The red dot circle is larger than the M 10P screw. Thus if you were able to get the screw it would leave a gap around the screw that I think would be ugly.
Would probably still look better than tape on the silver camera.
I doubt if the hole is threaded on the covers not designed for the screw. Think of the pennies threading the hole would add to the manufacturing cost...
Also, there would still be the circular recess where the dot fits in, which would look strange around the screw.
I suspect it is the same screw hole vs red dot hole as my M-P 240.
I wanted to go other way replacing my screw with a dot. Under the screw is totally different to the under dot.  Under the screw is no foundation to hold a dot.  So you won't be able to go the other way either.
Hope you can understand my explanation.
2 hours ago, pico said:
That's easy to say. It does not twist to weasel off as are other red dots.
I think they use more adhesive for optimum weather sealing.  It does twist off eventually......but at the cost of broken thumbnails
Here's an image of what the standard M240 looks like with the red dot removed - big dot-sized depression in the metal, with a (probably plastic?) little black insert, and an unthreaded access hole in it. No screw at all.
https://goo.gl/images/jn2yp4
The M8 and the film M6 had a sloppier big triangular access hole: https://goo.gl/images/TxvmXN
The "red dot on the top-plate" Leicas have never had a screw in addition, AFAIK - the dot (black or red) is the only thing protecting the access hole.
It was too late for me when I realized this. After I managed to twist it off, I had to weather seal the big dot-sized depression with a piece of chewing gum. Switched to the M10-P now. Since Adobe doesn’t support that camera with their profiles, yet, I’m still waiting for Andy to send me his. 😉
  • Haha 1
