I have a similar post on DP Review where you can see this pictures at higher resolution with their EXIF files.  See https://www.dpreview.com/forums/post/62155942
This was my first try to shoot anything in the night sky. It was an unusually clear night (for Singapore in December) and I spotted this crescent already fairly high in the sky.  I had a new (used) Vario-Elmarit-SL 90-280mm mounted on a Leica CL, so I decided to move the tripod on to the terrace.
I'm not thrilled with the results and wondered if anyone could suggest if it can get better results.  The first shot is the full APS-C frame - so 430mm equivalent. The second shot is a crop from the same frame.
I do now realize that I could have lowered the ISO speed since the camera was already on a tripod.
Edited by vikasmg
That looks pretty good to me. To get substantially more definition ne3ds a much larger image size: you'll really need an 800mm lens (or longer) and a very solid tripod, very clear air. Exposure of the Moon itself is essentially a sunlight exposure, so set f/11 @ 1/ISO for it and watch for highlight saturation.
Yes I realized a longer lens would have been useful.  However this is a rare photo type for me so it’s unlikeley I’ll go that route!  Thanks for your suggestions.
Edited by vikasmg
Focus is key...also solid tripod, having said that I have many moon and eclipse shots hand held.  Here are two hnd held shots both with Canon 5D2 and 100-400 mm lens
this one at iso 2500 F5.6 ( I would use around this aperture for new crescent waxing moon) full moon is different.
This one with Jupiter at at 200 mm same settings iso 2500 F5.6 and 1/750
here is afully eclipsed moon
Iso 2500 F7.1 shutter 1 second on a tripod 400 mm
catching the moon at full moonrise is fun, here is one with canon 7D 400 mm lnes eq of 628 mm iso 2000 F7.1 1/80 shutter speed on a tripod...I use pohtographer's ephemeris app to know time and location (bearings) of moon rises etc
There are many old manual focus long lenses that will do an excellent job on APS-C with dumb adapter. For me also Moon (and Jupiter/Saturn etc.) are curiosity object that is why I am also reluctant in getting "proper" lens/telescope to shoot them, however I have had good success with 400mm Telyt f6.8.  This lens is extremely sharp in the center and great for such shots. I have to add that for any long lens, one has to learn how to use properly (tripod, focusing, effect of turbulent air etc.). But it is fun to shoot. This is my Moon shot (without crop) with 400mm on APS-C.
I will also add that long lens (400+) is useful only to get closeup shots. Many a times a Moon photo with lots of context looks much better. For those, your 280mm should be more than sufficient.
This one is 180mm f/3.4 on FF sensor M240 without crop.
Leica M10 Elmarit 135 mm iso 400 1/125 at full moon
another Leica M10 with Elmarit 135mm eclipsed moon on a very cloudy morning, January 2018  iso 3200 1/15
Edited by tonyniev
Good advice all the above Vikas. When I shoot the moon, I use 1250mm of focal length, and end up with nearly the APSc chip covered.
Disagreeing slightly with the advice, clarity isn't the real essential at that longer focal length, stability is. Stability of the equipment obviously, and more so, stability of the atmosphere.
I've imaged in foggy conditions better than some "clear" nights, however this becomes more of an issue at longer than the focal lengths we are talking here.
Bear in mind you balcony will be above a hot asphalt area, and there will be thermals up and down, potentially destroying the image.
This is with the old T, and my 1250mm focal length scope. 1/800th sec, f5, ISO400.
Gary
Post processing helps too- I am posting a super sharpened, exaggerated postprocessed moon image using Canon 5D2 400 mm iso 200 F11
and cropping using 400 mm here too
Edited by tonyniev
Although we normally only accept Leica images, I’ll let them stand as an illustration. But please use images within the forum  rules.
Nice picture Gary.
Post processing is tricky IMHO.  Tony's image is oversharpened and shows squiggly artifacts.  A lot of digi images show white spots and noise, or other problems.
One needs good lenses and perfect focus...and rigorous photographic technique for good moon pics.
Best pictures are usually at first or last quarter.  Full moon pics can look too flooded with light.
But it's always worth trying to get that pic which might rival NASA...🤣.
1 hour ago, david strachan said:
Nice picture Gary.
Thank you Dave, it goes to show what can be achieved with a simple chip and a mirror or two.
To be honest, it is the simplicity of one shots like this that make it appealing. Most of my "serious" lunar shots are with a posh webcam, and using perhaps 500 to 1000 or more images, then stacked, and aligned, then all but the best discarded. A mono webcam too.
I'd post a sample, but it is not with Leica, and I don't want to incur the wrath of Jaap.
Gary
Thanks.  Nice shot!
I agree.  And nice shot!
...here is afully eclipsed moon
Wonderful.  Thanks for the information and assistance!
