv Posted September 22, 2007 Share #1 Posted September 22, 2007 Advertisement (gone after registration) Just found out: The 50/2.8M collapsible lenshood # 14550 fits, is extremely compact, screws in instead of clicks-and-falls-off, does not vignette (not even with filter) and is the most effective I suppose. Link to post Share on other sites More sharing options...
Advertisement Posted September 22, 2007 Posted September 22, 2007 Hi jaapv, Take a look here Lens hood for 28/2.8 asph. I'm sure you'll find what you were looking for!
carstenw Posted September 22, 2007 Share #2 Posted September 22, 2007 I think it would work in the 35 Cron ASPH as well. I meant to get one of these hoods until I switched to the Lux. Link to post Share on other sites More sharing options...
Frank Sprow Posted September 22, 2007 Share #3 Posted September 22, 2007 Thanks very much - I lost two of the plastic clip on type, and then gave up. Will go to this. Link to post Share on other sites More sharing options...
ko2006 Posted September 22, 2007 Share #4 Posted September 22, 2007 You mean 12550 ? Link to post Share on other sites More sharing options...
ibogost Posted September 23, 2007 Share #5 Posted September 23, 2007 Interesting. Does this hood also reduce the total size footprint (i.e. length) of the lens, compared to the 28 hood? Also, does a standard E39 cap fit when the 50 hood is in place? Link to post Share on other sites More sharing options...
grduprey Posted September 23, 2007 Share #6 Posted September 23, 2007 I am confused, what is wrong with the supplied hood? I have this lens and hood and find the supplied hood just perfect. The round vented hoods are cool looking,but they still intrude into the viewfinder far more than the very small hood supplied with the lens, which just barely intrudes into the viewfinder. I have had no problems with the supplied hood staying on at all, and the hood cap works fine. There is no cap for the round vented hood, unless you reverse it, a real pain. Gene Link to post Share on other sites More sharing options...
lct Posted September 23, 2007 Share #7 Posted September 23, 2007 Advertisement (gone after registration) ...Does this hood also reduce the total size footprint (i.e. length) of the lens, compared to the 28 hood? Also, does a standard E39 cap fit when the 50 hood is in place? Yes and yes. Reduces the overall length of the lens + hood by about 5 mm if you don't use any filter, otherwise the reduction is only a bit less than 1 mm. Not a big deal IMHO given that the 12550 is a very little hood that is not much usefull in my experience with 50mm lenses at least. Never used it with the Elmarit 28/2.8 asph though and better it than no hood at all of course provided it does not cause vignetting with and w/o IR-cut filter. A shorter and more effective combo would be the collapsible rubber hood of the Summicron-C 40/2 #12518 and its snap-on cap #14191 (right) if one don't screw the hood too tight on the lens, because its 0.75 filter thread is not the same as that of the lens (0.5 i guess). I don't know if it vignettes with film Ms or the M8 though. All in all i prefer the supplied hood personally. Was the same on the 35/2. Never lost one in 20+ years. Link to post Share on other sites More sharing options...
lct Posted September 23, 2007 Share #8 Posted September 23, 2007 BTW good clip-on hoods like those of the 35/2 or 28/2.8 asph are more protective that screw-in ones generally. In case of drop or bump a screw-in hood may damage the filter thread of the lens. Link to post Share on other sites More sharing options...
wattsy Posted September 23, 2007 Share #9 Posted September 23, 2007 I am confused, what is wrong with the supplied hood? Agreed. The hood for the 28/F2.8 ASPH and 35/F2 ASPH is very neat and compact. Certainly much more useful than the circular vented variety which came with my 35/F2 ASPH. Link to post Share on other sites More sharing options...
Woody Campbell Posted September 23, 2007 Share #10 Posted September 23, 2007 The classic vented metal hood, 12686, also works well with this lens. One advantage of the 12550 is that it obscurs none (or almost none of the viewfinder). Link to post Share on other sites More sharing options...
lct Posted September 23, 2007 Share #11 Posted September 23, 2007 The classic vented metal hood, 12686, also works well with this lens... Don't remember the 12686. Is it the plastic version of the 12585? The latter works fine as well but it cannot be reverted on the 28 because of the focus tab. Not that small a shade anyhow. How about the 12504? Link to post Share on other sites More sharing options...
Guest tvleeskr Posted September 23, 2007 Share #12 Posted September 23, 2007 Jaapv, the shade is in the mail, on its way to you. It's not only small but also very light, boxed including jiffy and stamps less then 50 grms. Post some pics? Thom Link to post Share on other sites More sharing options...
jaapv Posted September 24, 2007 Author Share #13 Posted September 24, 2007 Thanks; Nice to have a black one, Thom Yes, it fits the Summicron 35 asph 35 as well. The advantage is that it is tighter that the supplied hood; it vignettes on film. That means that it is more effective than the original one on the M8. The original hood of the Summicron, which is the same hood as the 28, is virtually useless for reducing flare on that lens on the M8; it is far too wide if it works on a 28 on film-size as well. Link to post Share on other sites More sharing options...
jaapv Posted September 24, 2007 Author Share #14 Posted September 24, 2007 Just noticed I am in the wrong forum here I was talking about the M8! Moderator!!! Link to post Share on other sites More sharing options...
LUF Admin Posted September 24, 2007 Share #15 Posted September 24, 2007 Moderator!!! Yesss!!! Moved!!!! Regards Andreas Link to post Share on other sites More sharing options...
jaapv Posted September 24, 2007 Author Share #16 Posted September 24, 2007 Thank you Andreas Link to post Share on other sites More sharing options...
aj55 Posted September 24, 2007 Share #17 Posted September 24, 2007 pauze ?? Link to post Share on other sites More sharing options...
jaapv Posted September 24, 2007 Author Share #18 Posted September 24, 2007 pauze ?? 13.30... Link to post Share on other sites More sharing options...
andybarton Posted September 24, 2007 Share #19 Posted September 24, 2007 Just noticed I am in the wrong forum here I was talking about the M8! Moderator!!! I moved this because your original post said nothing about the M8, and was an enquiry that was of general interest to all M users and not just M8 ones. Now, film users will not have the benefit.. Your reference to the M8 has come along a lot later in the thread. Link to post Share on other sites More sharing options...
jaapv Posted September 24, 2007 Author Share #20 Posted September 24, 2007 I moved this because your original post said nothing about the M8, and was an enquiry that was of general interest to all M users and not just M8 ones. Now, film users will not have the benefit.. Your reference to the M8 has come along a lot later in the thread. Point is, Andy, it may well vignette on a film body, I don't know.... I forgot to include the word "M8"in the OP. Unfortunately this forum has a limited (in time) editing feature. Link to post Share on other sites More sharing options...
