mc_murphy Posted June 20, 2022 Share #1  Posted June 20, 2022 Advertisement (gone after registration) Hi guys, Images shot on my M7 with Summicron 35 ASPH show significant blur near left (bottom) edge of frame. Looks like weird motion blur or multiple exposure, I've attached images with the described problem. I'm desperate to find the root cause of the problem and couldn't find the same problem described anywhere on the web. This differs from frame to frame and is not consistent. Some shots or even entire rolls are perfectly fine, experimented with it and it doesn't correspond with exposure time or aperture setting, the same lens on digital M240M produces perfect results, I have rotated the pressure plate spring 180°, but the blur remained on the same (left) side of image, Images have even exposure, so (probably) the curtains are tuned fine. It seems to be the problem with the camera itself, but the pressure plate seems to fit tight, and there is no wobbling in the camera frame or body. Do you have any advice on what to do and where to look further? Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/333761-m7-problem-blur-at-the-edge-of-frame/?do=findComment&comment=4457303'>More sharing options...
Advertisement Posted June 20, 2022 Posted June 20, 2022 Hi mc_murphy, Take a look here M7 problem: blur at the edge of frame. I'm sure you'll find what you were looking for!
Huss Posted June 20, 2022 Share #2 Â Posted June 20, 2022 (edited) Do you see blur on the negatives themselves? Â Because if you do not, then it is a scanning/printing issue and your M7 is fine. Edited June 20, 2022 by Huss Link to post Share on other sites More sharing options...
jaapv Posted June 21, 2022 Share #3  Posted June 21, 2022 In cases like this the lens is more suspect than the camera. A decentered lens element can produce such an effect. Link to post Share on other sites More sharing options...
Huss Posted June 21, 2022 Share #4  Posted June 21, 2022 2 hours ago, jaapv said: In cases like this the lens is more suspect than the camera. A decentered lens element can produce such an effect. Perhaps, but mc-murphy said no issues on his M240 which is far more demanding on the image than film.  Which is why he needs to examine his negatives.  A poor scan  can cause this.  1 Link to post Share on other sites More sharing options...
mc_murphy Posted June 21, 2022 Author Share #5  Posted June 21, 2022 (edited) 4 hours ago, Huss said: Do you see blur on the negatives themselves? Unfortunately, the issue is seen on the negatives as well  Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited June 21, 2022 by mc_murphy Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/333761-m7-problem-blur-at-the-edge-of-frame/?do=findComment&comment=4457406'>More sharing options...
Helge Posted June 21, 2022 Share #6  Posted June 21, 2022 My first idea was, that there are Problems with the flatness of the film in the camera. Did you check the pressure plate? Maybe bender or somehow not doing it’s job… Link to post Share on other sites More sharing options...
Hintsalae Posted June 21, 2022 Share #7 Â Posted June 21, 2022 Advertisement (gone after registration) Shutter bounce. Either shutter is moving too fast or shutter brake is too loose. You can see that it's darker in the edge and also blurry because exposure is way longer than intended. Link to post Share on other sites More sharing options...
mc_murphy Posted June 21, 2022 Author Share #8  Posted June 21, 2022 41 minutes ago, Helge said: My first idea was, that there are Problems with the flatness of the film in the camera. Did you check the pressure plate? Maybe bender or somehow not doing it’s job… Had the same first thought. Plate seems to be firmly pressed, just to be sure I detached the pressure plate and the spring and rotated the spring 180 degrees, than put everything back. The results are the same and the blur is still on the left, so plate spring was not faulty. 19 minutes ago, Hintsalae said: Shutter bounce. Either shutter is moving too fast or shutter brake is too loose. You can see that it's darker in the edge and also blurry because exposure is way longer than intended. The images do look like faulty shutter problem, but that would cause uneven exposure. And the brightness is practically even across the whole frame, don’t you think? I saw curtain problem shots on the forum and the blurred edges were way brighter, like, several EV stops. Link to post Share on other sites More sharing options...
mc_murphy Posted June 21, 2022 Author Share #9  Posted June 21, 2022 5 hours ago, jaapv said: In cases like this the lens is more suspect than the camera. A decentered lens element can produce such an effect. Sounds absolutely right. Unfortunately, I double checked this lens on my digital M240M, the image is perfectly sharp across the frame 🤔 Link to post Share on other sites More sharing options...
jaapv Posted June 21, 2022 Share #10  Posted June 21, 2022 4 hours ago, Huss said: Perhaps, but mc-murphy said no issues on his M240 which is far more demanding on the image than film.  Which is why he needs to examine his negatives.  A poor scan  can cause this.  That would suggest the film is not flat so maybe the film pressure plate does not push down completely. But that has been ruled out. So might the bayonet flange have worked loose making  the lens and film not parallel? A long shot, I know…, 1 Link to post Share on other sites More sharing options...
Helge Posted June 21, 2022 Share #11  Posted June 21, 2022 vor 1 Stunde schrieb mc_murphy: Had the same first thought. Plate seems to be firmly pressed, just to be sure I detached the pressure plate and the spring and rotated the spring 180 degrees, than put everything back. The results are the same and the blur is still on the left, so plate spring was not faulty. … Dirt on the rails, bend plate or out of center etc. Could you take a look from underneath while the base plate is de-attached? Press the back door slowly against the rails on the body and look whether the gap closes synchronously on all 4 corners/sides? Link to post Share on other sites More sharing options...
