paul.bridges.3388 Posted September 4, 2019 Share #1 Posted September 4, 2019 (edited) Advertisement (gone after registration) Looking at an expensive repair on my Q2. I foolishly used a damaged SD card, which pulled out a copper pin from the card slot when (forcibly) extracted. UK Leica can’t repair the Q2 because it’s weather-sealed so it's off to Germany. Worse still, the Q2 card slot is soldered to the camera motherboard and so it all needs replacing. All because I filled a card and resorted to a compromised spare (for some very mundane shots). 🙄 You’ve been warned. Edited September 4, 2019 by paul.bridges.3388 2 Link to post Share on other sites More sharing options...
Advertisement Posted September 4, 2019 Posted September 4, 2019 Hi paul.bridges.3388, Take a look here Q2: care with SD cards . I'm sure you'll find what you were looking for!
Guest Posted September 4, 2019 Share #2 Posted September 4, 2019 uggg that sucks man , well fingers crossed , for a lower bill Link to post Share on other sites More sharing options...
paul.bridges.3388 Posted September 4, 2019 Author Share #3 Posted September 4, 2019 50 minutes ago, RK1 said: uggg that sucks man , well fingers crossed , for a lower bill Ballpark of €1k..... Link to post Share on other sites More sharing options...
Guest Posted September 4, 2019 Share #4 Posted September 4, 2019 😥 Link to post Share on other sites More sharing options...
leicabug Posted September 4, 2019 Share #5 Posted September 4, 2019 Could you show us your damaged SD card? Link to post Share on other sites More sharing options...
Leica Guy Posted September 5, 2019 Share #6 Posted September 5, 2019 Somewhat in the same vein, last month I was on Cape Cod. Up early one morning to photograph a sunrise at Chatham Light with a rain storm moving out. I got my Q2 mounted on the tripod ballhead and was setting up in the dark, shielding the camera from rain with my jacket. Unfortunately, the ballhead (with Q2) became unscrewed from the tripod and fell to the pavement. I was dumb struck. I’ve used this Gitzo Traveler tripod and RRS BH-30 ballhead for more than 10 years and all over much of the world traveling. I never ever had any indication that only 4 threads were holding the head. Somehow I must have twisted enough times the wrong direction and the camera fell. It cracked the top plate, scratched the hood and on/off lever and scuffed up my beautiful Arte de mano half case. The camera still functioned fine for the rest of the trip although every time I looked at it, my stomach would ache. I got home and the next day sent it to Leica service in NJ. The quote is $850. They’re awaiting a part to complete the repair. Good to check your ballhead to tripod attachment. Mine now has 8 threads and loctite holding it safe and tight. 2 Link to post Share on other sites More sharing options...
lykaman Posted September 5, 2019 Share #7 Posted September 5, 2019 Advertisement (gone after registration) 2 hours ago, leicabug said: Could you show us your damaged SD card? Why on earth would you feel the need to see a damaged SD Card? Link to post Share on other sites More sharing options...
leicabug Posted September 5, 2019 Share #8 Posted September 5, 2019 4 hours ago, lykaman said: Why on earth would you feel the need to see a damaged SD Card? Never seen one in my life... Link to post Share on other sites More sharing options...
lykaman Posted September 5, 2019 Share #9 Posted September 5, 2019 14 minutes ago, leicabug said: Never seen one in my life... What a sheltered life you must live! 1 Link to post Share on other sites More sharing options...
Macberg Posted September 5, 2019 Share #10 Posted September 5, 2019 vor 6 Stunden schrieb lykaman: Why on earth would you feel the need to see a damaged SD Card? It would be also interesting for me to see what precise part/edge/"hook"(?) of the damaged SD card pulled out the copper pin, so that I could check every now and then whether mine is still doing fine or maybe going the same way soon... @paul.bridges.3388 So if you still have it, it would be very nice to see the cause of the hassle. Link to post Share on other sites More sharing options...
