erniethemilk Posted September 20, 2019 Share #1 Posted September 20, 2019 Advertisement (gone after registration) Just picked up a used M10-P yesterday and noticed the firmware is not the latest. I've read through the instructions on how to upgrade firmware and seems straight forward enough, just wondering if anything else is to be considered. I've done upgrades in the past plenty of times with the likes of Fujifilm cameras, but obviously as a new (to me) camera, don't want to make any mistakes with it! Link to post Share on other sites More sharing options...
Advertisement Posted September 20, 2019 Posted September 20, 2019 Hi erniethemilk, Take a look here Firmware Update Tips . I'm sure you'll find what you were looking for!
farnz Posted September 20, 2019 Share #2 Posted September 20, 2019 1. Make sure your battery is fully charged before you start - if the battery fails during a firmware upgrade it could brick your M10. 2. Be patient and let it finish completely. Pete. 1 Link to post Share on other sites More sharing options...
LocalHero1953 Posted September 20, 2019 Share #3 Posted September 20, 2019 If you have user profiles, export them to a SD card first, then load them again after update. Most updates prompt you to do this, sometimes they don't. Most times you can export them to the same SD card as you use for the update - I usually do - but the paranoid may wish to use a separate SD card. 1 Link to post Share on other sites More sharing options...
erniethemilk Posted September 20, 2019 Author Share #4 Posted September 20, 2019 Thanks for the information guys.... Have tried to update firmware and all I'm getting is a greyed out Firmware menu item, can't go any further than that. Have tried two different cards each formatted in camera and followed instructions as per the Leica downloads page. Any ideas? Link to post Share on other sites More sharing options...
jdlaing Posted September 20, 2019 Share #5 Posted September 20, 2019 What firmware version does it say in the grayed out menu item? Link to post Share on other sites More sharing options...
erniethemilk Posted September 20, 2019 Author Share #6 Posted September 20, 2019 1 minute ago, jdlaing said: What firmware version does it say in the grayed out menu item? Firmware showing at present is showing as 2.6.5.1 Link to post Share on other sites More sharing options...
a.noctilux Posted September 20, 2019 Share #7 Posted September 20, 2019 Advertisement (gone after registration) Had you downloaded the right file ? from this site ? Firmware (2.7.5.0) Leica M10-P Firmware Chinese English French German Indonesian Italian Japanese Korean Polish Russian Taiwanese Date: 09/04/2019 Format: FW (114.34 MB) Going further... if yes, when you are at the page showing grayed 2.6.5.1 what had you done ? 1 Link to post Share on other sites More sharing options...
farnz Posted September 20, 2019 Share #8 Posted September 20, 2019 Have you extracted the firmware update file and copied it to the root directory ('home' directory) of your SD card? When I used to use Windoze computers I needed to download the zipped file, extract the update file and drag it onto the root directory on the SD card. I use Macs now and the extraction takes place automatically. Since you're seeing a greyed-out menu item it suggests to me that your M10 maybe can't find an upgrade file where it expects it to be - or can't see it because it's encased inside a compressed (zipped) file. Pete. 1 Link to post Share on other sites More sharing options...
erniethemilk Posted September 20, 2019 Author Share #9 Posted September 20, 2019 Downloaded the file direct from Leica Website, copied and pasted directly on to formatted (in camera) SD card. Just a thought, does the file need to go into the Leica 100Leica file, I've been copying it straight to the SD card - not in a folder of any description. Link to post Share on other sites More sharing options...
a.noctilux Posted September 20, 2019 Share #10 Posted September 20, 2019 (edited) The right file must be copied in the root of SD card ! Not in 100xxxx directory. IS it the right file for M10-P ? Edited September 20, 2019 by a.noctilux Link to post Share on other sites More sharing options...
michali Posted September 20, 2019 Share #11 Posted September 20, 2019 (edited) Could also be because you've downloaded the FW update more than once onto the same card? This has happened to me.In this case it overwrites the original download and adds a no.2 or 3 to the file name which the camera doesn't recognise. You have to reformat card and download again. Edited September 20, 2019 by michali Link to post Share on other sites More sharing options...
erniethemilk Posted September 20, 2019 Author Share #12 Posted September 20, 2019 4 minutes ago, a.noctilux said: The right file must be copied in the root of SD card ! Not in 100xxxx directory. IS it the right file for M10-P ? That's what I suspected, thanks, have copied file to root. File Name is: M10-P-2.7.5.0-CUSTOMER.FW which shows as correct M10-P firmware download. I've re-formatted SD card each time tried so far, so no duplicates of FW on the card. Link to post Share on other sites More sharing options...
erniethemilk Posted September 20, 2019 Author Share #13 Posted September 20, 2019 Ah, it seems as if it's working now, currently uncompressing file in camera! Let's hope this does the trick. 1 Link to post Share on other sites More sharing options...
a.noctilux Posted September 20, 2019 Share #14 Posted September 20, 2019 Just wait 👍 1 Link to post Share on other sites More sharing options...
erniethemilk Posted September 20, 2019 Author Share #15 Posted September 20, 2019 4 minutes ago, a.noctilux said: Just wait 👍 Awesome, all worked by the look of it... New firmware now showing in camera information. Thanks all for your help 😎 Link to post Share on other sites More sharing options...
a.noctilux Posted September 20, 2019 Share #16 Posted September 20, 2019 Have fun with your "new M10-P" 😉 1 Link to post Share on other sites More sharing options...
erniethemilk Posted September 20, 2019 Author Share #17 Posted September 20, 2019 Just now, a.noctilux said: Have fun with your "new M10-P" 😉 Thank you! Love it already... 😎 Link to post Share on other sites More sharing options...
Peter Kilmister Posted September 20, 2019 Share #18 Posted September 20, 2019 @erniethemilk Welcome to the M10-P users. A fabulous camera and I am pleased you have updated the firmware. Please show us some photos when you are ready. P.S. I am in West Sussex. Get in touch if you are nearby. 1 Link to post Share on other sites More sharing options...
erniethemilk Posted September 21, 2019 Author Share #19 Posted September 21, 2019 8 hours ago, Peter Kilmister said: @erniethemilk Welcome to the M10-P users. A fabulous camera and I am pleased you have updated the firmware. Please show us some photos when you are ready. P.S. I am in West Sussex. Get in touch if you are nearby. Thanks Peter, appreciate your comments. I'm in Sunny Worcestershire so not too close unfortunately. First impressions of the camera are fantastic. Link to post Share on other sites More sharing options...
