heobro Posted April 6, 2020 Share #1 Posted April 6, 2020 (edited) Advertisement (gone after registration) The square box position inside the viewfiner is range It seems to have moved slightly to the right and you can see the space in the marked area. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited April 6, 2020 by heobro Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/308267-the-square-box-position-inside-the-finder-is-strange/?do=findComment&comment=3948253'>More sharing options...
Advertisement Posted April 6, 2020 Posted April 6, 2020 Hi heobro, Take a look here The square box position inside the finder is strange. I'm sure you'll find what you were looking for!
AndreasG Posted April 6, 2020 Share #2 Posted April 6, 2020 Sorry, what is your concern, I don't understand the point? 1 Link to post Share on other sites More sharing options...
mujk Posted April 6, 2020 Share #3 Posted April 6, 2020 I can see what you mean. It looks like the black mask in the ocular not being perfectly centered. Mine seems to be ever so slightly off in the opposite direction than yours and also somewhat off vertically. I don't think it has any effect on viewfinder FOV or rangefinder precision. Link to post Share on other sites More sharing options...
250swb Posted April 6, 2020 Share #4 Posted April 6, 2020 (edited) What 'space' do you see? I have absolutely no idea what you are trying to show me, are you saying this is what you see through the viewfinder, or what you see when the window itself is photographed? Is the problem, whatever it is, when you photograph the viewfinder window, or when you look through the viewfinder? Edited April 6, 2020 by 250swb Link to post Share on other sites More sharing options...
Good To Be Retired Posted April 6, 2020 Share #5 Posted April 6, 2020 (edited) I understand you are referring to the mask just inside the eyepiece, is that correct? It does appear to be slightly off center, but unless is continues to move and becomes an annoyance I don't think it will make any difference. I had not ever thought about this particular issue until you mentioned it, but mine seems off a tad in the opposite direction and I had never noticed. With a 28 mm lens mounted can you still see all the frame lines? If so, I suspect I'd just ignore it. Unless you're comfortable pulling the top off, which I'm told is not really that big a job. Then I assume you could move it back. If you are referring to the rangefinder patch that's different. Edited April 6, 2020 by Good To Be Retired Link to post Share on other sites More sharing options...
earleygallery Posted April 6, 2020 Share #6 Posted April 6, 2020 The grain on your leatherette covering looks most irregular. Have you asked Leica about it? Link to post Share on other sites More sharing options...
heobro Posted April 7, 2020 Author Share #7 Posted April 7, 2020 Advertisement (gone after registration) 3 hours ago, 250swb said: 어떤 '공간'이 보입니까? 나는 당신이 나에게 무엇을 보여 주려고하는지 전혀 모른다. 당신은 이것이 뷰 파인더를 통해 보는 것입니까, 아니면 창 자체가 사진을 찍을 때 보는 것입니까? 뷰 파인더 창을 촬영할 때 또는 뷰 파인더를 통해 볼 때 문제가 무엇입니까? There is space on the left side of the viewfinder. However, there is no space in the right viewfinder. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/308267-the-square-box-position-inside-the-finder-is-strange/?do=findComment&comment=3948566'>More sharing options...
heobro Posted April 7, 2020 Author Share #8 Posted April 7, 2020 8 hours ago, AndreasG said: 죄송합니다, 당신의 걱정은 무엇입니까, 요점을 이해하지 못합니까? I uploaded the detailed picture again. Please check it out. Link to post Share on other sites More sharing options...
heobro Posted April 7, 2020 Author Share #9 Posted April 7, 2020 2 hours ago, earleygallery said: 인조 가죽 덮개의 결이 가장 불규칙하게 보입니다. 라이카에게 물어 봤어? That's a protective film. Link to post Share on other sites More sharing options...
roverover Posted April 7, 2020 Share #10 Posted April 7, 2020 1 hour ago, heobro said: I uploaded the detailed picture again. Please check it out. I just looked at my M10 and i see the same slight space on the left side of on mine too. I suspect this is normal. Link to post Share on other sites More sharing options...
heobro Posted April 7, 2020 Author Share #11 Posted April 7, 2020 1 minute ago, roverover said: 방금 M10을 보았는데 왼쪽에 동일한 공간이 있습니다. 나는 이것이 정상이라고 생각합니다. I called Service Center Lieca I was answered that it was no problem. thank you! 1 Link to post Share on other sites More sharing options...
lucerne Posted April 7, 2020 Share #12 Posted April 7, 2020 9 hours ago, heobro said: There is space on the left side of the viewfinder. However, there is no space in the right viewfinder. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Please correct me if I am wrong. Is this is a factory standard/unmodified M10 body?? .It doesn't look right. Not Leica manufacturing. Has Someone modified the top plate around the eyepiece and left edge of the body and not reassembled everything correctly. It has a film of non-smooth plastic added on the top plate. Is this normal on a black body???? You can see where it ends halfway across the eyepiece . I only have a silver M10 (which doesn't have this) so I may be wrong. Very interesting. The OP needs to know the history of this M10. Link to post Share on other sites More sharing options...
AndreasG Posted April 7, 2020 Share #13 Posted April 7, 2020 vor 10 Minuten schrieb lucerne: It has a film of non-smooth plastic added on the top plate. Is this normal on a black body???? You can see where it ends halfway across the eyepiece . Yes indeed, looks like a homemade additional strap protector, or did an early owner try hide some damages? Link to post Share on other sites More sharing options...
heobro Posted April 7, 2020 Author Share #14 Posted April 7, 2020 4 hours ago, AndreasG said: Yes indeed, looks like a homemade additional strap protector, or did an early owner try hide some damages? This is the film I put on. There is no protective film attached to the right. Link to post Share on other sites More sharing options...
heobro Posted April 7, 2020 Author Share #15 Posted April 7, 2020 4 hours ago, AndreasG said: Yes indeed, looks like a homemade additional strap protector, or did an early owner try hide some damages? I called the service center and it wasn't. Link to post Share on other sites More sharing options...
heobro Posted April 7, 2020 Author Share #16 Posted April 7, 2020 4 hours ago, lucerne said: Please correct me if I am wrong. Is this is a factory standard/unmodified M10 body?? .It doesn't look right. Not Leica manufacturing. Has Someone modified the top plate around the eyepiece and left edge of the body and not reassembled everything correctly. It has a film of non-smooth plastic added on the top plate. Is this normal on a black body???? You can see where it ends halfway across the eyepiece . I only have a silver M10 (which doesn't have this) so I may be wrong. Very interesting. The OP needs to know the history of this M10. I put on a protective film and quit. Link to post Share on other sites More sharing options...
