Solsticephoto Posted December 19, 2021 Share #1 Posted December 19, 2021 Advertisement (gone after registration) In a recent shoot I was using a 28lux on my M10P and was disappointed by the performance of the lens. In trying to diagnose my unhappiness I noted I had the camera manually set for a 35mm/2 lens. When I look at the raw files in Lightroom they all show the correct lens -- 28lux. Question is whether there is any in camera manipulation based on the in camera lens setting prior to saving the image. Link to post Share on other sites More sharing options...
Advertisement Posted December 19, 2021 Posted December 19, 2021 Hi Solsticephoto, Take a look here Question About Lens Detection. I'm sure you'll find what you were looking for!
jdlaing Posted December 19, 2021 Share #2 Posted December 19, 2021 34 minutes ago, Solsticephoto said: In a recent shoot I was using a 28lux on my M10P and was disappointed by the performance of the lens. In trying to diagnose my unhappiness I noted I had the camera manually set for a 35mm/2 lens. When I look at the raw files in Lightroom they all show the correct lens -- 28lux. Question is whether there is any in camera manipulation based on the in camera lens setting prior to saving the image. Yes. There is. Link to post Share on other sites More sharing options...
Kwesi Posted December 19, 2021 Share #3 Posted December 19, 2021 (edited) 1 hour ago, Solsticephoto said: In a recent shoot I was using a 28lux on my M10P and was disappointed by the performance of the lens. In trying to diagnose my unhappiness I noted I had the camera manually set for a 35mm/2 lens. When I look at the raw files in Lightroom they all show the correct lens -- 28lux. Question is whether there is any in camera manipulation based on the in camera lens setting prior to saving the image. Hi Solsticephoto, there are some edge performance issues on a 28mm lens that are corrected in camera when the correct profile is selected. Which should have happened automatically with a Leica 28 lux as its 6 bit factory coded. Quick way to check is to review your 28lux photos in camera and look at which lens was selected Edited December 19, 2021 by Kwesi added "on a 28mm lens" Link to post Share on other sites More sharing options...
Solsticephoto Posted December 19, 2021 Author Share #4 Posted December 19, 2021 1 hour ago, Kwesi said: Hi Solsticephoto, there are some edge performance issues on a 28mm lens that are corrected in camera when the correct profile is selected. Which should have happened automatically with a Leica 28 lux as its 6 bit factory coded. Quick way to check is to review your 28lux photos in camera and look at which lens was selected thanks -- I'll have to do some test. Love your work and web site ! Link to post Share on other sites More sharing options...
Kwesi Posted December 19, 2021 Share #5 Posted December 19, 2021 1 hour ago, Solsticephoto said: thanks -- I'll have to do some test. Love your work and web site ! Thanks! It's all shot on digital M Leica's. The current homepage image was made on Halloween with the M10 P and 50 Lux ASPH Link to post Share on other sites More sharing options...
trisberg Posted December 20, 2021 Share #6 Posted December 20, 2021 12 hours ago, Solsticephoto said: In a recent shoot I was using a 28lux on my M10P and was disappointed by the performance of the lens. In trying to diagnose my unhappiness I noted I had the camera manually set for a 35mm/2 lens. When I look at the raw files in Lightroom they all show the correct lens -- 28lux. Question is whether there is any in camera manipulation based on the in camera lens setting prior to saving the image. If I put a 6-bit coded lens on my M10 I only have the options "Off" or "Auto", I don't see how you can set the lens selection to anything else, unless you have a lens without coding in which case you can manually set it. -Thomas Link to post Share on other sites More sharing options...
Solsticephoto Posted December 20, 2021 Author Share #7 Posted December 20, 2021 Advertisement (gone after registration) 22 minutes ago, trisberg said: If I put a 6-bit coded lens on my M10 I only have the options "Off" or "Auto", I don't see how you can set the lens selection to anything else, unless you have a lens without coding in which case you can manually set it. -Thomas I confirmed the same in my testing. I was switching back and forth from a 28lux and a zeiss 35/2 and thought the camera was stuck on the 35/2 setting but now cannot recreate the situation Link to post Share on other sites More sharing options...
