Howdy,
Today I received my Marco Elmar and I was wondering whether there are slim rear lens caps available? 🤔
As apparent from the photo, the original lens cap unnecessarily increases the size of the 90 macro dwarf:
I don't think that we can link to eBay but if you put in the following as a search you should see what was produced in the past: Leica M Shallow Lens Cap. I assume it should fit.
The old one's are slimmer:
They were listed with catalogue no. 14051 or as IZQOO. You'll probably find them on the second hand market.
KEH in Atlanta often lists original Leica Leitz shallow rear lens caps, e.g., this one currently (with the three lugs which help in removing an LTM to M adaptor stuck on the camera's mounting flange):
https://www.keh.com/shop/leica-m-leica-plastic-thin-rear-lens-cap-229864.html
If buying an original Leica Leitz shallow cap from an ebay seller you should query the seller to ensure that the grey inner ring is properly set, i.e., not loose.
There are also third-party sellers of shallow metal rear lens caps for M mounts.
There are lower profile shiny plastic with grey insert M lens caps from the 1950s which sometimes turn up. Also even further back there were low profile LTM caps just before lenses became coupled. I would not have the remotest idea where low profile modern rear caps might be sourced. As far as I know Leica has had a 'one size fits all' policy on rear lens caps for some years now.
William
These are the ones that I was talking about. I have a few with grey plastic claws for the M bayonets. The little tabs at the back are useful for removing LTM adapters.
William
The newly released Thambar has a shallower back cap made of brass, it has an internal plastic insert and is quite heavy for a cap.  This is similar to the cap  IZQOO.
It will fit many lenses but not all, the 21mm, 24mm Summilux have rear lenses that extend further than the cap will allow, iirc.
https://leicastoremiami.com/products/leica-replacement-rear-lens-cap-for-thambar-m-90mm-f-2-2?variant=7334546145324
In addition to the above good solutions, you can 3D print (or have 3D printed) slim ones. Also, I designed my own double sided one that fits within the space of a standard one, suits my purposes, 3D printed it and works well.
  • 1 year later...
I recently acquired 3D-printed lens caps which seem to be as shallow as possible (thanks to Simon Forster). Now the 90 Macro Elmar has a light weight rear lens cap which matches its small size... 🙂  Don't understand that Leica does not pay attention to said detail.
  • 2 years later...
Am 24.5.2022 um 21:45 schrieb Robert Blanko:
Perfect - I am searching for such a shallow cap for my Macro-Elmar-M 90/4 as well!
From where did you acquire that? Or do you have a 3D file (STL etc.)?
vor 20 Minuten schrieb 3D-Kraft.com:
I bought this from Simon Forster which I found after some search on the Internet back then: https://forsteruk.com
I don't exactly remember whether he had the shallow design in stock or whether I told him to make a Leica mount rear cap (which he for sure offered) as shallow as possible.
If I would have a 3D printer file I would print this by myself, as I in the meantime also have a 3D printer.
