quixotic_elixer Posted May 3, 2019 Share #1 Posted May 3, 2019 Advertisement (gone after registration) I've picked up my first Leica (M3) and scored a pretty good deal on a Canon 50mm 1.4LTM. I'm currently looking for an adapter for it and have found locally someone selling a voigtlander 35-135 adapter, and I am wondering if this will work with this lens? From my research I understand that adapter should be paired with focal length, but i've read that the 50mm framelines also don't disapear So I am wondering whether this adapter will work since the M3 doesn't have 35mm framelines? Are there any other alternative to the voigtlander 50-75 adapters? Your help is appreciated! Link to post Share on other sites More sharing options...
Advertisement Posted May 3, 2019 Posted May 3, 2019 Hi quixotic_elixer, Take a look here Voigtlander 35-135 adapter for 50mm on M3? . I'm sure you'll find what you were looking for!
TomB_tx Posted May 4, 2019 Share #2 Posted May 4, 2019 (edited) The M3 50mm framelines stay visible, but the 135mm framelines will appear with that adapter. It can be used if you can ignore the smaller frame. There are many makes of 50mm adapters. Rayqual is also good. The Canon 50 1.4 is quite good, especially if it is the second version. Edited May 4, 2019 by TomB_tx Link to post Share on other sites More sharing options...
a.noctilux Posted May 4, 2019 Share #3 Posted May 4, 2019 (edited) While waiting for the right adapter 50/75, if price is correct I'd go for the 35/135 adapter. On my M3, when I happen to use a 35mm lens on it, the 135 frame lines don't bother me. The 135 lines are so fine to help composition (and in my use of 35mm lens on M3, these faint 135 lines tell me the 35mm is there 😉). So maybe, this faint 135mm lines in the VF along with the 50mm thick lines can become a plus for you 😏. As side note, I have one Voigtlander 50/75 adapter mount on my Canon LTM 1.4/50mm = nice lens (no not really a Summilux class, but not bad for it's price and age). Edited May 4, 2019 by a.noctilux Link to post Share on other sites More sharing options...
quixotic_elixer Posted May 4, 2019 Author Share #4 Posted May 4, 2019 15 hours ago, TomB_tx said: The M3 50mm framelines stay visible, but the 135mm framelines will appear with that adapter. It can be used if you can ignore the smaller frame. There are many makes of 50mm adapters. Rayqual is also good. The Canon 50 1.4 is quite good, especially if it is the second version. Does anyone know what/where the mechanism that triggers the framelines are? Would it be possible to just jam or stick it so the 135 stays hidden? Link to post Share on other sites More sharing options...
a.noctilux Posted May 4, 2019 Share #5 Posted May 4, 2019 (edited) With your M3's "field control lever", the lever (at/with left hand when looking in the viewfinder) to change it to "50", then put some kind of cardboard/rubber plate to block it at the "50" setting. like this M5, the setting here is 35/135 "50" setting would be at middle "90" at the other side toward the lens Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited May 4, 2019 by a.noctilux Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/296882-voigtlander-35-135-adapter-for-50mm-on-m3/?do=findComment&comment=3734702'>More sharing options...
quixotic_elixer Posted May 4, 2019 Author Share #6 Posted May 4, 2019 39 minutes ago, a.noctilux said: With your M3's "field control lever", the lever (at left hand) to change it to "50", then put some kind of cardboard/rubber plate to block it at the "50" setting. I should note that this is a 1955 M3DS and it doesn't have a frameline lever. How do adapters automatically identify and establish the frameline? Link to post Share on other sites More sharing options...
