jaapv Posted May 4, 2022 Share #41 Posted May 4, 2022 Advertisement (gone after registration) It should not come as a surprise that an M 11 heats up a bit after twenty shots in rapid succession. I n general, M cameras run relatively warm due to the metal body and crowded interior with rapid heat dissipation. The huge files of the M11 will demand more processing power and the heat generated will have to go somewhere. Heat management is a design headache on these cameras. it appears you have a good dealer Hé shout en able to advise you. It is very hard for us to judge through the Internet whether your experience is normal (which I suspect ) or an issue. Link to post Share on other sites More sharing options...
Advertisement Posted May 4, 2022 Posted May 4, 2022 Hi jaapv, Take a look here How to navigate if there is a problem with new gear... I'm sure you'll find what you were looking for!
Fetchmycamera Posted May 4, 2022 Author Share #42 Posted May 4, 2022 " It is very hard for us to judge through the Internet whether your experience is bort(which I suspect ) or an issue " So, sorry, I don't understand bort? Yes, I am new to rangefinder. Yes it might be that warming is normal... However, I had the first M11 body that had X issues and that body was replaced. That body did not get warm at all and I was taking the same type of shots. Nothing rapid fire. With the old one, I was out in the field as well and no warming. Thanks ever so. Link to post Share on other sites More sharing options...
hdmesa Posted May 4, 2022 Share #43 Posted May 4, 2022 16 minutes ago, Fetchmycamera said: " It is very hard for us to judge through the Internet whether your experience is bort(which I suspect ) or an issue " So, sorry, I don't understand bort? Yes, I am new to rangefinder. Yes it might be that warming is normal... However, I had the first M11 body that had X issues and that body was replaced. That body did not get warm at all and I was taking the same type of shots. Nothing rapid fire. With the old one, I was out in the field as well and no warming. Thanks ever so. I just tried 10 minutes of live view and shooting, and yes the camera does get noticeably warm on the right side, warmest on the right side of the LCD up toward the 4-way controller. You just didn't notice it with your first one. Link to post Share on other sites More sharing options...
Fetchmycamera Posted May 4, 2022 Author Share #44 Posted May 4, 2022 WOW, thank you soooo much. You are so kind to me. Link to post Share on other sites More sharing options...
hdmesa Posted May 4, 2022 Share #45 Posted May 4, 2022 (edited) 13 minutes ago, Fetchmycamera said: WOW, thank you soooo much. You are so kind to me. Glad to help. All my mirrorless cameras have gotten hot over on the right side. Avoid handling the camera too long it gets really hot – you can get a cumulative burn from prolonged exposure. As far as heat management goes, it's best to use the rangefinder as much as possible and only use the LCD intermittently. Edited May 4, 2022 by hdmesa Link to post Share on other sites More sharing options...
jaapv Posted May 4, 2022 Share #46 Posted May 4, 2022 5 hours ago, Fetchmycamera said: So, sorry, I don't understand bort? Nor I. Maybe my iPhone does - it was corrected within a minute Link to post Share on other sites More sharing options...
jaapv Posted May 4, 2022 Share #47 Posted May 4, 2022 Advertisement (gone after registration) 5 hours ago, hdmesa said: it gets really hot I really doubt that. It will shut down over 45ºC - and we have not had a. single complaint about that. 5 hours ago, hdmesa said: you can get a cumulative burn from prolonged exposure. Link to post Share on other sites More sharing options...
hdmesa Posted May 4, 2022 Share #48 Posted May 4, 2022 (edited) 8 hours ago, jaapv said: I really doubt that. It will shut down over 45ºC - and we have not had a. single complaint about that. I doubt it, too, but my R5 was the first camera I owned that had to include thermal controls/warnings/shutoff for temps that don’t burn you right away but can leave burns if you hold it too long at certain temps (not cumulative from separate uses, lol). Hopefully Leica is aware of such burn risks and includes thermal controls at lower temps but at longer times, if needed. Edited May 4, 2022 by hdmesa Link to post Share on other sites More sharing options...
Fetchmycamera Posted May 4, 2022 Author Share #49 Posted May 4, 2022 Will advise. Link to post Share on other sites More sharing options...
