Apologies if this topic is already in the system by me, but for some reason I could not find what I had posted.
Anyway the issue I seem to be having since updating the firmware to v2.0 is that I have had a couple of crashes, or my camera locking up.  The on/off button does nothing, the OLED display and LCD are still on.  The only remedy to reset is to remove the battery.  So far its happened 3 times.  Anybody else experiencing this?
I suspect your SD card may be the culprit. I had similar issues until I changed SD cards. Try a different SD card.
Another point to consider-  are you perhaps using the same card that you downloaded the firmware to & if so did you format the card afterwards?
Thanks for the suggestion.  Both cards are newer than the upgrade, both Sony Tough G Series.  I will reformat them again and keep and eye out.  The upgrade was done and nothing untoward happened until a couple of weeks ago.  Its not a frequent issue which is more frustrating and harder to isolate.
If my memory serves me correctly (I may be wrong) I seem to remember reading somewhere that there were issues with the Sony Tough cards.
Edit- Here's a link regarding a recall on Sony cards, the problem appears to apply to video, but could be an issue in any event-
Sony Recalls TOUGH SD Cards Due to Data Corruption
For good measure try another brand of card & see if the problem comes up again.
Edited by michali
Thank you again.  I did see this issue a while back and checked my cards were not part of the recall.  I agree, perhaps a time using my other Sandisk cards to see if the issue is still there.
  • 2 weeks later...
Within 14 days after the first contact I received a replacement card from another production batch. What surprised me was that this card and the plastic case were not in the original packaging in which the cards were found when I bought them new.
I hope the error will not occur again.
1 hour ago, Max EPR said:
I am also having similar SL2 lockup issues. Although not for the past 5 days since I followed the Leica Service suggestion to reformat my 128GB V90 Sony and ProGrade cards with "SD Card Formatter" https://www.sdcard.org/downloads/formatter/.
Hopefully this solved the issue.
I will also try this formatting tool. Thank you.
On 7/9/2020 at 22:48, Max EPR said:
Ho anche problemi di blocco SL2 simili. Anche se non negli ultimi 5 giorni da quando ho seguito il suggerimento del servizio Leica di riformattare le mie schede Sony e ProGrade V90 da 128 GB con "SD Card Formatter" https://www.sdcard.org/downloads/formatter/.
Si spera che questo abbia risolto il problema.
After 4 months of life of my SL2 sent today to Leica Wetzlar for repeated blockages........ still hard to believe that this could happen to such an expensive camera. I also replaced the SDXC with the most expensive ones on the market
Lucio did you get your camera back yet? What did Leica report back? I'm having the same issue.
  • 2 weeks later...
