Just getting used to my new M11 Monochrom. First week out with it... Full 60 mp, Zeiss Biogen 35mm lens.
Edited by geraldseligman
M11 + 35mm Summilux FLE
On 7/26/2025 at 5:33 AM, don daniel said:
In the Basel agglomeration, where I live, the conditions for Milky Way photography are extremely poor: there is simply too much light pollution. Nevertheless, it is possible to produce a DNG with the M11 and the Summicron 28mm (latest version), from which the Milky Way can then be made visible in Lightroom. Normally, I use the Z9 and the Nikkor Z20/1.8 for situations like this. That setup clearly produces less coma in the corners. But I was curious to try out the M11 as well. Now, I would need a lens that is more suitable for this purpose: wider angle, less coma, and as fast as possible. I don’t think I’ll find anything like that from Leica.
Leica has a nice 21mm f/1.4 that I use on my M11 it is only 1 mm. shorter in focal length than what you use with your Z9 and a little bit faster.
Summer heat In color
Leica M11 & Elmarit-M 28mm F/2.8 Asph
Trying to mount the learning curve of the M system.
M11p + Elmarit-M 28mm Asph
M11 APO Summicron 35mm f/2
Brewster Beach, MA, low tide Cape Cod, sunset twilight.
Edited by Wandering Photographer
Mystic, Conneticut M11 APO Summicron 35mm f/2
Am 8.8.2025 um 06:41 schrieb Wandering Photographer:
Do you use this lens for astrophotography, too? In my experience nearly all Summilux-M-lenses suffer from vignetting and coma when used wide open. M lenses are far from ideal for Milky Way photography. In this field, the M system simply can’t compete with the capabilities of the big camera brands — or even Leica’s own SL line.
vor 39 Minuten schrieb don daniel:
Do you have an idea why this is? Has that to do with the flange distance?
M11  Summilux-M 1:1,4 (2023)
vor 3 Stunden schrieb M11 for me:
I assume so, yes. If you build a system according to today’s demands for image quality, you naturally choose a flange distance that allows optical designs to be less critical when illuminating the edges and corners of the image. Even the Leica M Apo lenses show noticeable vignetting at wide open aperture, including the superb Apo-Summicron 35mm. You can never achieve perfectly illuminated corners at this flange distance when shooting wide open, especially not with ultra wide-angle lenses. If you simply look at the bayonet diameter of the Nikon Z or Leica SL, you see that completely different possibilities exist for illuminating the same-sized sensor.
Port Detroit
M11-D | 35mm APO Summicron
M11-D and 50mm Summilux ASPH at f5.6
M11P Ultron 90mm
Light a little more subtle than before..
Leica M11-P | Zeiss 35 1.4 ZM
Apo-Summicron-M 1:2/35 ASPH.
Beautiful shades of pink
M11-P,  Thypoch Simera 75mm f1.4 Asph
f1.4, ISO 64, 1/1250s
M11/Distagon 35mm f/1.4...
28 Elmarit
