The lack of a tilting display on the SL2 makes it  difficult to shoot from low or other than eye level angles. Has anyone tried to put a secondary display, say mounted on the flash shoe so that it becomes easy to see the with  low or difficult angles. I saw using the Atomos Ninja for also recording video. Can the iPhone mounted on the hot shoe be a possibility or any other display option?
Hi, the iPhone will work using fotos.  Even be able to trigger the capture from it.  Not sure I would want to though - unwieldy ?
You should have bought the S1R instead 🙂 That does not help, I know. I don't think that the phone option is very practical. If you have the idea of a low angle shot, you have to open the app, establish a connection between phone and camera and then you can shoot. That can be quite cumbersome.
This right angle finder attachment just became available...
https://leicastoremiami.com/products/leica-sl2-right-angle-finder?variant=34118046318723
Looks like this one for the SL....
https://leicastoremiami.com/products/leica-sl-typ-601-right-angle-finder-br?variant=11475471685
Jeff
There are quite a few small monitors that don't record video. You will find them much lighter/cheaper than the Ninja. Most come with adapter plates for Sony L-Mount or Canon batteries, so you'll have to add batteries and a charger to the price. You will also need some kind of mounting system if they don't come with a hotshoe mount, and a short HDMI cable.
It's best to try it out in a shop if you can. Some of the mounting systems are very poorly designed (hard to adjust).
