Jan1985 Posted March 2, 2020 Share #1 Posted March 2, 2020 Advertisement (gone after registration) What you guys think is a reasonable for a 120mm Summarit-S CS Version with fixed AF Motor? Link to post Share on other sites More sharing options...
Advertisement Posted March 2, 2020 Posted March 2, 2020 Hi Jan1985, Take a look here Reasonable Price for 120mm CS . I'm sure you'll find what you were looking for!
davidmknoble Posted March 2, 2020 Share #2 Posted March 2, 2020 1 hour ago, Jan1985 said: What you guys think is a reasonable for a 120mm Summarit-S CS Version with fixed AF Motor? Not totally sure today, but I've seen the 30 and 35 for about $3,295 USD with a new motor in great shape, box, caps, case. So, I would think because the 120 was the same generation of lens that it would be similar... Link to post Share on other sites More sharing options...
Jeff S Posted March 2, 2020 Share #3 Posted March 2, 2020 The CS version currently seems far less common on the used market, at least in the US, so prices might be higher than the $3-3.5k level generally available here for the non CS lenses. Jeff Link to post Share on other sites More sharing options...
davidmknoble Posted March 2, 2020 Share #4 Posted March 2, 2020 5 hours ago, Jan1985 said: What you guys think is a reasonable for a 120mm Summarit-S CS Version with fixed AF Motor? Are you looking for a CS version because of studio flash work, or just because? Curious... Link to post Share on other sites More sharing options...
Jan1985 Posted March 2, 2020 Author Share #5 Posted March 2, 2020 vor 2 Minuten schrieb davidmknoble: Are you looking for a CS version because of studio flash work, or just because? Curious... I have CS version for sale.. Because I want to buy a 100mm... To keep both makes no sense... 1 Link to post Share on other sites More sharing options...
Milan_S Posted March 3, 2020 Share #6 Posted March 3, 2020 16 hours ago, Jan1985 said: I have CS version for sale.. Because I want to buy a 100mm... To keep both makes no sense... Maybe we can do a swap I would like the 120mm CS but it must be a in great condition and new motor and no focus issues. My 100mm f2 just returned from Wetzlar with perfect focusing. 1 Link to post Share on other sites More sharing options...
setuporg Posted March 9, 2020 Share #7 Posted March 9, 2020 Advertisement (gone after registration) On 3/3/2020 at 6:27 AM, Milan_S said: My 100mm f2 just returned from Wetzlar with perfect focusing. Have you sent both the lens and the body to tune up? Link to post Share on other sites More sharing options...
Milan_S Posted March 16, 2020 Share #8 Posted March 16, 2020 On 3/9/2020 at 5:52 AM, setuporg said: Have you sent both the lens and the body to tune up? indeed both camera and lens and now it focuses wonderful wide open! 1 Link to post Share on other sites More sharing options...
setuporg Posted March 16, 2020 Share #9 Posted March 16, 2020 9 hours ago, Milan_S said: indeed both camera and lens and now it focuses wonderful wide open! How much was it to tune? Did you go through a local dealer to ship/order? Lucky you did this before the whole world end thing:) Link to post Share on other sites More sharing options...
darylgo Posted March 18, 2020 Share #10 Posted March 18, 2020 On 3/8/2020 at 9:52 PM, setuporg said: Have you sent both the lens and the body to tune up? Pardon the change in direction. Does the body and lens need to be tuned to each other for perfect focus? Link to post Share on other sites More sharing options...
davidmknoble Posted March 18, 2020 Share #11 Posted March 18, 2020 3 hours ago, darylgo said: Pardon the change in direction. Does the body and lens need to be tuned to each other for perfect focus? @darylgo, typically the S does not need to have both tuned to each other. I have not had any problems with the 120mm or the 180mm out of the box. However, if one is out of tolerance, it is always possible the other is also, which can cause problems. Mirrors, simply because the flip up and down, have historically needed more frequent adjustments than mirrorless systems. But, I have never had to send my S007 or a lens in for adjustment. Link to post Share on other sites More sharing options...
darylgo Posted March 18, 2020 Share #12 Posted March 18, 2020 2 hours ago, davidmknoble said: @darylgo, typically the S does not need to have both tuned to each other. I have not had any problems with the 120mm or the 180mm out of the box. However, if one is out of tolerance, it is always possible the other is also, which can cause problems. Mirrors, simply because the flip up and down, have historically needed more frequent adjustments than mirrorless systems. But, I have never had to send my S007 or a lens in for adjustment. Thanks David, my S bodies and lenses seem to play well together, the one exception is the 180mm focus. I'm constantly sending M equipment back for adjustment, the idea that S lenses could be adjusted never occurred to me. Link to post Share on other sites More sharing options...
davidmknoble Posted March 18, 2020 Share #13 Posted March 18, 2020 1 minute ago, darylgo said: Thanks David, my S bodies and lenses seem to play well together, the one exception is the 180mm focus. I'm constantly sending M equipment back for adjustment, the idea that S lenses could be adjusted never occurred to me. I understand - I have matched M bodies to lenses before, the APO 90 'cron was the worst and I finally got rid of the lens. My Noctilux 1.0 works perfectly .. just tolerances. I've not had an S lens that needed adjustment, but truth be told, I've purchased all but one used, after a CLA with a new motor. So, I guess Leica probably set it to tolerance then. I love the 180mm - hope you get that working as it needs to be! 1 Link to post Share on other sites More sharing options...
