analog-digital Posted February 19, 2022 Share #1 Posted February 19, 2022 Advertisement (gone after registration) I would like to have some field reports on the Leica APO-MACRO-Summarit-S 120mm/2.5 ASPH (11070) lens. Can it be used WITHOUT a tripod? Link to post Share on other sites More sharing options...
Advertisement Posted February 19, 2022 Posted February 19, 2022 Hi analog-digital, Take a look here Leica APO-MACRO-Summarit-S 120mm/2.5 ASPH. (11070) . I'm sure you'll find what you were looking for!
Sarnian Posted February 19, 2022 Share #2 Posted February 19, 2022 13 minutes ago, analog-digital said: Can it be used WITHOUT a tripod? Absolutely! I never use a tripod. The only lens I would probably think about using a tripod with is the 180mm due to its length. Here's a handheld 'snapshot' with the 120mm Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 7 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/329959-leica-apo-macro-summarit-s-120mm25-asph-11070/?do=findComment&comment=4386525'>More sharing options...
helged Posted February 19, 2022 Share #3 Posted February 19, 2022 (edited) 31 minutes ago, analog-digital said: I would like to have some field reports on the Leica APO-MACRO-Summarit-S 120mm/2.5 ASPH (11070) lens. Can it be used WITHOUT a tripod? Absolutely +2. But try to avoid shutter speeds in the range 1/30-1/125 s (holdes for any lens on the S-system) as there is a tendency for shutter/mirror movement kicking in. Edited February 19, 2022 by helged Link to post Share on other sites More sharing options...
John McMaster Posted February 19, 2022 Share #4 Posted February 19, 2022 I try to use at least 1/500th with my 120, sometimes 1/360th is OK, rarely use a tripod outside... john Link to post Share on other sites More sharing options...
topoxforddoc Posted February 19, 2022 Share #5 Posted February 19, 2022 (edited) I regularly hand hold the 120 with my S(006) for music gigs. Here are some shots from the photographers' pit from Blenheim Palace in 2017 with Jamie Cullum, Gregory Porter and Tivon Pennicott (GP's sax player) Handheld between 1/125 to 1/250 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited February 19, 2022 by topoxforddoc 9 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/329959-leica-apo-macro-summarit-s-120mm25-asph-11070/?do=findComment&comment=4386655'>More sharing options...
Stuart Richardson Posted February 19, 2022 Share #6 Posted February 19, 2022 It is the best lens in the system, in my opinion. The sharpest edge to edge, beautiful bokeh, a flat focal plane, and no color fringing, distortion and focuses to 1:2. The only real improvements I can see for this lens would be to focus to 1:1 (which would make the lens even bigger), or to make it smaller/lighter. I still think it is not too bad though. It can definitely be used handheld as long as you keep the shutter speed reasonable. The S system is well-balanced, so it tends to handle better than it might appear given the size and weight specs. I shoot the 120mm often in daylight without a tripod. The lens is also at or near its best at f3.2 to 5.6, so unless you need the depth of field, you need not stop down, which helps keep the shutter speeds higher. 2 Link to post Share on other sites More sharing options...
tom0511 Posted February 19, 2022 Share #7 Posted February 19, 2022 Advertisement (gone after registration) Here is one more fan of the 120. Besides the points mentioned I also have very good accurate AF with my 120 (while the 100 seems more tricky). It is a little more heavy than the 100, and it focuses a little slower than the 180, but it is a very flexible lens with beautiful rendering. Macro, portrait, ... 2 Link to post Share on other sites More sharing options...
analog-digital Posted February 19, 2022 Author Share #8 Posted February 19, 2022 Thanks for all the input. What is your assessment of the used market price? Link to post Share on other sites More sharing options...
Sarnian Posted February 19, 2022 Share #9 Posted February 19, 2022 1 hour ago, analog-digital said: What is your assessment of the used market price? The 120mm is well-regarded so you won't see it sell as cheaply (or as frequently) as the 70mm. I got mine for £1,755 (with a new auto focus motor) but that was a good price. The cheapest on ebay.co.uk at the moment is £1,999.99 (with no mention of whether it has a new auto focus motor or not). Link to post Share on other sites More sharing options...
ocean2059 Posted February 19, 2022 Share #10 Posted February 19, 2022 (edited) I agree with others that this may be the best lens in the S line. I use mine hand-held pretty often. Here is an old one image with S2 (hand-held, ISO 160, 1/360. f/9.5) Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited February 19, 2022 by ocean2059 5 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/329959-leica-apo-macro-summarit-s-120mm25-asph-11070/?do=findComment&comment=4386973'>More sharing options...
Sailronin Posted February 20, 2022 Share #11 Posted February 20, 2022 The 120mm Macro-APO is probably my most used S lens. For landscape I use a tripod about half the time, always in the studio, but most of the time hand held. My Flickr site (David Reams) has an album of 120 macro Summarit if you're interested. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 5 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/329959-leica-apo-macro-summarit-s-120mm25-asph-11070/?do=findComment&comment=4387134'>More sharing options...
