STANDARD H Posted July 10, 2019 Share #1 Posted July 10, 2019 Advertisement (gone after registration) Hi everyone. Got the B&W UV filter for my new Q2 as recommended by several Q/Q2 friends to protect the glass, however, I have a trip coming up with lots of water/beach days. Wanted to know which model Polarizer filter everyone may be using. Any positive/negative feedback welcome. I was looking at the following two, but not married to either. Thanks! B+W 49mm Circular Polarizer MRC Filter B+W 49mm F-Pro Kaesemann High Transmission Circular Polarizer MRC Filter Link to post Share on other sites More sharing options...
Advertisement Posted July 10, 2019 Posted July 10, 2019 Hi STANDARD H, Take a look here Go-To/Favorite Polarizer Filter?. I'm sure you'll find what you were looking for!
bullmoon Posted July 10, 2019 Share #2 Posted July 10, 2019 I went with the XS-Pro (lower profile) Kaesemann HT with the hope that when I forget and leave it on inside, it won't knock my exposure down too much - because I know I'm going to do that <again> eventually. 🙄 1 Link to post Share on other sites More sharing options...
STANDARD H Posted July 11, 2019 Author Share #3 Posted July 11, 2019 11 hours ago, bullmoon said: I went with the XS-Pro (lower profile) Kaesemann HT with the hope that when I forget and leave it on inside, it won't knock my exposure down too much - because I know I'm going to do that <again> eventually. 🙄 Ok, cool - thanks for that! Link to post Share on other sites More sharing options...
dancook Posted July 13, 2019 Share #4 Posted July 13, 2019 I just ordered Hoya 49mm Linear Polarizing Screw-in Filter, it seems a CPL is wasted on a mirrorless/compact - and there isn't a vast selection of linear - but much cheaper. Link to post Share on other sites More sharing options...
jaapv Posted July 13, 2019 Share #5 Posted July 13, 2019 That is correct. A circular polarizer is needed when there is a mirror in the light path. On a mirrorless camera thus obviously not And before the red herring swims: PDAF also works fine with a linear polarizer. Not that ‘this applies to the Q cameras. Link to post Share on other sites More sharing options...
Fedro Posted July 13, 2019 Share #6 Posted July 13, 2019 B&W for me Link to post Share on other sites More sharing options...
Leica Guy Posted July 13, 2019 Share #7 Posted July 13, 2019 Advertisement (gone after registration) It’s very embarrassing, but I thought a circular polarizer meant I could rotate it. Damn. I learned something new and its not even 7 am yet where I live. 😁 2 2 Link to post Share on other sites More sharing options...
dancook Posted July 13, 2019 Share #8 Posted July 13, 2019 58 minutes ago, iQ2 said: It’s very embarrassing, but I thought a circular polarizer meant I could rotate it. Damn. I learned something new and its not even 7 am yet where I live. 😁 Easy mistake 1 Link to post Share on other sites More sharing options...
Jared Posted July 13, 2019 Share #9 Posted July 13, 2019 I couldn’t find in a local store the brand I had originally been looking for, so decided to give “Breakthrough” a try and purchased their X4 CPL. So far, I have been pleased. The brass construction makes it resistant to binding which is a good thing since it is quite thin so would be hard to get a good grip on the inner, on rotating ring for removal. About one stop of light reduction so not quite as much throughput as the latest from Hoya and B+W, but it dies appear quite neutral which is the major selling point to the X4. Construction is excellent, and optical quality is high enough that I can detect no degradation in image quality. Multi coatings are extremely good, easily among the best. if you aren’t worried about losing just a bit more light than the highest transmission filters out there, I highly recommend the X4. If you want to leave it on all the time as sort of a combo lens protector and CPL, I would probably go with the newest B+W or the highest transmission Hoya as they appear to have this one beat by half a stop or so. Link to post Share on other sites More sharing options...
bullmoon Posted July 13, 2019 Share #10 Posted July 13, 2019 Good points - I had read Overgaard's paper where he recommended circular because that's needed if the metering is fed from a mirror split-off, but now I have read that the Q's don't meter that way so linear should be fine as well. 1 Link to post Share on other sites More sharing options...