TeleElmar135mm Posted June 21, 2022 Share #12  Posted June 21, 2022 Perhaps check it with another lens (loan one of your dealer). As jaapv said perhaps a problem with the bajonet because with your digital M it is all ok. It might be also a problem with the film channel in the camera. The film is pressed against the film channel which must be absolutely flat with the help of the pressure plate. But this is a problem Leica must adjust. Link to post Share on other sites More sharing options...
Hintsalae Posted June 21, 2022 Share #13  Posted June 21, 2022 3 hours ago, mc_murphy said: The images do look like faulty shutter problem, but that would cause uneven exposure. And the brightness is practically even across the whole frame, don’t you think? I saw curtain problem shots on the forum and the blurred edges were way brighter, like, several EV stops. Shutter bounce doesn't require curtains to travel different speeds. Closing curtain just bounces back after it passes the film gate. That produces exactly that kind of negatives. If your phone has high-speed try recording shutter action with it.  1 Link to post Share on other sites More sharing options...
mc_murphy Posted June 21, 2022 Author Share #14 Â Posted June 21, 2022 2 hours ago, Helge said: Could you take a look from underneath while the base plate is de-attached? Press the back door slowly against the rails on the body and look whether the gap closes synchronously on all 4 corners/sides? The plate seems to close evenly, with both sides touching the rails at the same moment. But its hard to tell for sure, the gap is really small Link to post Share on other sites More sharing options...
mc_murphy Posted June 21, 2022 Author Share #15  Posted June 21, 2022 58 minutes ago, Hintsalae said: Shutter bounce doesn't require curtains to travel different speeds. Closing curtain just bounces back after it passes the film gate. That produces exactly that kind of negatives. If your phone has high-speed try recording shutter action with it. Contacted a local Leica Store technician and showed him the images, he too blames the faulty curtains. I tried recording the video at 240 fps, and there is no visible curtain bounce. What is more interesting is that the left side of the image corresponds to the right side of the film channel, and this is where the curtains start their travel. Weird 🤔 Anyway, Hintsalae, thanks for the suggestion! I'll visit Leica technician tomorrow, hope he finds the means to diagnose the issue. Link to post Share on other sites More sharing options...
250swb Posted June 21, 2022 Share #16  Posted June 21, 2022 (edited) 4 hours ago, mc_murphy said: Sounds absolutely right. Unfortunately, I double checked this lens on my digital M240M, the image is perfectly sharp across the frame 🤔 Checked at the same apertures? On all the images you have a significant area out of focus in each shot in the same place (assuming you always hold the camera the same way). A test would be to see if the OOF goes away if you stop the lens down all the way. At the moment I would argue in favour of @Jaap's idea, and perhaps if you follow the trend for shooting everything wide open it is showing up a mis-alignment somewhere because DOF isn't compensating for it. Edited June 21, 2022 by 250swb Link to post Share on other sites More sharing options...
mc_murphy Posted June 21, 2022 Author Share #17 Â Posted June 21, 2022 (edited) 1 hour ago, 250swb said: Checked at the same apertures? On all the images you have a significant area out of focus in each shot in the same place (assuming you always hold the camera the same way). A test would be to see if the OOF goes away if you stop the lens down all the way. At the moment I would argue in favour of @Jaap's idea, and perhaps if you follow the trend for shooting everything wide open it is showing up a mis-alignment somewhere because DOF isn't compensating for it. I've checked lens on all apertures on my M240M, the lens seems to perform as usual. Considering the amount of blur on film, it would certainly be visible somewhere on digital images, but they all turned out fine. So probably if there is any misalignment, it is located in the M-mount or the body. The final candidates to check seem to be the curtains and the misalignment somewhere. Gonna ask a Leica technician to rule out both, if he can. Edited June 21, 2022 by mc_murphy Link to post Share on other sites More sharing options...
Mateusz Zimnoch Posted December 17, 2024 Share #18  Posted December 17, 2024 On 6/21/2022 at 2:20 PM, mc_murphy said: I've checked lens on all apertures on my M240M, the lens seems to perform as usual. Considering the amount of blur on film, it would certainly be visible somewhere on digital images, but they all turned out fine. So probably if there is any misalignment, it is located in the M-mount or the body. The final candidates to check seem to be the curtains and the misalignment somewhere. Gonna ask a Leica technician to rule out both, if he can. Have you actually managed to resolve this? I have exact same issue with my M6 after it came back from CLA. Obviously, I’ll send it back, still it would be good to know your experiences. Link to post Share on other sites More sharing options...
jaapv Posted December 17, 2024 Share #19 Â Posted December 17, 2024 The member has no visited since September 2022. Â Link to post Share on other sites More sharing options...
mc_murphy Posted December 17, 2024 Author Share #20  Posted December 17, 2024 I could not identify the issue myself and sent the camera to Leica for CLA, mentioning that particular problem with attached images. That fixed the issue, though sometimes I notice very slight blur at that side of the image. I’ve decided to leave that be. Link to post Share on other sites More sharing options...
