10 hours ago, Ouroboros said:
There's nothing in this thread that convinces me that this lens will produce an image any better than the average mobile 'phone can. 'Characterless' is probably the most polite description I would use.  Compared to a summaron, it's not even close to the ballpark
Yes, I can say that for most threads.  My mobile phone cannot take film, so that is all the convincing I need.
The biggest drawback of this lens for me is the lack of contrast wide open at f/5.6. It's fine if that's what you're after I guess. 28 Summaron at f/5.6 jumps off the screen by comparison. I think there there is a market for LLL to remake the Summaron at around $850 but with much better optics and coatings than the TTA.
I’m curious now.  I will take the same pic w all my m mount 28s at 5.6 and post the results when I have the time.
11 hours ago, Al Brown said:
@pippy presents some facts on character and the lack/need thereof in a post here.
Not 'facts', but a simple opinion with which I mainly agree, notwithstanding there are many people here who value lens 'character'.   I am of the opinion, not 'fact',  that most who buy the summaron-m do so primarily for it's well-known character, as I did.
In the context of comparing  the TTA with the summaron-m, which I assume is why the TTA was created; ie, a cheap and cheerful  Chinese look-alike alternative dressed up to resemble a summaron.
My opinion from what I've seen here and elsewhere is that the comparison begins and ends with visual similarities only.  The TTA does not seem to me to share the same character as the summaron.
Edited by Ouroboros
Yup, I’ve mentioned that numerous times.  The only similarity it has with the Summaron is physical appearance. The optical formula/number of elements etc is completely different.
It’s a $300 lens vs a $2800 lens and that is where expectations should be tempered.  I’ve mentioned this before but the only reason I bought it was because they released a black paint version which to me is stunning.  The fact that I am very happy w the results is icing on the cake.
If Leica sold the Summaron in bp as a regular model, I would have ponied up for that.  The silver doesn’t do it for me, and I have Summicron, Ultron II and Cv 28 3.5 if I want a different look.  The black Summaron, as it was a limited edition model, is now about $7000. And for me that is just silly.
2 hours ago, hdmesa said:
Even showing the TTA against itself at f/5.6 vs f/8 would be great.
Just for fun earlier on today I did a low-fi torture-test where I compared the TTA with a Voigtlander Ultron 28 f2 and a 28 Elmarit Asph v1. As the TTA only focusses down to 1m the snaps were shot at this distance(*). I used two apertures; f5.6 and f11.
As mentioned this was done as a 'just-for-fun' exercise to compare lenses and not an exhaustive Lines Per Millimetre test-session. For one thing the subject matter - books on three shelves of a bookcase - didn't have all the books on each shelf lined-up exactly on the front-edge of the shelves so there was some camera-to-subject variation going on(* again!) but, even so, it was easy to compare results as these variations were, if you like, a constant for all three lenses.
The results were as might be expected at a 100% pixel-peeping level. The Elmarit was sharper in the corners at both apertures. The Voigt. was half-way between the TTA and the Elmarit at f5.6 but by f11 these two were of a similar performance. Over the central-zone there wasn't really that much in it between any of the lenses at either aperture; certainly nothing which would make me think "I'd better not take that one out"...
Something else which should be bourne in mind is that the TTA was being used at MFD and Max. Aperture so was at a disadvantage straight away. If I get a chance I might try to do a similar test outdoors and with a more-usual (for me!) subject-matter.
Philip.
* The distance as measured from lens-to-central-subject-matter was actually 112cm. This distance, however, becomes 134cm from lens-to-top-left-corner-subject-matter which is an increase of some 20% so it was hardly surprising there was some softness as the lens wasn't focussed on that area of the image.
Edited by pippy
3 hours ago, Huss said:
.....I have Summicron, Ultron II and Cv 28 3.5 if I want a different look.
You already had a CV 28mm f3.5 skopar and you spent another $300 on that Chinese thing? Are you mad?  You could have bought a roll of Portra 400 and processed it instead! :D
The CV 28mm f3.5 is a very nice little lens,  especially in brassy black paint and it has a more sensible 39mm filter thread.  Such a good lens, in fact, that I never felt the need for a 28mm elmarit-m asph.
It is still one of CV's best ever and it's long past the time since it should have been reintroduced in ltm and M mount.
