cboy Posted May 10, 2020 Share #1 Posted May 10, 2020 Advertisement (gone after registration) Hi hello I'm new to the forum. I just wanting to know is it possible to fix or replace a small dent on the 50 summicron v5 lens hood? . The one with the slide out hood Thanks Link to post Share on other sites More sharing options...
Advertisement Posted May 10, 2020 Posted May 10, 2020 Hi cboy, Take a look here Dent on 50 summicron lens hood? Replacement?. I'm sure you'll find what you were looking for!
cboy Posted May 11, 2020 Author Share #2 Posted May 11, 2020 here is a pic of the dent... Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/309383-dent-on-50-summicron-lens-hood-replacement/?do=findComment&comment=3971066'>More sharing options...
Stealth3kpl Posted May 11, 2020 Share #3 Posted May 11, 2020 (edited) I would try to reshape it with my thumbs. It's a poor hood, and I tend to use something like this instead Pete Edited May 11, 2020 by Stealth3kpl Link to post Share on other sites More sharing options...
cboy Posted May 11, 2020 Author Share #4 Posted May 11, 2020 I heard ABS plastic can be bent with hotwater. is it safe to use or will thhe heat will atomise the grease which could lead to haze... Link to post Share on other sites More sharing options...
jaapv Posted May 11, 2020 Share #5 Posted May 11, 2020 Send it to a reputed Leica repair shop. They will remove the hood (not too difficult), reshape it or replace it. Link to post Share on other sites More sharing options...
250swb Posted May 11, 2020 Share #6 Posted May 11, 2020 (edited) 4 hours ago, cboy said: I heard ABS plastic can be bent with hotwater. is it safe to use or will thhe heat will atomise the grease which could lead to haze... It's metal, that is why it bent and didn't bounce back like ABS. A repair guy will fix it for you, otherwise do as suggested, push it back to almost a round shape and instead use a metal hood from eBay. Edited May 11, 2020 by 250swb Link to post Share on other sites More sharing options...
Ko.Fe. Posted May 12, 2020 Share #7 Posted May 12, 2020 Advertisement (gone after registration) One of the methods. http://forum.mflenses.com/bent-filter-ring-repair-technique-t46159.html Tool: https://www.amazon.com/DSLRKIT-Repair-Filter-Ajustment-Steel/dp/B00SYBYTZO 1 Link to post Share on other sites More sharing options...
