On 10/4/2022 at 12:19 PM, egonleicaforum1 said:
I still have FW 2.0.2.0 on my M-P .  Tried to find a document on FW history to determine is it is wise to update to 2.1.0
Is there such a document?
Just my own notes about the M240:
2.0.2.5
M_240-2.0.2.5.FW
08/07/2015
• New Menu item "Flash exposure compensation" to adjust flash exposure with the Leica SF 26 flash unit (only active when SF 26 is attached). This new function requires Firmware 1.1 on the SF 26 Flash.
• Several firmware bugs that caused occasional camera hang up when using Live View or Video function have been fixed.
2.0.3.0
M240_2030.FW
29/04/2016
• Implemented optimizations that prevent the camera controls from becoming unresponsive after a series of continuous burst photos fills the buffer.
• The selected user profile will be displayed even when exposure compensation has been adjusted. Exposure compensation is no longer saved to the user profile.
• Memory cards with a capacity up to 512 GB are supported
• The default file format settings upon camera reset have been changed from "JPG" to "DNG+JPG"
• The time-out period for the last GPS Position, when no GPS signal is received, has been extended to 2.5 hours (GPS is not available with M (Typ 262))
• It is now possible to display DNG files from the Leica M Monochrom (Typ 246) in all zoom steps, also with the M/M-P (Typ 240 and 262)
• When using SD-cards that are too slow for movie recording, a message appears in the viewfinder display
2.0.5.0
M_240-2.0.5.0-CUSTOMER.FW
30/11/2017
• Support for the new Thambar-M 90 f/2.2
• Support for the new Noctilux-M 75 f/1.25 ASPH.
• A Bug, that lead to occasional underexposure when using a flash unit, was fixed
2.0.6.0
M_240-2.0.6.0-CUSTOMER.FW
23/10/2019
• Optimisation to prevent the camera controls from becoming unresponsive after a series of continuous burst photos fills the buffer.
• Memory cards with a capacity up to 512 GB are supported.
• The default file format settings upon camera reset have been changed from “JPG“ to “DNG+JPG“.
• The time-out period for the last GPS position, when no GPS signal is received, has been extended to 2.5 hours (GPS is not available with the M 262).
• It is now possible to display DNG files from the Leica M Monochrom (Typ 246) in all zoom steps, also with the M/M-P (Typ 240 and 262).
• When using SD-cards that are too slow for movie recording, a message appears in the viewfinder display.
2.1.0.0
M_240-2.1.0.0-CUSTOMER.FW
30/10/2019
• The list of automatically detectable Leica-M lenses was extended
