wilfredo Posted January 18, 2020 Share #1 Posted January 18, 2020 Advertisement (gone after registration) I’ve been using a Metabones LeicaM -E Mount adapter on a Sony A7RII with no issues. I upgraded to a Sony A7RIII and this adapter won’t snap into place. My TechArt adapter snaps into place smoothly with no problems, but not the Metabones. I need an adapter that will work on the Sony A7RIII for manual focus situations. Any recommendations? Have any of you had this issue? Thanks! Link to post Share on other sites More sharing options...
Advertisement Posted January 18, 2020 Posted January 18, 2020 Hi wilfredo, Take a look here Best Leica M - E Mount Adapter. I'm sure you'll find what you were looking for!
lct Posted January 18, 2020 Share #2 Posted January 18, 2020 My favorite on A7s are the Voigtlander VM-E close focus adapter and the Novoflex NEX/LEM adapter. I have no experience with the A7r3 though. Link to post Share on other sites More sharing options...
wilfredo Posted January 18, 2020 Author Share #3 Posted January 18, 2020 3 hours ago, lct said: My favorite on A7s are the Voigtlander VM-E close focus adapter and the Novoflex NEX/LEM adapter. I have no experience with the A7r3 though. Since these are E-mount adapters, I would assume they would work the same? Link to post Share on other sites More sharing options...
cp995 Posted January 18, 2020 Share #4 Posted January 18, 2020 +1 for the VM-E! Link to post Share on other sites More sharing options...
jankap Posted January 18, 2020 Share #5 Posted January 18, 2020 vor 8 Stunden schrieb lct: My favorite on A7s are the Voigtlander VM-E close focus adapter and the Novoflex NEX/LEM adapter. I have no experience with the A7r3 though. The same here (on APS). Wilfredo, do you have asked Metabones for the problem? The Sony E-mount does not change, otherwise Sony lenses would not be compatible on new camera generations. Link to post Share on other sites More sharing options...
wilfredo Posted January 18, 2020 Author Share #6 Posted January 18, 2020 59 minutes ago, jankap said: The same here (on APS). Wilfredo, do you have asked Metabones for the problem? The Sony E-mount does not change, otherwise Sony lenses would not be compatible on new camera generations. I hear you. It could be that I have a defective adapter. Any warranty on it has expired. Link to post Share on other sites More sharing options...
lct Posted January 18, 2020 Share #7 Posted January 18, 2020 Advertisement (gone after registration) 7 hours ago, wilfredo said: Since these are E-mount adapters, I would assume they would work the same? All adapters are not set with the same tolerance i guess. I've just rejected 3 LTM to M adapters, including a Metabone one, for similar reasons as yours. 1 Link to post Share on other sites More sharing options...
Keith (M) Posted January 18, 2020 Share #8 Posted January 18, 2020 I use the Novoflex NEX/LEM adapter on my A7III (and A6500) for a variety of M lenses. Beautifully made and works perfectly albeit a tad expensive. Also have Novoflex's NEX/LER . Link to post Share on other sites More sharing options...
pegelli Posted January 18, 2020 Share #9 Posted January 18, 2020 I use the Hawk Helicoid adapters. I have an older one which has a narrow "throat" (~36 mm) where my 90 mm Elmar/Elmarit, 135 mm Elmar and Telyt 200/4 will get little dark corners. A later version I have with a wider "throat" (~41 mm) work well with all my lenses (tested up to the Telyt 200/4). I find the ability to focus a little closer as the standard Leica MFD advantageous, allthough the longer the lens gets the additional few mm is obviously giving less gain. Link to post Share on other sites More sharing options...
duoenboge Posted January 18, 2020 Share #10 Posted January 18, 2020 I use with my A7r3 an TechArt Pro adapter. For autofocus and manuel focus shots as well. It works fine. Link to post Share on other sites More sharing options...
