yukosteel Posted July 3, 2022 Share #1 Posted July 3, 2022 Advertisement (gone after registration) Just made this mod few days ago for one of my good friend. Button is cut from the used casing shot from his Sako rifle, then drilled through to get primer diameter. I used generic brass soft release button and trimmed its diameter to primer size as well. Used cut primer is straightened and pressed in from the top, while trimmed soft release button is pressed in from the bottom, forming rigid assembly. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 6 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/334158-m10-diy-soft-release-for-precision-shooters/?do=findComment&comment=4464486'>More sharing options...
Advertisement Posted July 3, 2022 Posted July 3, 2022 Hi yukosteel, Take a look here M10 DIY soft release for precision shooters. I'm sure you'll find what you were looking for!
TomB_tx Posted July 3, 2022 Share #2 Posted July 3, 2022 Nice job! Sounds like very solid construction. I only use a tiny soft release on my M5, due to the depth of travel to move the meter cell. Maybe a 30 Super Carry would do for me... Link to post Share on other sites More sharing options...
yukosteel Posted July 3, 2022 Author Share #3 Posted July 3, 2022 Right! With so many casings sizes available it's quite easy to adapt preferred diameter and depth to a soft release. Most challenging part is a trimming of soft release base to smaller diameter, because it's hard to hold it. I used 2mm drilling bit, wrapped few dozen layers of aluminum foil to form a pipe. Then used a small nut to fit pipe inside and finally screwing in the soft release conical thread into aluminum foil pipe. It allows to trim soft release button in a high-speed rotary tool by using metal or diamond file. Link to post Share on other sites More sharing options...
DI1 Posted July 22, 2022 Share #4 Posted July 22, 2022 If you would be willing to make another one, I would love to purchase it. Link to post Share on other sites More sharing options...
jakontil Posted July 23, 2022 Share #5 Posted July 23, 2022 One of the finest shutter release i ever see! Link to post Share on other sites More sharing options...
M11 for me Posted July 23, 2022 Share #6 Posted July 23, 2022 vor 7 Stunden schrieb jakontil: One of the finest shutter release i ever see! OMG! Are you aware that this is part of a gun? Link to post Share on other sites More sharing options...
jakontil Posted July 23, 2022 Share #7 Posted July 23, 2022 Advertisement (gone after registration) 46 minutes ago, M11 for me said: OMG! Are you aware that this is part of a gun? I know, that’s the bottom of bullet, but this was intended for shutter release 😂 Link to post Share on other sites More sharing options...
84bravo Posted July 23, 2022 Share #8 Posted July 23, 2022 So you drill out the primer pocket to 2 mm? Link to post Share on other sites More sharing options...
yukosteel Posted August 24, 2022 Author Share #9 Posted August 24, 2022 On 7/23/2022 at 3:26 PM, 84bravo said: So you drill out the primer pocket to 2 mm? I've extracted primer and drilled that pocket to primer diameter. Soft release button is also trimmed to primer diameter and fits tight from the bottom. Then I've extracted anvil from used primer, straightened and polished its bottom, then cut it to be about 2mm long for proper fit from the top. 1 Link to post Share on other sites More sharing options...