a.noctilux Posted May 4, 2019 Share #7 Posted May 4, 2019 (edited) Advertisement (gone after registration) Funny, I have one M3 of the first batch 1954, no lever so why I use like described above. Just try "not to worry" about the 135 framelines. How ? To complete your knowledge 😇: One of the 4 "positive claws" on the lens rear is cut to index the right framelines automatically in the M, since the first M lens. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! the claw at left indexes the framelines Leitz/Leica adapters, pictures from Wiki (link to page) "cutting" is around 1 millimeter, 35/135 is the shortest claw, 50/75 medium, 28/90 the longest (about 2mm more than 35/135) Edited May 4, 2019 by a.noctilux Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! the claw at left indexes the framelines Leitz/Leica adapters, pictures from Wiki (link to page) "cutting" is around 1 millimeter, 35/135 is the shortest claw, 50/75 medium, 28/90 the longest (about 2mm more than 35/135) ' data-webShareUrl='https://www.l-camera-forum.com/topic/296882-voigtlander-35-135-adapter-for-50mm-on-m3/?do=findComment&comment=3734740'>More sharing options...
quixotic_elixer Posted May 7, 2019 Author Share #8 Posted May 7, 2019 On 5/4/2019 at 2:38 PM, a.noctilux said: Funny, I have one M3 of the first batch 1954, no lever so why I use like described above. Just try "not to worry" about the 135 framelines. How ? To complete your knowledge 😇: One of the 4 "positive claws" on the lens rear is cut to index the right framelines automatically in the M, since the first M lens. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! the claw at left indexes the framelines Leitz/Leica adapters, pictures from Wiki (link to page) "cutting" is around 1 millimeter, 35/135 is the shortest claw, 50/75 medium, 28/90 the longest (about 2mm more than 35/135) This was really informative, thank you. I guess I can settle with the 35/135 and just live with the 135 lines. Not sure I can justify the extra cost when it can go towards an actual future leica lens lol. Link to post Share on other sites More sharing options...
250swb Posted May 7, 2019 Share #9 Posted May 7, 2019 You can buy the correct adapter from eBay and not expect to pay more than a few $. Link to post Share on other sites More sharing options...
quixotic_elixer Posted May 7, 2019 Author Share #10 Posted May 7, 2019 7 hours ago, 250swb said: You can buy the correct adapter from eBay and not expect to pay more than a few $. What are the downsides of one of the cheaper adapters if they aren't made to spec? Could you personally recommend one that works the same? Link to post Share on other sites More sharing options...
a.noctilux Posted May 7, 2019 Share #11 Posted May 7, 2019 I've tried those cheaper (costing few euros "no name" or unknown naming ) adapters and now they are not in use anymore. Downsides are multiple : soft metal comes first (not much force to bent them) with poor dimensional many times (need to be exactly 1.00mm thick), some stop threading a couple of degrees more or less, some even can't be removed from the body, and so on. Leitz/Leica or Voigtlander adapters are the choices for peace of mind. Link to post Share on other sites More sharing options...
jdlaing Posted May 7, 2019 Share #12 Posted May 7, 2019 11 minutes ago, quixotic_elixer said: What are the downsides of one of the cheaper adapters if they aren't made to spec? Could you personally recommend one that works the same? https://www.keh.com/shop/leica-m-adapt-35-135-sm-to-m-voigtlander-661541.html?prod_id=710646&aid=710646&rmatt=tsid:|cid:1719678158|agid:67449094996|tid:pla-294930372950|crid:335510879501|nw:u|rnd:1430753662937137387|dvc:t|adp:&gclid=EAIaIQobChMIh8OAl9CJ4gIVDvDACh1mAwGHEAQYASABEgK6EvD_BwE Link to post Share on other sites More sharing options...
quixotic_elixer Posted May 7, 2019 Author Share #13 Posted May 7, 2019 3 hours ago, jdlaing said: https://www.keh.com/shop/leica-m-adapt-35-135-sm-to-m-voigtlander-661541.html?prod_id=710646&aid=710646&rmatt=tsid:|cid:1719678158|agid:67449094996|tid:pla-294930372950|crid:335510879501|nw:u|rnd:1430753662937137387|dvc:t|adp:&gclid=EAIaIQobChMIh8OAl9CJ4gIVDvDACh1mAwGHEAQYASABEgK6EvD_BwE I"m looking for a 5-75 adapter for my m3. A Local classified has a 35-135 adapter for $65 CAD, KEH has one for $45USD+45 shipping. Was hoping someone had a solid recommendations on the cheaper chinese alternatives while understanding that the leica/voigtlander ones are probably the safe choice. Link to post Share on other sites More sharing options...