pgk Posted January 18, 2020 Share #11 Posted January 18, 2020 6 hours ago, wilfredo said: I hear you. It could be that I have a defective adapter. Any warranty on it has expired. Mine is fine so it sounds as though yours is defective in some way. Why not at least ask Metabones to look at it? Link to post Share on other sites More sharing options...
padam Posted January 18, 2020 Share #12 Posted January 18, 2020 I've adjusted a K&F Concept LM-NEX to match infinity focus, and it works perfectly fine (fits perfectly, snug etc.), also had the Voigtlander and it worked fine, close focusing is fine, but I didn't feel it was worth that much more. I got a Novoflex EOSR/LEM for the EOS R from an ebay auction and it started to wiggle slightly after a few months of light use (at least I didn't pay the full retail price), so overall it seems to me that these 'premium' adapters are a waste of money, when there are cheaper ones out there that after a bit of adjust work just as fine for a whole lot less and one can get an extra lens from the savings. Imho, of course. Link to post Share on other sites More sharing options...
wilfredo Posted January 18, 2020 Author Share #13 Posted January 18, 2020 6 hours ago, duoenboge said: I use with my A7r3 an TechArt Pro adapter. For autofocus and manuel focus shots as well. It works fine. How do you get it to work on manual? Even when I set my Sony A7RIII to M focus, it won't shoot manually when my TechArt adapter is attached to it with an M lens. Link to post Share on other sites More sharing options...
duoenboge Posted January 19, 2020 Share #14 Posted January 19, 2020 In the same way as with the normal Sony autofocus lenses. There is no difference. Link to post Share on other sites More sharing options...
duoenboge Posted January 19, 2020 Share #15 Posted January 19, 2020 Sorry there is a difference. With the adapter the image is not enlarged while focusing (when the MF assist is set to "on"). The peaking works well. Link to post Share on other sites More sharing options...
wilfredo Posted January 19, 2020 Author Share #16 Posted January 19, 2020 (edited) 11 hours ago, duoenboge said: Sorry there is a difference. With the adapter the image is not enlarged while focusing (when the MF assist is set to "on"). The peaking works well. I managed to get it to work but even on manual it goes into search mode, at least in low light. I think I’m going to give the Voiglander adapter a try, and will be ordering it. Edited January 19, 2020 by wilfredo Link to post Share on other sites More sharing options...
wilfredo Posted January 27, 2020 Author Share #17 Posted January 27, 2020 Just an update. I purchased the Voigtlander VM-E close focus adapter, and it works really well, even with a 90mm Elmarit R lens I have, which I use with an LR-LM adapter on the VM-E close focus adapter. I'm good to go! Thank you all for your responses! Link to post Share on other sites More sharing options...
nikidi Posted November 24, 2021 Share #18 Posted November 24, 2021 On 1/18/2020 at 7:16 PM, wilfredo said: Hello all. I was wondering if anyone knew of a Sony E lens, to a M mount Leica is possible. Thank you kindly. Link to post Share on other sites More sharing options...
idusidusi Posted March 4, 2022 Share #19 Posted March 4, 2022 I just received the Novoflex NEX/LEM and testing now with my 35/90mm Summicrons. It works brilliantly. I will say on the Sony A1 I needed to up the shutter speed with the 90mm. No so with the 35mm and presumably with the 50mm Summicron when I get that. These two images the first with the 90mm and second with the 35mm are the first tests to check out the lenses and especially to to try zone focussing again. On the A1 the focus aids make it very easy. So far very happy that I can test out my lenses and my abilities with manual focussing before I receive my M11. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/305445-best-leica-m-e-mount-adapter/?do=findComment&comment=4394515'>More sharing options...
mike_j Posted March 28, 2022 Share #20 Posted March 28, 2022 On 11/24/2021 at 3:34 PM, nikidi said: Hello all. I was wondering if anyone knew of a Sony E lens, to a M mount Leica is possible. Thank you kindly. No.. Sony E flange distance is 18mm, M is 27.8mm so M to E is possible, E to M is not, at least not without some optical elements in the adaptor. Link to post Share on other sites More sharing options...
