maqroll Posted November 21, 2019 Share #21 Posted November 21, 2019 Advertisement (gone after registration) Perhaps here? https://www.sigma-global.com/en/download/lenses/firmware/ Link to post Share on other sites More sharing options...
Advertisement Posted November 21, 2019 Posted November 21, 2019 Hi maqroll, Take a look here Where to find list of current firmware for L lenses by Panasonic and Leica. I'm sure you'll find what you were looking for!
Docderm Posted November 23, 2019 Author Share #22 Posted November 23, 2019 Latest update from Panasonic USA re how to update firmware on a Leica SL lens for use on a Panasonic S1/S1r body I learned that: a) use an SL/SL2 body and update the firmware for the lens b) The update firmware version will reside in the SL lens c) Then simply mount the SL lens on the Panasonic S camera body and automatically the updated firmware for the lens will be used by the camera. Link to post Share on other sites More sharing options...
vanhulsenbeek Posted November 27, 2019 Share #23 Posted November 27, 2019 Do not know about Sigma. But to update a Pana L lens on a SL one simply downloads the update from the Pana page quoted above on an empty SD-card ( as with any Leica update. Follow the normal Leica procedure and the firmware shows itself to be updated. Easy as pie! Did this with the Pana L 24-105 on a Leica SL. 1 Link to post Share on other sites More sharing options...
Docderm Posted November 27, 2019 Author Share #24 Posted November 27, 2019 Thanks, Vanhulsenbeek However I am looking for information about the reverse situation. How to update the firmware on a Leica lens used on a Panasonic model S body. Anyone have any information on the subject? Experience with this issue? Thanks Link to post Share on other sites More sharing options...
zorky Posted January 14, 2020 Share #25 Posted January 14, 2020 https://av.jpn.support.panasonic.com/support/global/cs/dsc/download/index4.html Link to post Share on other sites More sharing options...
georgecp Posted February 3, 2020 Share #26 Posted February 3, 2020 I have had the reverse also work. I have an S1R and updated the Sigma EF to L adapter firmware through the S1R camera and firmware update menu. Same process as described above but in reverse to the above post; I downloaded the Sigma firmware file and placed it on an SD card..installed the Sigma adapter on the S1R..when I went to the S1R's firmware update screen, it recognized both the current and new Sigma adapter firmware and installed it. I have not had the occasion to try this with a Leica lens (have the 75SL and it is fabulous on this camera)..but will keep an eye out and update when the time arises. Link to post Share on other sites More sharing options...
colonel Posted February 27, 2020 Share #27 Posted February 27, 2020 Advertisement (gone after registration) Not trying to downplay the issue, but lens updates are very infrequent. Also if you have the Panasonic body, it’s firmware update covers all makes at the moment Link to post Share on other sites More sharing options...
Ivar B Posted April 28, 2020 Share #28 Posted April 28, 2020 On 2/4/2020 at 12:18 AM, georgecp said: I have had the reverse also work. I have an S1R and updated the Sigma EF to L adapter firmware through the S1R camera and firmware update menu. Same process as described above but in reverse to the above post; I downloaded the Sigma firmware file and placed it on an SD card..installed the Sigma adapter on the S1R..when I went to the S1R's firmware update screen, it recognized both the current and new Sigma adapter firmware and installed it. I have not had the occasion to try this with a Leica lens (have the 75SL and it is fabulous on this camera)..but will keep an eye out and update when the time arises. I own the same camera and lens. It seems, that a firmware upgrade is now available for the lens, but I could not install it. Have you tried? Link to post Share on other sites More sharing options...
jmm1 Posted September 4, 2020 Share #29 Posted September 4, 2020 I have a Leica SL2 and the Lumix 70-200 f2.8 lens. I downloaded the Lens Firmware update 1.1 but there is ZERO information on how to install the lens update if you only have a Leica Body and NO Lumix Body. The link on their page just goes to a general website - how careless of Panasonic! Has anyone worked it out. I could try something but have no wish to "brick" my SL2. TIA John Link to post Share on other sites More sharing options...
helged Posted September 4, 2020 Share #30 Posted September 4, 2020 Use one sd-card, reformat it in-camera, remove the card and upload the lens FW to the card (at top/root level, not in directories), insert the card in the body, from 'Main Menu' go to 'Camera Information' and 'Lens Firmware Version', activate and you're done... Link to post Share on other sites More sharing options...
jcraf Posted November 18, 2020 Share #31 Posted November 18, 2020 On 9/4/2020 at 10:07 AM, jmm1 said: I have a Leica SL2 and the Lumix 70-200 f2.8 lens. I downloaded the Lens Firmware update 1.1 but there is ZERO information on how to install the lens update if you only have a Leica Body and NO Lumix Body. The link on their page just goes to a general website - how careless of Panasonic! Has anyone worked it out. I could try something but have no wish to "brick" my SL2. TIA John I have just updated my Lumix 70-200 f4 from v1 to v1.1 using my SL2 body; I have no Lumix S series body. This update is required in order to use the Lumix 1.4x teleconverter with this lens. Once downloaded as a zip file from the Panasonic website (listed in various posts above), the extracted .plf file should be copied to the root directory of a formatted SD card (as is usual with FW updates) which is then placed into the Leica L mount body (SL2 in my case). Switch on, and in the SL2 menu go to Camera Information > Lens Firmware Version > Start update. It all then works seamlessly. Took a couple of minutes of 'Lens update in progress' on the SL2's screen, then the lens gave an OIS-style physical 'thunk' and the camera told me the update was complete and to restart the camera. Very easy and surely this is what the L-Mount Alliance is all about? 1 Link to post Share on other sites More sharing options...