Philip.
Many thanks, your comments I think are what many of us suspected.
Philip.
The TTA 28 5.6 was plenty sharp for me wide open. It was the lower contrast wide open that I didn't like compared to the 28 Summaron reissue, which was super snappy even at 5.6. Maybe I wasn't shooting the TTA in the right light, though. I didn't have it for long.
Interesting to read that, hdmesa, because low-contrast has never been an issue when, in London, the sun makes an occasional appearance!
:lol:
The camera used for my play-time today was an M-D Typ-262 therefore nothing in terms of a lens' profile could be set so bearing that in mind, FWIW, here is a patchwork - grouped by pairs - made up from the f5.6 and f11 images mentioned earlier. DNG to JPEG conversion apart these (obviously lo-res) are effectively SOOC. Not much difference in terms of contrast to my eye between all three.
Which pair (Top and Lower are f5.6 and f11) is from which lens? Voigtlander / TTA / Elmarit ASPH are the candidates;
Philip.
Edited by pippy
:lol:
Philip.
I guess people in some parts of the world live low contrast lives, at least outdoors 😂
I've never shot the Elmarit, but if I had to guess, I'd say the TTA was in the center because it looks to improve from 5.6 to 11. The lens on the left looks like it was best at 5.6 and took a hit from diffraction at f/11, so I would guess that is the Ultron.
Edited by hdmesa
5 hours ago, hdmesa said:
...if I had to guess, I'd say the TTA was in the center because it looks to improve from 5.6 to 11. The lens on the left looks like it was best at 5.6 and took a hit from diffraction at f/11...
Although you have them slightly the wrong way around, hdmesa, your reasoning is (*AFAICR) spot-on. L-R they are Elmarit; Ultron; TTA.
It is the TTA which suffers most through diffraction probably (*again!) because at f11 the aperture is so tiny that by the time light has passed through there is an awful lot of work to do to cover the 36x24 frame without this amount of degradation in IQ. This is something I've noticed previously and with this lens I tend to stick to f8.
One thing which came out of this experiment was seeing by how much each lens required correction from barrel-distortion at this focussing-distance; a correction which I don't remember having to make with either of the lenses when using them under 'normal' conditions. Again it is the Elmarit which comes out on top receiving a +1 (at both apertures in P'shop). The Ultron was given a +2 (ditto) and the TTA had a +2 at f5.6 and +2.5 at f11.
As the images shown are effectively SOOC these changes had not been applied.
Philip.
* From such stuff as I can remember from 'Optics Theory and Lens Design' classes which, admittedly, took place a long time ago...
Edited by pippy
What Chinese thing are we talking about?  I'm expecting a BrightinStar 28 2.8 to be delivered today.
  • Haha 1
..The CV 28mm f3.5 is a very nice little lens,  especially in brassy black paint and it has a more sensible 39mm filter thread.  Such a good lens, in fact, that I never felt the need for a 28mm elmarit-m asph.
yeah, not sure why they haven't.
:lol:
Philip.
You have the most colourful selection of books!
  • Haha 1
  • 1 year later...
Posted (edited)
Just got my TT two weeks ago. I have the Black version. I tested it and really enjoy it.
My question, has anyone coded their lens and does the camera read the code?
I have tried coding it multiple times, but my M240 says UNCODED LENS, when in Automatic mode. I do have the last available firmware on this camera.
I have coded it correctly, as I have another lens that I coded, a Canon 135 f3.5, and the M240 reads it correctly. I used the same coder template and paint.
The code used was from Akaralabs lens code list 001011. It is listed for the Summaron 28mm f5.6.
Thank you in advance for any assistance with this.
Edited by SamMen
The 28mm Summaron-M may post-date the 240 and if so it will not be in the f/w. If you scroll through the lenses you can select manually you will know, if it is not there it will never be recognised. If it is there, keep trying!
Thank you pedaes for your response.
I was thinking tyhe same thing, as I have been browsing the forums. The reissue date for the Summaron was 2016, so I was hoping that the new firmware, from 2019?, would have incorporated this in the lens profiles.
 I guess not.
I will continue with my quest, until then, I will manually input the 28mm  f 2.8. If the quest fails, I will code the lens into submission, with the f2.8 coding, and go from there.
