RayD28 Posted December 25, 2021 Share #1 Posted December 25, 2021 Advertisement (gone after registration) I thought I loaded FP4+ @ ISO 125 and unloaded the roll and to my horror saw it was HP5+. I will use Ilford DD-X. Should I pull two stops or one using the Massive Development Chart? I shot with an M3 so I was using a Sekonic 308 and the ISO was set at 125. The light was Sunny f11 and I used the Sekonic for shade. I normally put a piece of the carton in the hotshoe so I don't make this kind of mistake, but not that day. Any and all advice appreciated. Link to post Share on other sites More sharing options...
Advertisement Posted December 25, 2021 Posted December 25, 2021 Hi RayD28, Take a look here Help! HP5+ Shot at ISO 125 by Accident. I'm sure you'll find what you were looking for!
250swb Posted December 25, 2021 Share #2 Posted December 25, 2021 I don't think DD-X will work, but refer to the Massive Dev Chart https://www.digitaltruth.com/devchart.php?Film=Ilford+HP5%&Developer=&mdc=Search&TempUnits=C&TimeUnits=D and you will see that taking it down to 100 ISO isn't out of this world, but you may need a different developer. If you can't find a combination to use look up HP5 in DD-X and take a 1+9 dilution and improvise from there. Unfortunately DD-X isn't the best developer for increased dilutions to compensate for over exposure, but you may be the guy that did the experiment that works, good luck. 1 Link to post Share on other sites More sharing options...
RayD28 Posted December 25, 2021 Author Share #3 Posted December 25, 2021 1 hour ago, 250swb said: I don't think DD-X will work, but refer to the Massive Dev Chart https://www.digitaltruth.com/devchart.php?Film=Ilford+HP5%&Developer=&mdc&TempUnits=C&TimeUnits=D and you will see that taking it down to 100 ISO isn't out of this world, but you may need a different developer. If you can't find a combination to use look up HP5 in DD-X and take a 1+9 dilution and improvise from there. Unfortunately DD-X isn't the best developer for increased dilutions to compensate for over exposure, but you may be the guy that did the experiment that works, good luck. Thanks, Steve. Some shots were low contrast (people in full sun) and some were medium contrast. Since HP5+ has a wide latitude I may develop @ 200 in DD-X (it's all I have) at 1:4 dilution and cut the developing time per the MDC to 5 minutes and use limited agitation. Maybe one gentle inversion every 60 seconds. We'll see how it goes. 1 Link to post Share on other sites More sharing options...
Pyrogallol Posted December 26, 2021 Share #4 Posted December 26, 2021 Try Ilford Perceptol. At 1:3 it is a speed reducing developer and HP5 would be rated at about 250 ISO which is closer to what you exposed it at. Perceptol gives nice smooth low grain negatives. 1 Link to post Share on other sites More sharing options...
Doug A Posted December 26, 2021 Share #5 Posted December 26, 2021 (edited) On 12/25/2021 at 2:22 PM, RayD28 said: Any and all advice appreciated. Are you wet printing or scanning? Based on my experience wet printing the old HP5 (no plus) two stops overexposure isn't a big deal. Reduce your regular development time with DD-X by 20% and keep everything else the same. You'll be fine. For scanning all bets are off. My experience with scanning HP5 Plus is that it is already at the ragged edge of overexposure at ISO 400. I'd follow the MDC advice for ISO 200 and hope for the best. It least I'd have someone to blame. 😀 Edited December 26, 2021 by Doug A Link to post Share on other sites More sharing options...
RayD28 Posted December 26, 2021 Author Share #6 Posted December 26, 2021 10 minutes ago, Doug A said: Are you wet printing or scanning? Based on my experience wet printing the old HP5 (no plus) two stops overexposure isn't a big deal. Reduce your regular development time with DD-X by 20% and keep everything else the same. You'll be fine. For scanning all bets are off. My experience with scanning HP5 Plus is that it is already at the ragged edge of overexposure at ISO 400. I'd follow the MDC advice for ISO 200 and hope for the best. It least I'd have someone to blame. 😀 Hey, Doug. Scanning. I'm sure the Lightroom sliders will be at the extreme ends. Link to post Share on other sites More sharing options...
Doug A Posted December 26, 2021 Share #7 Posted December 26, 2021 Advertisement (gone after registration) 1 hour ago, RayD28 said: Hey, Doug. Scanning. I'm sure the Lightroom sliders will be at the extreme ends. Been there. Done that. Good luck, and let us know how it works out. Link to post Share on other sites More sharing options...
Ornello Posted December 29, 2021 Share #8 Posted December 29, 2021 Reminds me of a time when I was working in a retail camera shop. A customer walked in with a roll of film to have it processed, and said: "Can you help me? I shoved my ASA!". 1 Link to post Share on other sites More sharing options...
RayD28 Posted January 31, 2022 Author Share #9 Posted January 31, 2022 On 12/25/2021 at 3:57 PM, 250swb said: I don't think DD-X will work, but refer to the Massive Dev Chart https://www.digitaltruth.com/devchart.php?Film=Ilford+HP5%&Developer=&mdc=Search&TempUnits=C&TimeUnits=D and you will see that taking it down to 100 ISO isn't out of this world, but you may need a different developer. If you can't find a combination to use look up HP5 in DD-X and take a 1+9 dilution and improvise from there. Unfortunately DD-X isn't the best developer for increased dilutions to compensate for over exposure, but you may be the guy that did the experiment that works, good luck. On 12/26/2021 at 2:51 PM, Doug A said: Are you wet printing or scanning? Based on my experience wet printing the old HP5 (no plus) two stops overexposure isn't a big deal. Reduce your regular development time with DD-X by 20% and keep everything else the same. You'll be fine. For scanning all bets are off. My experience with scanning HP5 Plus is that it is already at the ragged edge of overexposure at ISO 400. I'd follow the MDC advice for ISO 200 and hope for the best. It least I'd have someone to blame. 😀 On 12/26/2021 at 4:56 PM, Doug A said: Been there. Done that. Good luck, and let us know how it works out. Develop the film yesterday. Used Massive Development Chart for HP5+ @200 ISO shaved off 30 seconds using DD-X 1:4. Slow agitations at the start and two gentle inversions at the intervals. Thanks for all the suggestions. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/327803-help-hp5-shot-at-iso-125-by-accident/?do=findComment&comment=4372886'>More sharing options...
wizard Posted January 31, 2022 Share #10 Posted January 31, 2022 Well done, looks perfect to me. 1 Link to post Share on other sites More sharing options...
Doug A Posted January 31, 2022 Share #11 Posted January 31, 2022 Thank you for following up. It's good to know that HP5+ can take some overexposure. 2 Link to post Share on other sites More sharing options...