Viv Posted September 5, 2019 Share #11 Posted September 5, 2019 7 hours ago, Leica Guy said: Somewhat in the same vein, last month I was on Cape Cod. Up early one morning to photograph a sunrise at Chatham Light with a rain storm moving out. I got my Q2 mounted on the tripod ballhead and was setting up in the dark, shielding the camera from rain with my jacket. Unfortunately, the ballhead (with Q2) became unscrewed from the tripod and fell to the pavement. I was dumb struck. I’ve used this Gitzo Traveler tripod and RRS BH-30 ballhead for more than 10 years and all over much of the world traveling. I never ever had any indication that only 4 threads were holding the head. Somehow I must have twisted enough times the wrong direction and the camera fell. It cracked the top plate, scratched the hood and on/off lever and scuffed up my beautiful Arte de mano half case. The camera still functioned fine for the rest of the trip although every time I looked at it, my stomach would ache. I got home and the next day sent it to Leica service in NJ. The quote is $850. They’re awaiting a part to complete the repair. Good to check your ballhead to tripod attachment. Mine now has 8 threads and loctite holding it safe and tight. Some years ago I destroyed a Nikon D300 in a similar way. 1 Link to post Share on other sites More sharing options...
paul.bridges.3388 Posted September 5, 2019 Author Share #12 Posted September 5, 2019 (edited) 12 hours ago, leicabug said: Could you show us your damaged SD card? I’m traveling without it....but will post later. The SD card lock tab was faulty and I taped it in the field so the camera would continue to record images on it. After the shoot, it was apparent that the tape jammed the card in the slot. I assume the push release was jammed by the tape and so the card plastic tore when I pulled it out with heavy tweezers. It was an expensive, fast card...which motivated me to patch it up 🙄 Edited September 5, 2019 by paul.bridges.3388 1 2 Link to post Share on other sites More sharing options...
jaapv Posted September 5, 2019 Share #13 Posted September 5, 2019 A couple of lessons to be learned here, I guess. 1. Always carry a spare SD card 2. Never force anything. Having Leica remove a stuck card (or battery or lens for that matter) is always far less expensive than having CS rebuild the entire camera to get at the damaged part. 2 1 Link to post Share on other sites More sharing options...
paul.bridges.3388 Posted September 5, 2019 Author Share #14 Posted September 5, 2019 49 minutes ago, jaapv said: A couple of lessons to be learned here, I guess. 1. Always carry a spare SD card 2. Never force anything. Having Leica remove a stuck card (or battery or lens for that matter) is always far less expensive than having CS rebuild the entire camera to get at the damaged part. The large size of Q2 files makes these points all the more important. Link to post Share on other sites More sharing options...
paul.bridges.3388 Posted September 13, 2019 Author Share #15 Posted September 13, 2019 Repair estimate is 600 Euro. Link to post Share on other sites More sharing options...
nicci78 Posted September 13, 2019 Share #16 Posted September 13, 2019 12.5% of the Q2 cost 😥 Link to post Share on other sites More sharing options...
paul.bridges.3388 Posted September 13, 2019 Author Share #17 Posted September 13, 2019 30 minutes ago, nicci78 said: 12.5% of the Q2 cost 😥 I get a sensor clean! 🤗 Link to post Share on other sites More sharing options...
nicci78 Posted September 13, 2019 Share #18 Posted September 13, 2019 Did it need it ? Link to post Share on other sites More sharing options...
paul.bridges.3388 Posted September 13, 2019 Author Share #19 Posted September 13, 2019 4 hours ago, nicci78 said: Did it need it ? Of course not. 1 Link to post Share on other sites More sharing options...
Jared Posted September 13, 2019 Share #20 Posted September 13, 2019 So sorry to hear about this, and thanks for the heads up! I’ll make a point of periodically inspecting my cards to make sure there is no obvious wear in the plastic around the pins. 1 Link to post Share on other sites More sharing options...
