JJ2005 Posted May 9, 2019 Share #21 Posted May 9, 2019 Advertisement (gone after registration) I use Godox X1, and Xpro triggers 1 Link to post Share on other sites More sharing options...
Advertisement Posted May 9, 2019 Posted May 9, 2019 Hi JJ2005, Take a look here Looking for a Flash... . I'm sure you'll find what you were looking for!
ramarren Posted May 10, 2019 Share #22 Posted May 10, 2019 13 hours ago, iQ2 said: What RF transmitter do you use? I have the Canon RF transmitter. It does not work on the Leica. I assume you are also using receivers of the same brand as your transmitter under each flash. I have both Cactus V2 and Cactus V5 triggers. Simple, manual things. Work great with every camera I've used them with. 11 hours ago, maxtor said: Nikon SB 300 works well with LQ2 (only manual whether TTL) ? What transmitter ? What's LQ2? My Nikon flash is an SB-30. Link to post Share on other sites More sharing options...
maxtor Posted May 10, 2019 Share #23 Posted May 10, 2019 2 hours ago, ramarren said: I have both Cactus V2 and Cactus V5 triggers. Simple, manual things. Work great with every camera I've used them with. What's LQ2? My Nikon flash is an SB-30. OK, thanks, Nikon SB-30 (I didn't know this flash earlier, I've Nikon SB-300). LQ2 this is my abbreviation of Leica Q2 Link to post Share on other sites More sharing options...
ramarren Posted May 10, 2019 Share #24 Posted May 10, 2019 (edited) Ah. The SB-30 has both manual and built-in auto flash modes, and Nikon TTL capabilities. It works well with all my cameras using the remote triggers in both manual and built-in auto modes; TTL only works for compatible Nikon cameras. It cannot be fitted directly to the CL because of a mechanical clearance problem with the hot shoe and the viewfinder bulge. I don't have a Q2 so I cannot say whether it is compatible, but since the Q2 top is flat there should not be any problems. I suspect the same would be true of the SB-300, but of course I've never seen one of those or tried to fit one to a camera. The SB-30 is particularly useful to me because it has a built in IR flash cover shield which blocks the flash in visible light but allows it to trigger other flashes with slave flash sensors (like my Paterson Flash Panel units). It also has a small diffuser built in which allows it to cover a 28mm lens on FF field of view pretty nicely for casual shooting. Edited May 10, 2019 by ramarren Link to post Share on other sites More sharing options...
maxtor Posted May 10, 2019 Share #25 Posted May 10, 2019 1 hour ago, ramarren said: Ah. The SB-30 has both manual and built-in auto flash modes, and Nikon TTL capabilities. It works well with all my cameras using the remote triggers in both manual and built-in auto modes; TTL only works for compatible Nikon cameras. It cannot be fitted directly to the CL because of a mechanical clearance problem with the hot shoe and the viewfinder bulge. I don't have a Q2 so I cannot say whether it is compatible, but since the Q2 top is flat there should not be any problems. I suspect the same would be true of the SB-300, but of course I've never seen one of those or tried to fit one to a camera. The SB-30 is particularly useful to me because it has a built in IR flash cover shield which blocks the flash in visible light but allows it to trigger other flashes with slave flash sensors (like my Paterson Flash Panel units). It also has a small diffuser built in which allows it to cover a 28mm lens on FF field of view pretty nicely for casual shooting. Hi, Thank you for help and excellent explanation. I've SF-40 for Q2 then I probably will not try Q2 with SB-300 or my SB-910. Link to post Share on other sites More sharing options...
dancook Posted May 10, 2019 Share #26 Posted May 10, 2019 For my Q2 I use a re-branded Godox flash, just in manual mode though. - I like that it has a li-ION battery which lasts PIXAPRO® Li-ION350II Speedlite with Rechargeable Battery, Built-In 2.4GHz Receiver & High-Speed Sync Link to post Share on other sites More sharing options...
benedictc Posted September 14, 2019 Share #27 Posted September 14, 2019 Advertisement (gone after registration) On 5/1/2019 at 5:28 AM, Kaiden said: I use Wireless Profoto Lighting (B10's, B1X's, and A1 Off Camera Of Course) with the Standard Air Remote. Works Amazing! Can I ask which Air Remote do you use with your Leica Q/M? Do you just use manual mode since Profoto does not support Leica cameras Link to post Share on other sites More sharing options...
Trankster Posted September 14, 2019 Share #28 Posted September 14, 2019 I would love to find a small/mini manual flash with tilting head for travel mainly for fill on-camera. Light weight and fast recycle, too. Does such a thing exist? My Olympus EM-1 2.0 came with one but it is TTL only. Link to post Share on other sites More sharing options...
higa Posted September 15, 2019 Share #29 Posted September 15, 2019 I bought a Bargain condition Sf-40 from KEH that works really well. But like everyone said, the TTL is clunky at best, so I find myself using the manual setting on the SF40 and dialing it way back. In situations that I would usually use a flash in an SLR, I find myself using the SF40 and Leica Q about 50% of the time. The other 50% I just forego the flash and just use the Q . with a high ISO. I like the way the Q renders "in the dark" more than I like the way the Q+SF40 will render the scene. 1 Link to post Share on other sites More sharing options...
tesiz Posted October 8, 2019 Share #30 Posted October 8, 2019 Godox TT350 N flash, is a small 2xAA battery unit more similar in size to a Leica flash. (SF 40) . I had a trigger on my camera hotshoe. It is small and very usefull. It suits for everday usage I doesn't support TTL on leica. Adjust manuel Link to post Share on other sites More sharing options...
