dkCambridgeshire Posted June 27, 2020 Share #1 Posted June 27, 2020 Advertisement (gone after registration) 1000mm to 2000mm IBIS ... needed same when using 800mm with 2x extender ... photographing wading birds at 100m distance . I used a cable release and 2 sec self timer with IBIS switched off. dunk Link to post Share on other sites More sharing options...
Advertisement Posted June 27, 2020 Posted June 27, 2020 Hi dkCambridgeshire, Take a look here Panasonic S1 / S1R firmware request. I'm sure you'll find what you were looking for!
tom.w.bn Posted June 27, 2020 Share #2 Posted June 27, 2020 I doubt that anyone at Panasonic looks here but just in case..... I would like to have a proper support for long time exposures. 60sec. is the longest time you can dial in manually. For everything longer you have to use bulb. a) I want to manually pick the time from 60sec. up to the maximum time in usable increments b) when using bulb I want to have a timer that's visible at night. The shoulder display light goes off automatically when the shutter is pressed. No chance to see the timer in the shoulder display. Even better would a small counter on the otherwise black LCD display. 1 Link to post Share on other sites More sharing options...
SrMi Posted June 29, 2020 Share #3 Posted June 29, 2020 On 6/27/2020 at 12:16 PM, dkCambridgeshire said: 1000mm to 2000mm IBIS ... needed same when using 800mm with 2x extender ... photographing wading birds at 100m distance . I used a cable release and 2 sec self timer with IBIS switched off. dunk There is no space for sensor to move that much to compensate for 1000mm lens movements. Link to post Share on other sites More sharing options...
Kenb Posted July 9, 2020 Share #4 Posted July 9, 2020 I want the live composite update on my S1 had that on a omd-em1, and miss it. Panasonic has added it to m4/3 Link to post Share on other sites More sharing options...
