Lightroom aperture readings on M10 w/ Summicron
Hi everyone,
I apologize if this has been asked before; I searched the forum but couldn't find any previous topics like this.
Recently, I bought an M10. I notice that in Lightroom my 50MM Summicron, which has a maximum aperture of 2.0, has a reported aperture of sometimes as low as 1.2. An example of this oddity is as follows:
Is this normal behavior? Any thoughts?
Hello Chris,
Welcome to the Forum.
What you are reading as F 1.2 is 1:2 which is another way of writing: This is the relationship of the physical diameter of the lens to the physical length of the lens. The lens length is measured from the second nodal point of the lens to the film plane. One divided by two.
 Which can also be written as F 2
Best Regards,
Michael
Edited by Michael Geschlecht
14 minutes ago, hteasley said:
So it guesses, based on the histogram of the image.
Not exactly. As Leica states: “The camera compares the brightness measured through the lens with the measured ambient brightness to estimate the aperture used. This value is then written to the EXIF data. In some cases, the interpretation of the subject or scene may lead to incorrect estimation of the aperture value, for instance when shooting subjects or scenes with high contrast and black or white objects.”
The ambient light is measured by a sensor, which is incorporated in the little round window on the front of the camera.  I believe it’s also used for frame line brightness adjustment.
As a side note, Leica initially deleted this aperture ‘guess’ in EXIF for the M10, but reintroduced it via a FW update due to customer feedback.
Jeff