PaulJohn Posted October 11, 2019 Share #31 Posted October 11, 2019 On 5/9/2019 at 8:50 PM, JJ2005 said: I use Godox X1, and Xpro triggers Which triggers? I have Fuji and Sony Xpro triggers but am nervous of using them as manual warns against. Link to post Share on other sites More sharing options...
LocalHero1953 Posted October 11, 2019 Share #32 Posted October 11, 2019 12 minutes ago, PaulJohn said: Which triggers? I have Fuji and Sony Xpro triggers but am nervous of using them as manual warns against. I use the Xpro Canon trigger on the SL Link to post Share on other sites More sharing options...
rbookman Posted October 30, 2019 Share #33 Posted October 30, 2019 On 3/28/2019 at 7:25 PM, T.J. said: Has anyone tried a flash unit with their Q2? If using one, any recommendations? Or simply, who needs a flash? I have used my (long-time) Nikon SB-800 Speedlight with my Q2 in A or M mode (but not TTL) either on camera or off camera with a Pro|Master transmitter/receiver pair. Works great! Link to post Share on other sites More sharing options...
gdclarkMiami Posted November 2, 2019 Share #34 Posted November 2, 2019 Don't laugh, but I am using the FlashQ Q20II which is USD $70. I have been happy with the results so far as I mainly use for fill purposes. But having a cheap remote triggering flash that is small and easy to pack with my kit has been great. Link to post Share on other sites More sharing options...
gdclarkMiami Posted November 5, 2019 Share #35 Posted November 5, 2019 On 11/2/2019 at 1:17 PM, gdclarkMiami said: Don't laugh, but I am using the FlashQ Q20II which is USD $70. I have been happy with the results so far as I mainly use for fill purposes. But having a cheap remote triggering flash that is small and easy to pack with my kit has been great. Here is an image I shot of my daughter recently. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 8 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/296321-looking-for-a-flash/?do=findComment&comment=3848293'>More sharing options...
elopezso Posted November 24, 2019 Share #36 Posted November 24, 2019 On 5/8/2019 at 9:42 PM, Leica Guy said: Thr SF-40 is a pretty obvious and solid solution for a Q or Q2. I had an SF-26 and sold it. I have an SF-40 and it works well enough. What are your settings on the flash, Leica Guy? Link to post Share on other sites More sharing options...
Leica Guy Posted November 25, 2019 Share #37 Posted November 25, 2019 5 hours ago, elopezso said: What are your settings on the flash, Leica Guy? I pretty much use it on TTL unless I’m just doing everything manual. I shot a party a few days ago on TTL and it worked very well. Camera was 1/125, f/1.7, ISO Auto as I remember. I’m traveling right now and cannot get to LR to see exactly. TTL on the SF-40 for sure. Link to post Share on other sites More sharing options...
ADrake0506 Posted November 29, 2019 Share #38 Posted November 29, 2019 (edited) I do get it, but I have to ask why are we spending $5000 for a camera and then trying to get the best and consistent TTL results from a non-Leica on camera flash unit? Maybe because we all say that light is light and why pay anymore for the same light; I don't know. I must admit that my reluctance in purchasing the SF-40 has always been knowing that it was just a rewrapped Nissin flash unit with a jacked up price due solely to the significance of the red dot association. I have the corresponding Nissin unit that is designed for Fuji and I have used it in the manual mode on my Q and M262. The Fuji EF-20 affords a low profile, is good for very minor fill, and will work through the shutter speed range but lacks any directional capabilities. Of course any unit works fine after I dial it in and remember not to change my distance. I was wondering if anyone has used a Panasonic or Olympus designed flash unit in TTL mode with the Q? Edited November 29, 2019 by ADrake0506 corrections and additional explanations Link to post Share on other sites More sharing options...
NRKstudio Posted December 3, 2019 Share #39 Posted December 3, 2019 On 5/1/2019 at 7:28 AM, Kaiden said: I use Wireless Profoto Lighting (B10's, B1X's, and A1 Off Camera Of Course) with the Standard Air Remote. Works Amazing! I have a profoto A1X for Sony. Are you saying that the A1 will work in auto mode on camera? Also, will the A1 work off camera with the Profoto hot shoe remote even if it’s not for a Leica?? Link to post Share on other sites More sharing options...
budjames Posted December 9, 2019 Share #40 Posted December 9, 2019 On 5/1/2019 at 8:28 AM, Kaiden said: I use Wireless Profoto Lighting (B10's, B1X's, and A1 Off Camera Of Course) with the Standard Air Remote. Works Amazing! Does it support HSS on the B10? Regards, Bud James Please check out my fine art and travel photography at www.budjames.photography or on Instagram at www.instagram.com/budjamesphoto. Link to post Share on other sites More sharing options...