jdlaing Posted May 7, 2019 Share #14 Posted May 7, 2019 43 minutes ago, quixotic_elixer said: I"m looking for a 5-75 adapter for my m3. A Local classified has a 35-135 adapter for $65 CAD, KEH has one for $45USD+45 shipping. Was hoping someone had a solid recommendations on the cheaper chinese alternatives while understanding that the leica/voigtlander ones are probably the safe choice. Tolerance wise you are safer with voitlander. Link to post Share on other sites More sharing options...
jdlaing Posted May 7, 2019 Share #15 Posted May 7, 2019 These are also good quality: https://www.adorama.com/mbl39m5075.html?gclid=EAIaIQobChMIk5nAj4mK4gIVe_fjBx3zdgAXEAQYCSABEgJUH_D_BwE Link to post Share on other sites More sharing options...
250swb Posted May 9, 2019 Share #16 Posted May 9, 2019 (edited) https://www.ebay.co.uk/itm/M39-Screw-to-Leica-M-Mount-Adapter-50-75-framelines-50mm-75mm-Chrome-Brass/264248949416?hash=item3d8676faa8:g:R~4AAOSw~CVck4Qh Given many of the adapters on sale are made by the same company and simply branded you don't have to pay more just because it says 'Voigtlander' on it when they're all from the same factory anyway. And Voigtlander don't sell them anymore so it's difficult finding stock. Don't go for the cheap alloy adapters (although they can work), but the one above with KOOD branding will be fine as it's a company that makes filters for many other camera company's, Leica's UV cut filters for example. Doesn't mean KOOD made it, but they put their name to it. Edited May 9, 2019 by 250swb Link to post Share on other sites More sharing options...
quixotic_elixer Posted May 10, 2019 Author Share #17 Posted May 10, 2019 On 5/9/2019 at 3:59 AM, 250swb said: https://www.ebay.co.uk/itm/M39-Screw-to-Leica-M-Mount-Adapter-50-75-framelines-50mm-75mm-Chrome-Brass/264248949416?hash=item3d8676faa8:g:R~4AAOSw~CVck4Qh Given many of the adapters on sale are made by the same company and simply branded you don't have to pay more just because it says 'Voigtlander' on it when they're all from the same factory anyway. And Voigtlander don't sell them anymore so it's difficult finding stock. Don't go for the cheap alloy adapters (although they can work), but the one above with KOOD branding will be fine as it's a company that makes filters for many other camera company's, Leica's UV cut filters for example. Doesn't mean KOOD made it, but they put their name to it. THANKS! I'll take a look at it On a separate note, my canon 50 LTM just came it and it's quite a beaut and can't wait to start to use it. Something I noticed is that the aperture controls only work in full stops. My question is if I adjust it to the halfway point, does that equate to a half stop adjustment? Or is that relationship nonlinear? I'm just looking to understand if it's possible to make small exposure adjustments on a camera and lens that only operate in full stops. Link to post Share on other sites More sharing options...
a.noctilux Posted May 10, 2019 Share #18 Posted May 10, 2019 My Canon LTM 1.4/50 can be adjusted the aperture as I like between two clics. I'm sure that those settings are linear. I have 50mm older Summilux-M with full stop "clics", and newer Summilux-M with half stop clics. Even I prefer those without "aperture setting clic" at all, like my Elmar or Summar (in LTM 😇) or some Jupiter 3 - 8 in 50mm. Link to post Share on other sites More sharing options...
