lmans Posted April 15, 2020 Share #1 Posted April 15, 2020 Advertisement (gone after registration) I have a 1962 M3 with the standard 50mm lens.... I would like to shoot some nature with a longer lens...up to 300mm or 400 if possible. Any suggestions? What brand of lens might work and would I need some adapter to fit my camera? Much appreciated.... jim Link to post Share on other sites More sharing options...
Advertisement Posted April 15, 2020 Posted April 15, 2020 Hi lmans, Take a look here M3 with Long Lens. I'm sure you'll find what you were looking for!
Pyrogallol Posted April 15, 2020 Share #2 Posted April 15, 2020 (edited) You would need a Visoflex adaptor and various other bits and pieces to use a lens longer than 135mm on an M3. Interesting and fun to acquire, but not ideal. See if a 135mm will suit what you want, if not a conventional film SLR would be more practical to use or a digital camera that lets you view the image through the lens. Edited April 15, 2020 by Pyrogallol 1 Link to post Share on other sites More sharing options...
lmans Posted April 15, 2020 Author Share #3 Posted April 15, 2020 (edited) 16 minutes ago, Pyrogallol said: You would need a Visoflex adaptor and various other bits and pieces to use a lens longer than 135mm on an M3. Interesting and fun to acquire, but not ideal. See if a 135mm will suit what you want, if not a conventional film SLR would be more practical to use or a digital camera that lets you view the image through the lens. Thanks....Yes...135 tops for the camera w/o adaptors etc...but doable. Is there a difference between the Tele-Elmar and just Elmar 135mm.? There are several on Ebay and will take a look. Fairly in-expensive to pick up and would be a challenge for sure, ....jim Edited April 15, 2020 by lmans Link to post Share on other sites More sharing options...
jankap Posted April 15, 2020 Share #4 Posted April 15, 2020 Must it be film? Would a Leica CL (with a crop sensor) not be better? You could still use M-lenses (with an adapter). Your 50mm lens - for instance - would serve as a 75mm (eq). Link to post Share on other sites More sharing options...
lmans Posted April 15, 2020 Author Share #5 Posted April 15, 2020 (edited) Probably work better but I have my old M3 ...want to use this. It would be a challenge but more a composition challenge as I want to shoot wildlife. not so much as getting up close and personal as we do now with digital wildlife photography but more , habitat, general lay of land....bird within image and central but more 1940's style images...and yes, film and all I have at the moment is BW but can always purchase color but I like the idea of artfully done BW. I am burnt out on anything digital... Edited April 15, 2020 by lmans 1 Link to post Share on other sites More sharing options...
jaapv Posted April 15, 2020 Share #6 Posted April 15, 2020 Any lens on the Visoflex3. I have used the Noflexar-T 400 in Visosflex mount /Pigriff with good success, but both Telyt-V 400 and 560 are excellent options. If you are looking at the Telyt-V 280, make sure you get version 3, it is better optically. easiest to focus using a Televit quick-focus mount. I was less impressed with the Telyt-V 200. Noflexar-T 400 on M8: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/308572-m3-with-long-lens/?do=findComment&comment=3954350'>More sharing options...
Lmax Posted April 15, 2020 Share #7 Posted April 15, 2020 (edited) Advertisement (gone after registration) You asked: The Elmar 4/135 (1960-1965) was a good lens, the Tele-Elmar 4/135 (1965-1985 and 1992-1998, only differing in barrel-design) was a really superb lens. Edited April 15, 2020 by Lmax 1 Link to post Share on other sites More sharing options...
TomB_tx Posted April 15, 2020 Share #8 Posted April 15, 2020 Agree with Lmax - the Tele-Elmar 135 is an excellent lens, and quite usable on the M3 without any adapters. 1 Link to post Share on other sites More sharing options...
Pyrogallol Posted April 15, 2020 Share #9 Posted April 15, 2020 4 hours ago, lmans said: Thanks....Yes...135 tops for the camera w/o adaptors etc...but doable. Is there a difference between the Tele-Elmar and just Elmar 135mm.? There are several on Ebay and will take a look. Fairly in-expensive to pick up and would be a challenge for sure, ....jim The use of the term “Tele” in a lens name indicates that the lens is physically shorter than its given length, as a result of the optical design. In the old days a 135mm lens would be around 135mm long and should really be called a “long focus” lens. But these days people call any lens longer than the standard a “Tele” or “telephoto” lens, but modern lenses are probably all actually shorter than their nominal length, so “Tele” is probably right anyway. With Leica lenses “Tele” does indicate a shorter length than the older non “Tele” versions. Link to post Share on other sites More sharing options...
spydrxx Posted April 15, 2020 Share #10 Posted April 15, 2020 The 135 Tele-Elmar (early version) is a superb lens, originally designed for use by the US Navy for reconnaissance work, before being made available to the public. Some people find it difficult to focus on M2-3-4 bodies, but I've used one for many years with no trouble. Other feature is the head is removable for use on the Visoflex (or some other cameras), turning it into a SLR lens. Later version, although sharper doesn't have a removable head. If you're really into nature (like birds and small mammals), the Telyt 400/6.8 used in conjunction with a Visoflex on your M3 is the ticket...nice and sharp in the center fading sharpness as you move away from center. If you're really cheap (frugal) an old Spiratone 400/6.3 can be cut down and fitted with an M fitting for use on the Visoflex & M3 as well, and delivers just about as well as the equivalent Telyt...especially stopped down 1 notch to f/8. 1 Link to post Share on other sites More sharing options...
J.Nordvik Posted April 15, 2020 Share #11 Posted April 15, 2020 1970 Tele-Elmar Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/308572-m3-with-long-lens/?do=findComment&comment=3954582'>More sharing options...
J.Nordvik Posted April 15, 2020 Share #12 Posted April 15, 2020 1970 Tele-Elmar Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 2 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/308572-m3-with-long-lens/?do=findComment&comment=3954583'>More sharing options...
J.Nordvik Posted April 15, 2020 Share #13 Posted April 15, 2020 "The 135 Tele-Elmar (early version) is a superb lens, originally designed for use by the US Navy for reconnaissance work" That sounds like the APO-Telyt R 3,4/180mm. Link to post Share on other sites More sharing options...
jankap Posted April 16, 2020 Share #14 Posted April 16, 2020 (edited) Something like this: https://frankencamera.wordpress.com/2020/01/27/leica-m3-digital-conversion-kit/ This does not solve any of the problems using a rangefinder camera with long lenses. But is not it interesting? Edited April 16, 2020 by jankap Link to post Share on other sites More sharing options...
