not for me; it would be as if leica also started offering a leica monochrome that could also take color pictures, etc; it would rob the leica q of its   'deliberate'   caracter and move it into the direction of the many wonderful cameras that  'can do it all'  and thereby may seduce you to try to exploit all the camera's available features instead of honing your ability to recognize interesting scenes;
11 hours ago, Einst_Stein said:
JI am tempted by Q2, although I have no real need. But need is a subjective term.
Wouldnt it be good if a Q VArio is available! Say, the Q2 but replaced with a 28-75mm f4 lens! Or 28-50mm f2.8!
But one of the Q's USPs if not the main characteristic is the fast lens.
19 minutes ago, AndrewDD said:
A zoom lens is either slow, short, or huge (usually 2 of the 3) because... physics.
That's why the X Vario didn't really work.
Don't understand what you mean by "didn't really work".
I am not sure how much it means, but the XV image thread has far more posts than the combination of X1, X2, X113, XU. (XV: 3380, X1: 1280; X2: 407; XU: 63; X113: 944).
This is the same argument of XV vs. X1/2/113.
But if the number of image posts in this site means popularity or photo productive, XV out-runs significantly than the combination of X1/X2/X113/XU.
It already happened, The XV.
QV, if exists, is simply the full frame version of XV.  You can't argue against Leica on XV, can you?
It wasn't popular and went out of production pretty quickly
It didn't really work commercially. The camera was too large (and expensive) to compete with D-Lux cameras. Sensor size is of little interest to potential buyers, outside Internet blogs and forums; "standard" customers have other criteria, like size, price, haptics in relationship to results. The relative length of image threads is a wobbly measure - it only takes a few enthusiastic posters to make them grow.
Q2 can be used as follows using crop mode (I list equivalent aperture for depth of field and cropped resolution).
28mm  f1.7   47MP
35mm  f2.1   30MP
50mm  f3.0   15MP
75mm  f4.5    6.6MP
So if you do not mind the reduction in resolution, I think it can be used fine for what you described.
28mm  f1.7   47MP
35mm  f2.1   30MP
50mm  f3.0   15MP
75mm  f4.5    6.6MP
This is what I do.
28mm  f1.7   47MP
35mm  f2.1   30MP
50mm  f3.0   15MP
75mm  f4.5    6.6MP
The equivalent aperture does NOT apply to lens speed,that is a constant. It is a DOF equivalent if you shift subject distance, nothing more.
Zoom lens on a fixed lens camera probably makes sense on a smaller camera like the D-lux 7.  By the time you have a zoom lens that is decently fast with reasonable range, it will be too big for a fixed lens.  SL 24-90 will be a good reference point.  I doubt Leica willing to make any full-frame AF lens that is not sharp corner to corner, and that means large lens.  For Q2, 50mm/F3 equivalent is still pretty usable both in boken and resolution. I doubt many people will go for a vario Q.
