On 2/2/2023 at 8:21 AM, ramarren said:
I can't say that I know how HP5 renders or what is "native" for it since a B&W film's rendering qualities are so dependent upon exposure, filtering, processing, and all the other et cetera. But, if it is a slightly less contrasty look you are going for with the M10-M, try using a green filter on your lens. You can see the differences between rendering on an Xrite Color Checker between no filter, orange filter, and green filter in my post on this subject here
I tend to use a green filter most of the time in daylight conditions, and of course strive for best exposure (typically, +0.3 to +0.7 EV for raw captures). I find it separates tones subtly and effectively. An orange filter in daylight tends to accentuate contrast even further, with less effect when used under artificial illumination.
G
Now that's an approach I haven't heard before. I should try that. I have a green filter, but use it only to lighten foliage and/or separate lighter and darker leaves. Also, I read everywhere to underexpose by 1/3 or 2/3 with the Monochrom to protect the highlights. Are you overexposing to make up for the amount of light the green filter cuts out? Also, I do portraits more than anything else, and use a yellow or orange filter to smooth out skin tones in open shade; I've never tried a green filter for faces.
x
Level Three - 21 Super Elmar 3,4
  • Like 12
No need to do anything if you're using the Monochrom's built in metering with a green filter ... since it reads through the lens, it will autoadjust exposure for you. (.. and a green filter does not throw off the metering like a deep red will.)
I read the same myth about underexposing by 1/3 or 2/3 EV with the Monochrom. It's driven by the concern that you don't have a multichannel image that tools like LR can use differing channels to rebuild a blasted channel. But my metering calibration tests with the M10-M proved to me that, for raw capture, my camera was already underexposing by -0.3 to 0 EV compared to what I like in a raw file, so I normally set the EV Compensation in Auto mode to 0 or +0.3 EV, sometimes more. I do not get any unexpected blown highlights (I get blown highlights when a scene's dynamics are beyond what the sensor can handle, but then you cannot help that without damaging mid and low tones through severe underexposure anyway.
A green filter on light-skinned people often shows some undesirable skin texture so I'd experiment and see what your subjects' skin looks like that way. If you're shooting darker-skinned people, a green filter will often give skin textures that are very pleasing and difficult to achieve with no filter or a yellow to orange filter.
Experiment ... Film for a Monochrom is cheap! LOL! ;)
G
Old Cannon ...
Leica M10M +  35mm Lux FLE 1 + Orange Filter
A stormy day at Metairie Cemetery in New Orleans. 50mm Noctilux f/1.2.
  • Like 13
Portland Oregon,   M10M 28mm summilux
  • Like 13
Opting to post an image completely unedited, which illustrates how wonderful the M10M image sensor is.
M10M + APO 50mm Summicron-M + Red filter
  • Like 15
50mm Summilux
click for details
Edited by wolan
Summer storm
Uluru, NT, Australia
M10M, 21mm SEM
Edited by Ramesh
35mm Summilux
click for details
35mm Summilux, orange filter
Few weeks ago I bought the m10m to replace my original mm: buffer and high iso being main reason.
Yesterday I took this portrait. The guy just buried his brother.
 I could maybe have taken this shot on the original mm, though I am not sure.
Meet Braco, meaning brother, which is his name, though sad in this context.
50mm lux asph
