Showing results for tags '2.0'.
Apologies if this topic is already in the system by me, but for some reason I could not find what I had posted. Anyway the issue I seem to be having since updating the firmware to v2.0 is that I have had a couple of crashes, or my camera locking up. The on/off button does nothing, the OLED display and LCD are still on. The only remedy to reset is to remove the battery. So far its happened 3 times. Anybody else experiencing this?
First, DNG automatic noise reduction set or no switch. Second, SL is the 1.1 firmware in the M file to support the wireless flash, upgrade 1.2 and 2 firmware can not use the PROFOTO Wireless Flash (TTL-C Canon) and Canon ST-E3 wireless flash. 1.2 and 2 firmware Canon 600EX top flash can be used, PROFOTO wireless single point and (TTL-N Nikon) flash can be used. It seems only for the camera. 第一,DNG自动降噪设置还是没有开关。第二,SL是1.1固件在M档支持无线引闪,升级1.2和2.0固件无法使用PROFOTO无线引闪器(TTL-C佳能)和佳能ST-E3无线引闪器。1.2和2.0固件佳能600EX机顶闪光灯可以使用,PROFOTO无线单点和(TTL-N尼康)引闪器可以使用。看来只有换相机了。
