As I am currently stuck home (like most of us), I began toying around with some video.
Now, the internal microphone is obviously not all that great, but for some reason my external microphone, when connected to the microphone plug, does not work at all. It works perfectly well on my Sony, but doesn't record a single ping with the SL2.
I digged through the manual, but other than the noise cancelation settings, there is not even a single mention of any specifications for external microphones.
Am I missing anything here?
I just plugged in my Rode mic in the mic port and it works perfectly after switching the mic on.
In the video screen the is a mic icon to change the levels, but if you are not getting anything there must be a connection issue .
I suppose you are using a powered mic that does not need phantom power since you where using it on the Sony ?
vor 3 Stunden schrieb Photoworks:
Yep, using a little attachable mic with it's own power source. Do you think that's the problem?
1 hour ago, scott kirkpatrick said:
If your mic is powered you don't have the problem of needing phantom power  But test it by recording with it plugged into your phone to make sure it's working.
hummm , not sure what phone you are using ;-) , my phone has removed all the plug options
It's hard to make suggestions without seeing the actual mic.  Mics with 1/8" plugs would not have phantom power.  The on-camera mics are not bad if the camera is isolated on a tripod, and for a better mic I use a preamp and even an external recorder, which lets me see on the VU meter if things are working.
vor 11 Stunden schrieb scott kirkpatrick:
Well..here's the thing. It is powered! It works on my pc, it works on my sony, it doesn't work on my phone and neither on my SL2.
I just kind of hate the guesswork.
The name of the microphone is "PLOTURE Lavalier-Mikrofon". It's a cheap piece of gear I still had around.
I don't mind buying a new one, but I don't even know where to start. I'd asumed a simple lavalier mikrofon with its own power source would do the job and there's no big science around it.
I'll try with my SL2.  I have some good lavaliere mics, but they are in my office and I can't get there until we loosen our lockdown rules.  I have recorded into the SL using a preamp from Sound Devices, whose output goes into a 1/8" plug (and then into the SL's audio adapter cord.  I'll have to see if it works on the SL2 as well.  At least this gives me the ability to hear the microphone signal both before and after it reaches the camera and is recorded into the video.
You really should report this to Leica Customer Service and let them tell you if there are any recommended microphones or other characteristics to look for.
Did the same this week when I wanted to try some video - not what I usually do.  Plugged in a Rode Stereo VideoMicv Pro Rycote I just happened to have lying around.  Worked really well.  So much better than the built-in microphone in the SL2.
Looking at your Lav mic PLOTURE Lavalier-Mikrofon, it looks like the issue is the plug. you are using a TRRS plug, and you should be using TRS.
I assume the last contact is occupied by something else like cable release
Edited by Photoworks
vor 14 Minuten schrieb Photoworks:
Thx for that. Where did you find the info about the trs plug? My (german) manual only says "Audio-Out 3,5 mm"
For unbalanced stereo audio gear, the usual pinout is the TRS, even for a mono device like a lav mic.  Cables that I have for mixer/preamp/recorder to camera are all TRS.  Did your  mic come as part of some more complicated control system that would have used the extra ring?  Audio capture is a real afterthought on the SL2.  There is no entry under "audio" in the manual's index.  Under sound there are two entries, one of which sets the loudness of the shutter sound.  The other describes touch input to set sound levels.  There are nice sound level meters at the top of the info screen when you are in video.  For the plug it just says "3.5 mm stereo."
Edited by scott kirkpatrick
2 hours ago, NOERML said:
Thx for that help.
just don't understand why they don't provide that simple information in the user manual.
the TRRS became popular for phones like the iPhone , adding the last ring for the remote control on the headphones. you probably got a mic that is multi use, mostly for mobile devices.
The standard mic is a TRS
Solution is to get a TRRS to TRS adapter.
https://www.amazon.com/Rode-SC3-3-5mm-TRRS-Adaptor/dp/B00L6C8PNU
vor 2 Stunden schrieb Photoworks:
Yeah. I ordered that already as soon as you gave me the trs hint.
vor 2 Stunden schrieb scott kirkpatrick:
Well obviously the SL2 wouldn't be my prime choice for video and I'm aware that, as you say, it's merely an aftethought for this camera. Just am playing around with a bit of video cuz of the lockdown.
And I willingly admit, I know nothing about it as well. But that's probably why I expected a tiny bit more details. Anyways, guess it's solved now :)