smenp3 Posted July 15, 2019 Share #11 Posted July 15, 2019 On 7/10/2019 at 1:32 AM, STANDARD H said: Hi everyone. Got the B&W UV filter for my new Q2 as recommended by several Q/Q2 friends to protect the glass, however, I have a trip coming up with lots of water/beach days. Wanted to know which model Polarizer filter everyone may be using. Any positive/negative feedback welcome. I was looking at the following two, but not married to either. Thanks! B+W 49mm Circular Polarizer MRC Filter B+W 49mm F-Pro Kaesemann High Transmission Circular Polarizer MRC Filter I go with Zeiss 49mm. Just be careful water/beach/sand. Link to post Share on other sites More sharing options...
FHPdoc Posted July 15, 2019 Share #12 Posted July 15, 2019 On 7/13/2019 at 2:41 PM, bullmoon said: Good points - I had read Overgaard's paper where he recommended circular because that's needed if the metering is fed from a mirror split-off, but now I have read that the Q's don't meter that way so linear should be fine as well. Thanks for sharing this! Did any of your reading address how linear vs. circular polarizers affect the Q2's autofocus capability? I had understood that TTL autofocus also required circular polarization (if used). Link to post Share on other sites More sharing options...
jaapv Posted July 15, 2019 Share #13 Posted July 15, 2019 There are indeed some sources that suggest that PDAF might be influenced by polarized light. However, it has never been demonstrated reliably. Until then : Urban Myth, probably from the time that AF and focus confirmation systems used mirrors. Link to post Share on other sites More sharing options...
FHPdoc Posted July 15, 2019 Share #14 Posted July 15, 2019 5 hours ago, jaapv said: There are indeed some sources that suggest that PDAF might be influenced by polarized light. However, it has never been demonstrated reliably. Until then : Urban Myth, probably from the time that AF and focus confirmation systems used mirrors. Ah—thank you sir! I should have looked up PDAF when you first mentioned it. 1 Link to post Share on other sites More sharing options...
dancook Posted July 16, 2019 Share #15 Posted July 16, 2019 I used to have CPL's, but changing cameras all the time I stopped using them - This thread prompted me to get a filter because of Ireland trip coming up Tried it in the garden Filter, No Filter, No Filter Processed with -41 highlights and +30 vibrance Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Q2 - With Filter by Daniel Cook, on Flickr Q2 - No Filter by Daniel Cook, on Flickr Q2 - No Filter Processed by Daniel Cook, on Flickr Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! Q2 - With Filter by Daniel Cook, on Flickr Q2 - No Filter by Daniel Cook, on Flickr Q2 - No Filter Processed by Daniel Cook, on Flickr ' data-webShareUrl='https://www.l-camera-forum.com/topic/299123-go-tofavorite-polarizer-filter/?do=findComment&comment=3779265'>More sharing options...
M11 for me Posted July 16, 2019 Share #16 Posted July 16, 2019 In our eyes we do not have a built in Pol filter. So one could argue that such a filter is not needed for a natural rendering. Only for special applications it makes sense. The example above shows us how in Lightroom you can improve the contrast in the sky. Dancook applied the LR rulers for the entire picture I presume. This could be done for the sky only. I think there could be a discussion if to use such a filter at all. At least when you plan to use the filter permanently on your lens. Link to post Share on other sites More sharing options...
dancook Posted July 16, 2019 Share #17 Posted July 16, 2019 4 minutes ago, M10 for me said: In our eyes we do not have a built in Pol filter. So one could argue that such a filter is not needed for a natural rendering. Only for special applications it makes sense. The example above shows us how in Lightroom you can improve the contrast in the sky. Dancook applied the LR rulers for the entire picture I presume. This could be done for the sky only. I think there could be a discussion if to use such a filter at all. At least when you plan to use the filter permanently on your lens. Yes I used global sliders so could certainly take more care over it, I note the filter does leave things looking a little flat by comparison Link to post Share on other sites More sharing options...
