Hey guys.
I looking for SL2 case.
what do you think Angelo Pelle?
another brand is Oberwarth.
actually german brand is expensive ( 400$ )
angelo pelle safari green is 200$ .
do you have any experience?
which better?
Brown is oberwarth
safari green is angelo pelle
For my Q2 I loved the case I had (Arte do Mano) and then switched to the RRS L plate with grip since I was using a tripod more.  With the SL2 I just have the RRS L plate on it  and don’t miss having a case - but, again, I use a tripod quite a bit.
On 11/27/2020 at 2:16 AM, caissa said:
I find a case for SL2 somehow unnecessary. (Even bad if I need to change the battery - not too rarely).  😇
Some of the half cases allow access to both battery and SD without removing. I even have mine set up with an attached RRS B9 plate for tripod use.
